Question about HP Laser Jet 1320 Printer
Hp laserjet 1320tn folds the upper right-hand corner of the page
  • Anonymous May 08, 2009
    I have same problem. This happened after new cartridge was installed. Put old cartridge back in and problem continued.
    Scholar:
  • 136 Answers
YOU can also Physically place the paper up through the paper tray becareful not to touch the foamy roller and see if anything is getting caught if you do not notice anything chances are you have a bad picker on your fuser and that will need replacing.
I seen this happen when end-user try to print labels and one of them gets stuck inside.
Posted on Sep 14, 2009
    Problem Solver:
  • 5 Answers
Check carefully for any small scraps of paper caught in the paper path. Do a 1/2 way test, do a print job, listen for the paper to get just under the toner then quickly open the front of the printer (may take a few tries) see if the paper is folded there or if it's happening later that way. If it is folded before entering the fuser, you probably have a small piece of paper in the paper chute somewhere. If it's not and folds later, the fuser is probably worn badly.
Posted on Jun 21, 2009
1320 Printer prints with corner fold
This tells me something is getting caught usually I would recheck the Paper Tray. If possible you could run the paper through the Bypass or Tray One as HP would call it. See if it is happening there if so then you can eliminate the Cassette Trayi
Also Did you run any lables through this Printer ??
Sep 12, 2009 | HP LaserJet 1320 Printer
HP laserjet 4350 DTN Folding corners
teflon coating on heat roller in fuser is coming apart. replace the fuser. also check to make sure the paper tray is set to the correct size. this means pull the tray out, remove all paper, look inside to make sure the arrow is pointing directly at the correct media size you are using i.e. letter or legal or whatever you are using. Good Luck! please rate this carefully.
Oct 09, 2008 | HP LaserJet 4350dtn Printer
HP LJ 4350 paper folding problem
It could be either the paper feed assembly, part # RM1-0012, or the registration assembly, part #RM1-1098. These parts can be bought at TSAworld, phone # 1-800-633-6626
Aug 08, 2008 | HP LaserJet 4350 Printer
Folded corners
Your printers papper feed is history.
Time to get a new printer.
It's sad but true.
Thank you for choosing FixYa!
Az.
Aug 06, 2008 | HP LaserJet 2300 Printer
Hp lazer 1300
The Printer's Fixing Film on the fuser assy is broken. It should be replaced. Go to a Service Center and replace the fault part.
Mar 05, 2008 | HP LaserJet 1300 Printer
Trouble Shoot for Printing HP Printer
the problem is with the sleeve that inside the fuzer unit.
it may shredded.. you cant solve the problem by your self.
thanks
Feb 22, 2008 | HP LaserJet 1020 Printer
HP Color Laserjet 3500 printer - no black on left side of page
The folded paper solution for for me. Thanks to all for sharing!!!!
I had the same problem. No black or cyan on the left side of the pages. From this advice... I folded a stack of 4 pieces of paper in half and then half again. I took out the transfer unit and put the folded paper in the upper left corner and then put the transfer unit back in. WORKS BEAUTIFULLY! Thanks you all sooooo... much!
Sep 25, 2007 | HP Color LaserJet 3500 Printer
222 people viewed this question
Seeker5211
Seeker5211
