Question about Microsoft Xbox 360 Elite Console
Xbox360 connect problems using 2wire2701HG-D
So i'm using a 2wire2701HG-D i can connect to xbl just fine and microsoft is useless, when it comes to these routers it seems, as tried several solutions: however i have recently come across something intriging but do not know how to do it, I was told to give the 360 a static ip through the router or change it to dmz~ However! i cannot find my 360 on the router in the networking list, it's just the simple fact i want to use connect so i can load some music and vids onto my 360 elite~
  • silenieuxevo Feb 09, 2009
    i apologize i forgot one majour detail, i am using a wire connection, since the weire sits on my desk and i'm too cheap to pay 100usd for a wireless adapter for 360~
    President:
  • 2,559 Answers
The settings you are looking for are not in the router,They are in the xbox settings.
xbox360 connect problems using 2wire2701HG-D - ba6812a.gif 93a81f8.gif db4858a.gif
Please rate this a fixya
Posted on Feb 09, 2009
  • Randy Hough
    Randy Hough Feb 10, 2009
    That is fine,you set it up the same way as above,The xbox will find the connection and all you have to do is click edit and change it that way.
Problem with my LG TV and my XBOX360 , there no picture and sound when i connect my xbox with hd cable.
Try different AV ports on the TV, if it doesn't work press the right trigger + Y, right after the console starts (this will reset the resolution of the console output) I'm assuming you are using the same cable that worked with another TV, so neither the cable is broken, neither the Xbox. It can only be an output format problem, bad configured or a faulty TV.
Jun 09, 2012 | Microsoft Xbox 360 Elite Console
Xbox not connecting to router
call your internet service provider
Jul 13, 2010 | Microsoft Xbox 360 Console
I can't set my xbox360 to the internet
try running the diagnostic to see what the problem is. Could be a router / modem error or simply XBL is down.
Also reset your modem / router leaving the power off for at least 30 seconds then reconnect the router 1st, wait another 30 seconds then plug in the modem.
Feb 27, 2010 | Microsoft Xbox 360 Console
My xbox360 won't read disc, spins for awhile and
The best bet is to try and clean the laser, if the unit is under warranty, contact microsoft and send it back, if not, dont use a laser cleaning kit, they are useless at cleaning and excellent at spreading the grime over the eye. Open the case, an online guide will help you learn the art of pulling apart the xbox, dis-assemble the dvd drive assembly and clean the laser using a cue tip or cotton bud. Good Luck.
Nov 23, 2009 | Microsoft Xbox 360 Console
How do you unblock a xbox360 consul to go online
if the xbox has been banned from xbl there is no going back online with that console you will have to buy another one, sorry
Nov 09, 2009 | Microsoft Xbox 360 Console
I cannot connect to xbox live because my xbox360 cannot find my network
i had this exact problem. the reason mine wasn't working was because the security settings for my wireless router were set on wp2a and the xbox 360 can't pick this up. change your wireless router security to wpa and you should be fine...after i did this it saw my network and i was fine
Jun 02, 2009 | Microsoft Wireless Network Adapter Xbox...
No connection ATALl to internet/live
Okay check the cable of the xbox make sure its not broken or KINKED could have a broken wire somewhere make sure the wire work try the wire on a computer to see if it gets an IP.
Check the connector too, make sure none of the wire are lossen up, if so then replace the connectors or buy a new wire. make sure its Cat 5 or Cat 5E. doesnt have to be cat 6. thats overkill.
if its wireless then check if your router has WEP or WAP enabled, then you have to get the Key to get into the router, and make sure the SSID of the router is correct.
Hope this helps
Good Luck
Rate this please
Dec 19, 2008 | Microsoft Xbox 360 Console
HDMI XBOX360 Elite -"No Signal"
The connection order can be a key issue as to whether or not the HDMI signals will pass through the system. For best results the receiver should be turned on first, then the source device(s) and then the display. The reason for this has to do with getting the equipment to handshake properly for the HDCP protocol.
If HDMI video will not pass through your receiver, you may with to just connect the xbox using the component cables. Since component will pass through 720p and your TV is 1080i you should expect the same qualtiy and a more crisp picture.
Oct 12, 2008 | Denon AVR-2307Ci Receiver
Very first update for xbox live how do i get it plz help its reckin my head
If you have a game and your connected xbl it should ask you "You need to download this patch or you will be signed out of xbl" download, if it works dont worrie about the update, if it does download it to. If you realy want it search Spring update in google and burn that file to a disk.
May 03, 2008 | Microsoft Xbox 360 Console
Xbox360 problem
you have to install the update for backward compatibilty.
Dec 26, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Elite Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
