Question about HP Laser Jet 1320 Printer
HP Laserjet 1320 Can't Print PDF
Errror: Your Application needs to be configured for printing to a PostScript Language Level 2 printer.Select “Language Level 2” in the PostScript options section of he Advanced Print dialog.
OK, so I go check this and it is already set to level 2.
The driver is HP Universal Printing PS installed from the internet
The printer is a HP laserjet 1320.
  • 17 Answers
SOURCE: Model : HP LaserJet 1320
Hi, If that is the only light on (blinking or not), then you probably have a paper jam or a door open somewhere on the printer. Make sure both doors are closed securely at the back of the printer. Make sure that the toner cartridge is secured inside the printer. You not only have to just insert it, but you have to insert it until you can feel it lock into place. Make sure there is no paper jammed inside the printer or inside the rear doors. If you have a blinking light AND the power light is ON, press the GO button. This is also a sign that a complex print job was sent that max'd out the installed memory. Hope this helps!
Posted on Feb 15, 2007
  • 28 Answers
SOURCE: HP Laserjet 1320 Printer doesn't respond
Manual Feed or Continuable
This state can be reached in
the following circumstances:
● Manual feed
● Out of paper for the
specified tray
● General continuable error
● Memory configuration error
● Personality/Job related
To recover from the error and
print whatever data is possible,
If the recovery is successful,
the printer goes to the
Processing Data state and
completes the job.
If the recovery is unsuccessful,
the printer returns to the
Continuable Error state.
Posted on Feb 22, 2008
  • 13433 Answers
SOURCE: Slow printing of Acrobat pdf files on HP Laserjet 1300
I beleave this is a issue with the drivers, I'l look into this more but I suspect there is no easy fix for this, other than geting another type of printer. but hold on. lets see what I can dig up.
Posted on Sep 27, 2008
SOURCE: Laserjet 1320 will not pick paper
A small plastic 'key' on the end of the paper pickup drive shaft has been known to break off. You will know if this has happened if the paper feed roller rotates freely.
Posted on Nov 05, 2008
  • 245 Answers
SOURCE: My HP LaserJet 1020 don't print pdf
go in contact with HP help and customer support....or read ur instruction booklet under trouble.shooting aand help......
Posted on Mar 12, 2009
How do I get a page count on my laserjet 1320?
You can see the the count in configuration page, to print configuration page do the following:
To print the configuration page from the printer, press GO for 5 seconds, until the yellow light comes on, when the printer is in the ready state....
Jun 20, 2013 | HP LaserJet 1320 Printer
Can't install hp 1320 printer
Hi downward_man,
Here's the instruction on how you will install your HP Laser Jet 1320 Printer:
1. Access the HP hardware support site to retrieve the HP LaserJet 1320 driver download.
2. Click the link that represents your computer's operating system.
3. Scroll down the page, and click the "Download" action, below the "Driver - Universal Print Driver" table. Opt to save the driver, as the download file has the setup application that is needed to install it.
4. Double-click the setup application's icon from its new file location on your hard drive. The HP installation application will open automatically.
5. Click "Next" to proceed to the first installation steps.
6.Select all of the HP recommended installation options, and click "Next" to begin copying the driver's files and components to the computer.
7. When the HP installation wizard asks, plug the HP LaserJet 1320 USB sync cable to the USB port, located on the back of the printer hardware. Connect the other end of the cable to an open USB port on your computer.
8. Click "Finish" to complete and conclude the HP LaserJet 1320 series driver installation process.
Hope it helps.
Thank you for using FixYa.
Jan 27, 2011 | HP Laser Jet 1320 Printer
My HP Laserjet 1320 won't print even modest sized PDF files. The Printer Window says "Error-Printing" I've had this problem for years. How can I get my printer to print PDF files? I increased the memory...
If you are using a PS (post script) print driver, delete it and install the PCL driver (PCL5 or PCL6 if available). May help, not positive. I have seen lots of pdf printing problems with PS or incorrect model drivers.
These drivers are free to download at ""
Feb 06, 2010 | HP LaserJet 1320 Printer
Hello,my hp laser jet 1320 does not work correctly,I work under an office network, some time it prints and some time does not print specially about pdf files or high size files, the alert is: fail to...
Is there a typical application you are using? I noticed that file size (especially in adobe) can be an issue. If you go to printer settings (start / settings / printers / right click on the 1320 and select properties) choose device settings and the very bottom item is printer memory. I would increase this to like 80mb.... hope this helps
Jul 19, 2009 | HP LaserJet 1320 Printer
Mac laptop hooked up to HP laserjet 4 plus gets error message:
This printer will not work with a Mac - it has no postscript.
The only laserjet 4's that work with Macs all have an "M" in their name - 4M, 4M Plus etc.
You might be able to get a Postscript personality module for the printer to effectively upgrade it to the "M" version.
Feb 05, 2009 | HP LaserJet 4 plus Printer
Can't print entire pdf documents only first page.
Try this
For Adobe Acrobat Professional 9:
  1. Choose File > Print.
  2. Click on Advanced.
  3. Choose Postcript Options.
  4. Under Font and Resource Policy, select "Send for Each Page".
  5. If "Print as Graphic" is checked, it must be unchecked, as well as "Send As Group" if it does not uncheck itself when you select "Send for Each Page"
  6. Save it as a custom configuration.
Jan 16, 2009 | Office Equipment & Supplies
1320 not printing all the time
Your USB cord may be too long, or you have too many USB devices running. Try removing any other USB device, except the printer and do a test print.
Nov 17, 2008 | HP LaserJet 1320 Printer
Hp 1320 prints blank pages
My HP 1320 printer is printing blank pages and it will not even print test pages etc
Nov 03, 2008 | HP LaserJet 1320 Printer
HP Printer 1320 PCL XL error
I'd suggest downloading and installing the PS (PostScript) driver from HP here:
Then use the PS driver when you're printing .pdf files. Use your existing PCL driver when printing all other types.
i hope it would help you...
Oct 13, 2008 | HP LaserJet 1320 Printer
Re: HP 1320 won't take the tray designation for 2 and 3 Help
Hello classygirl,
I had this exact same problem and resolved it by downloading the HP LaserJet 1160/LaserJet 1320 North American and Western European Full Printing Solution which can be downloaded from
Because the 1320 does not have a built-in interface, installing the basic drivers will not work. You must download and install the full 400+mb package.
Hope this helps!
Aug 28, 2008 | HP Laser Jet 1320 Printer
676 people viewed this question
Ben Johnson
