Question about Electrolux Vacuums
I have a Electrolux cannister Type Epic 6500 SR vacuum cleaner. The motor is making a whining noise on shutdown. What is the trick to opening it to get to the motor? THANKS, John
  • maajda Feb 09, 2009
    My question is, How do you do that?
    My question is How do I dissemble the casing
    Brigadier General:
  • 3,614 Answers
the best thing you can do, is to disassemble the casing of the unit,
Posted on Feb 09, 2009
  • 3 more comments
  • micromaster
    micromaster Feb 09, 2009
    see this illustration
  • micromaster
    you better check it and clean the vac.
  • micromaster
    Always be sure that your machine is unplugged from the electrical outlet before servicing.
    1. Remove the hose from the front cover and pull the electric cord out 2 or 3 feet.
    2. Remove the paper bag. Place the vacuum upside down on a work bench with some kind of pad underneath.
    3. Open the bag door and pull the end of the soft pastic rail cover out slightly (on both sides) to expose the rigid plastic side rails underneath.
    4. If you look directly at the side rails from the front you will see that the ‘T’ shaped part of each rail slides into a channel that locks the top and bottom halves of the machine together.
    5. The rails have notches or barbs on the last half inch or so which keep the rails from sliding out.
    6. You will need to get these notches away from the channel by sliding a narrow flat blade screw driver in between the top of the ‘T’ and the channel.
    7. Just tap it in and leave it there while you pull the rails out with a pair of needle nose pliers. Next, take a look at the bag door hinges.
    8. They have a square hole in the center through which a small tab from the bag compartment pokes through.
    9. Take a larger flat blade screwdriver and carefully pry the edge of the hinge away from the tab. This will release the bottom section (which is really on top now of course).
    10. If you remembered to pull out the two or three feet of cord before you started then you should now have enough slack so that you can lay the bottom section aside.
    NOTE:
    If you plan to do any electrical work be sure to mark the locations of the wire connections. Electrolux Service Centers are the only source of wiring diagrams and they don’t like to share.
  • micromaster
    PROCEDURE #2
    1. Around the side of the vacuum housing is a rubber strip.
    2. CAREFULLY
      remove this rubber strip and you will find the screws under it.
    3. Remove
      these screws and the entire top should come up.
    4. This rubber strip tears
      easily so be careful.
    5. Its also a bear to get put back in properly
  • micromaster
    FOR ANY FURTHER ASSISTANCE, JUST LET ME KNOW.
    remember always put a mark, when you are removing parts. esp. the wrings.
    Good luck
Epic 6500 Sr. Why does it keep turning on and off?
Electrolux Epic 6500 - Bag Full Indicator Bypass - YouTube
? 0:55
https://www.youtube.com/watch?v=YrMgoUAHcI4
Jun 23, 2013 - Uploaded by easilen
The rear pops off. There's a vac. ... Yeah, keep it. Undo Close ...Electrolux Epic 6500 - Bag Full Indicator ...
Questions and Answers for Electrolux Vacuum Unit
builtinvacuum.com/help/electrolux/qanda/main-central-unit.html
For Electrolux; Central Vacuum Attachment Kits and Hose and Tool Kits for Electrolux Attachment ... With a clean bag in, the unit starts up and immediately shuts off. If you hold ... From what I have read hear, it sounds like the motor is going. ... How can I fixmy electrolux epic 6500 SR vacuum? ..... It keeps cutting off and on.
Electrolux Epic 6500 SR Shuts off when power hose ...
Dec 28, 2015 | Electrolux Vacuums
Electrolux Epic Series 6500 SR. The machine is 15 yr. old & is working beautifully. However, when operating it emits a terrible stink, like cat *****. I've changed bags & filters but no ch
You need to have the vacuum cleaned out. If you are good with tools, just remove the motor and fans assembly, take the fans off and wash them. Brush ALL dirt out of the housing and reassemble. Your Electrolux dealer can do this but it isn't cheap. I used to be the service manager for my area. Since it isn't under warranty, you can have ANY reliable vacuum cleaner shop give a good cleanout. NEVER put anything into the cleaner to make it smell good. Electrolux cleaners get their power by having a straight through suction. The air goes through the motor. Adding smelly things can crystallize onto the motor and burn it out.
Jan 17, 2013 | Electrolux Epic 6500 Vacuum
I have a loud noise coming from the motor. Electrolux Epic 6500 sr Vacuum I have a loud noise coming from the motor. It smells like it is overheating. How do I open the canister to see the motor?
With the smell and the noise, it's likely the motor is shot. Unless it's seen heavy use, this is unusual for an Electrolux of this age. Or it could have been used to vacuum sheetrock dust, glass, or even liquids, possibly without your knowledge. Or "made to fit" bags were used, allowing more dust to get inside the canister and into the motor.
Unless other parts/accessories need replaced, it's much cheaper to have the motor replaced than to buy a new vacuum.
I recommend taking it to the nearest Aerus Electrolux store for a definite diagnosis (should be free), cleaning, and repair if needed. The technician will also let you know what other problems there are.
If you leave it for repairs, make sure you are given a copy of the work order for the vacuum that includes: type and model of vacuum, serial number, accessories left, your name and address, and an estimate. You'll need this to get your vacuum back. It's a good idea to also have this information written down at home.
Apr 17, 2011 | Electrolux Epic 6500 Vacuum
What charge for this service?
Actually there are no hidden screws on your Electrolux Epic model. This is the newer plastic body canister made by Aerus Electrolux. In order to open the vacuum cleaner to inspect the motor, first open the vacuum bag door and remove the vacuum bag. After the vacuum bag has been removed, keep the vacuum bag door open.
The two rubber furniture guards on both sides of the vacuum cleaner are actually what are holding the top housing and the bottom housing together. You'll need to slide both of these rubber furniture guards off in order to open the rest of the vacuum cleaner. They slide forward towards the vacuum bag housing which is why the door needs to be open.
In order to get these slides started, it's sometimes necessary to put a flat head screwdriver in between the back of the furniture guard and the start of the cord reel housing. Right after the rubber starts behind the word Electrolux. Fit a flat head screw driver in this gap, and it's sometimes easier to use a hammer, and hit the screw driver that's on the furniture guard facing the front of the vacuum.
With a little perseverance, you should be able to get the slide started, and when the slide starts to come out past the vacuum bag housing, simply grab the end of it with a pair of pliers, and pull the rest of it out of the vacuum.
Do this on both sides of the vacuum, and you'll be able to separate the two housings, and get access into the motor compartment.
If you have any problems, or would like me to take a few pictures of this being done, I'd be happy to do so. Please just rate my repair as helpful if you found this advice useful. I really do appreciate this.
Thank you,
Chris J.
GoVacuum
Apr 07, 2010 | Electrolux Epic 6500 Vacuum
I have the electrolux epic 6500 sr. when i
As hooton8 stated i have the electrolux epic 6500 sr. as well and when i attempt to vacuum i turn it on and it turns off after about 3 seconds. new bag nothing stuck in tube. I turned dial to the right all the way. Works when hose is not connected..hose is clear.
Dec 05, 2009 | Electrolux Epic 6500 Vacuum
What size/model bags do I need for my Electrolux Epic 6500 SR vacuum?
You need an Electrolux Cannister bag to fit pre 2001 Series cannisters. You can fin them at a VAC Service center or thru AERUS Electrolux. Buy only a 4 ply bag, nothing thinner.
Sep 08, 2009 | Electrolux Epic 6500 Vacuum
Repair my Electrolux 2100 cannister vacuum cleaner
On my 6500, I just disconnected the air line from the switch and now the vaccuum won't sense the bag pressure; I just have to check the bag myself now.
Jun 19, 2008 | Electrolux Epic 6500 Vacuum
Vacuums Logo
47 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
