Question about Sony KP-53HS30 53" Rear Projection HDTV-Ready Television
I need some help with my sony 60" KP-53V15 TV outer rigid screen
Hello, I need some help with my sony 60" KP-53V15 TV. I recently got the tv and it had a crack on the outer rigid screen, to me it looks like a screen protector of sorts but was manufactured with the tv since it was built in to it. My son recently helped the crack along by pulling it and actually taking a piece off, needless to say the smooth screen is now exposed and i am looking at a whole in this plastic, i was thinking of removing the whole thing but not sure if i should do that as well as how i would go about doing that as i said it is built into the TV. So i am looking for a replacement outer rigid screen for the tv a.s.a.p i looked at the tvsreenprotectors or something like that website and i see they are selling a piece of plastic that covers the whole tv, I am not looking for that i could have used it before, i need to replace that piece that is rigid that is now cracked and broken, i can email a pictures so you can see what i mean. Thanks Jenn
  • co6bg May 11, 2010
    WRITE ME TO LET YOU KNOW.
    This is an important part, the name is "LENTICULAR".
    There is a provider in Texas, price$280.00 plus shipping$80.00
    co6bg@yahoo.com
  • 16 Answers
SOURCE: Red Screen
Sounds like the red color tube is goeing bad you wil hafto call in a tech to conferm it Sony is noted for tubes goeing bad, in the future leave sony alone
Posted on Sep 27, 2006
shaggyrat
  • 1224 Answers
SOURCE: CRACKED SCREEN
this might possess giving an arm and leg for new screen glass there might be a way to fix it and its a long shot
glass repair for auto mobiles that little filler they use for cracks is what i can suggest off hand
i hope this can be of use
Posted on May 07, 2008
  • 4234 Answers
SOURCE: Sony 57" projection TV - need replacement screen
The part number for the screen for the KP57WS500 does not match the one for the KDP-57WS550. The inner screen is still available for the KDP using part number 4-095-924-01 for $120.32
Hope this helps,
Dan
Posted on Mar 24, 2009
SOURCE: sony kp-53hs30
I was checking for one similar.The name is "LNTICULAR"
In Texas you can find a provider
Price $280.00 plus $80.00 S&H more o less.
Let me know to send the address
co6bg@yahoo.com
Posted on Apr 09, 2009
TOM2-TOM2
  • 110 Answers
SOURCE: cracked outer screen on projection tv
No it can't be repair only replaced.
Part# 4-090-943-01 $76.15
Freight charges may range from $45 - $150
Posted on Jun 10, 2009
Sir Myself Raj, My Sony Tv Projection Model is kp
Sir Myself Raj, My Sony Tv Projection Model is kp -es53me1. We are using this tv since 8 years. Now recently we are facing a problem with it. The problem is, The Picture quality is not good. Total screen & pictures are appearing as blur. Would you please give the solution for this?
Oct 10, 2013 | Televison & Video
I have a Sony KP-46S25. The screen is cracked. I
There are 2 screens for this set, a protective (outer) screen and a fresnel (inner) screen. Which one needs to be replaced?
Dan
Apr 08, 2010 | Sony KP-46S25 TV
Sony rear projection tv model KP-53V15 turns on, have sound but no picture, after a while, picture comes on, but later goes out again, picture keeps coming and going. Where do I start looking?
Adjust Screen Volts (G2) of all 3 picture tubes and screen volt control knobs are on focus block located under speaker grills at front of TV.
Remove speaker front grille of TV, look for focus block that has 6 control knobs, 3 knobs are for focus and 3 for screen volts, increase volts by turning little bit control knobs of screen volts and this will solve your problem.
Nov 02, 2009 | Sony Televison & Video
Cracked outer screen on projection tv
Jun 10, 2009 | Sony KP-46WT500 46" Rear Projection...
Wavy coloured lines on the screen all the time & hue
Tv repairman. the green picture tube has an intermittent short in it. This is an expensive fix.
Mar 30, 2009 | Sony KP-51WS500 51" Rear Projection...
I have a 60" SONY VIDEOSCOPE KP-53V15 the person that i received it from said that the picture sometimes turns pink tinted (the best wasy I can explain this) ... Where things on the screen should be white...
In the back of set you have a red green and blue gun.
two or three problems with sony on this.
sum times the green gun will go intermit.
by gentely taping the neck of green gun while set is on, and you see corection, you need to replace green gun.
in others we have found bad soldier in the HV section of the flyback.
and sumtimes its due to louse conectors going to the HD input in back of the set.
hope this is of help to you.
regards,
daniel.
Jan 15, 2009 | Televison & Video
Sony KP-46WT510 Rear Projector TN
Try to hard reset the TV that is Unplugg the device for 30 mins or an hour and then connect it back..It will help you essentially..!..Thank you..
Please post back on how things turned or for further assistance..!..
Regards!!..
Jul 23, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Outer screen
look for it @ local tv shop they may have one they are discontinued
Dec 24, 2007 | Sony KP-53HS30 53" Rear Projection...
Sony KP-51HW40 51 Screen Protector
this tv has three parts to screen , the most outer part is called CONTRAST screen part # 408195411 for the model you gave.This is available @ sony.com (parts&access) Please make sure this what you need and model is correct..Good luck
Nov 29, 2007 | Sony KP-51HW40 51" Rear Projection...
Sony KP-FX432M91 TV 10 blinks
my sony kp-fx432m91 has a 10 blinks problem. it has no pictures but has sound that goes off after 5 seconds please advice on what to do.
my email address is drbonnyb@yahoo.com
Oct 31, 2007 | Sony KP-FX532M91 TV
Sony KP-53HS30 53" Rear Projection HDTV-Ready Television Logo
48 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
