Question about Sony Handycam DCR-SR40 Camcorder
Video memory full on camcord, how to burn it onto a dvd?
We tried to remove all our video recordings onto our computer, but could only go so far & we couldn't burn it onto dvd?
do we need to have a certain software to burn the video from our camcord to a dvd?
whats the procedure to remove videos, we are able to remove our photos but not videos.
had camera over a year but not really used it alot.
  • 3 Answers
First be sure to have installed ImageMixer software that came with the camera. If you can't find the disc go here... http://esupport.sony.com/US/perl/swu-list.pl?mdl=DCRSR40&LOC=3 then select your operating system and then select imagemixer to download.
Step 1:
Place camera onto docking station, connect usb cable to computer, open camera door, turn on camera. Imagemixer should open automatically, if not open up imagemixer.
Transfer to Computer:
Select "Viewing and Editing", then select "handycam" tap, click on "▼" (arrow) facing down, then click "movies". Place a check mark on each movie you wish to move to the computer then click "Options" tab (lower left corner) and see where the movies will end up once you click "Import to computer".
Burn to DVD:
Be sure you have a DVD drive that can write to DVD's. Will have DVD R/RW on the face of the drive. Place a blank DVD into drive. Follow Step 1. Then click "One Touch DVD Burn" from the imagemixer menu. Follow any instructions on screen.
Or you can choose to use Windows Explorer and select the drive letter that is your camera's harddrive and move/copy/cut/paste files directly from this location to another.
Posted on Feb 17, 2009
SOURCE:
How can I transfer from tape in camera onto dvd
The best way to do this is to download the video onto a computer. Using video software (there is a lot available on the internet), edit your video and then send it to the DVD burner.
May 20, 2015 | Panasonic NV-GS330 Mini DV Camcorder
Tip
How to burn MTS, M2TS Videos to DVD on Windows 7?
You have .mts/m2ts videos on your HD camcorder and want to burn it to the DVD disk? This tutorial will show you how to burn MTS/M2TS Videos to DVD on Windows 7.
Before we go to step-by-step guide, we need to understand a bit of background knowledge about MTS/M2TS. According to Wikipedia, both MTS and M2TS are Sony high definition video file types, which are raw AVCHD videos recorded by AVCHD camcorders such as Sony HDR-SR1 camcorders. And m2ts files usually record onto 8cm mini DVDS or blue-ray DVDS, SD memory cards and Memory Stick, or record onto hard drive camcorder
So, We have to convert MTS/M2TS videos to DVD video formats (MPEG-2)before we burn it to DVD disk. Fortunately, there is Wondershare DVD Converter Ultimate can burn mts/m2ts video to DVD directly. Importing your MTS/M2TS videos into it and insert a blank DVD disk to DVD Rom, with 1 click, it will bring you a DVD that is playable on your home DVD player. Sounds great? Let's go to the step-by-step guide:
How to burn MTS/M2TS videos to DVD
Step1 Download Wondershare DVD Converter Ultimate, install it and running
Step2 loading videos
Load video files that you want to burn into DVD disk.
Step3 Making a DVD menu
You can select DVD menu template on the left bar. Set background image and music from you local hard disk. Then, click "Next" button
Name DVD label and set video quality and DVD disk type. Click "Start" button. Then, you can take cup of coffee and waiting until it done.
Step4 Burn DVD
That is it, 4 steps to burn videos to DVD and enjoy it on your home DVD player.
on Dec 29, 2009 | Cameras
How do I get Handycam DCR-DVD305 to recod videos onto a memory stick duo pro?
It is not possible to record the videos onto a Memory Stick Duo or Pro Duo, as this Camcorder DCRDVD305 does not support video recording onto the Memory Stick.
To record the videos you may use 8cm DVD-R/DVD-RW/DVD+RW.
Aug 23, 2010 | Sony Handycam DCR-DVD305 DVD Camcorder
Have a Sony DCD-DVD 101 camcorder that uses mini DVD's. How do I transfer from the mini DVD's onto a full size DVD? Don't have an instruction manual for my camcorder.
use software for dvd creations like nero, roxio or any other, or try using pro's like ulead dvd movie factory for import your mini dvd's in the computer and create a new full dvd with the software. First close sesions of your mini dvd's with the same camcorder. remember when close sesion the mini dvd can't recorder more video.
Feb 03, 2010 | Sony Video Cameras
I have a JVC GZ-MG37u Everio. It is a harddrive and its full. I need to get the videos from my camcorder onto a dvd that will work in any dvd player. Is it as easy as hoooking it up to my dvd player and...
hook it up to the front sockets on your dvd recorder ..select the front imput sockets on your dvd remote usually av3 press play on the camcorder and record on the dvd recorder.or hook it up to your pc to edit...
Sep 14, 2009 | JVC Everio GZ-MG130 Camcorder
Sony hi8 video cam trying to record onto cd's through Sony dvd pl
Yellow connection for camcorder is your video output, the other one is for audio. If your DVD recorder does not have composite video inputs you will have to get an adapter to attach to your yellow wire and the other end of adapter will go to your recorder. OK?
Sep 01, 2017 | Sony CCD-TRV238 Camcorder
Transfer my minidv camcorder film onto DVD
You need to download the movie to a computer and store it in a video file. Then you should be able to use a software program to burn it to a DVD. I use a TIVO for watching and burning my videos. You don't need a computer. You save the video by recording it to the TIVO's hard drive then after it is on the drive you DUB it to an empty DVD-R disc.
Jan 24, 2008 | Panasonic NV-GS17 Mini DV Digital...
HOW TO BURN MOVIE ONTO DVD WITH MY COMPUTER
i suggest you obtain the program cyberlink powerproducer onto your pc which is such a user friendly program to help you burn video from camcorder straight onto a dvd. you should be able to download from the internet.
May 12, 2007 | JVC Everio 25x/20GB Hard Disk Drive...
Sony Handycam  DCR-SR40 Camcorder Logo
350 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
