Question about Maytag PAV2300 Top Load Washer
Washer spins freely but clothes remain very wet
Washer is a o loading model A612 se#047127PV
    Scholar:
  • 105 Answers
The two possibilities of which come to mind are, something in pump slowing the water outlet, belt loose or needing replacement. Sometimes an article gets over the barrell and sucked into the pump still allowing some water to pass by, but the belt needing to be replaced would prably be my first check. both need Power disconnect then cabinet panel pulled to view both the pump and belt
Posted on Feb 09, 2009
Frigidaire Gallery washer won't produce final high spin
Hey friend, thank you for your post!
I see that your Frigidaire washer, FWT449GFS2 is not entering the final high spin cycle. It is possible that you could have a defective motor or timer. Since it could be any one of these underlying issues I would recommend you having a professional come out to the home for the repair of your washer. -Matt
Aug 14, 2014 | Frigidaire Washing Machines
Lsw9750pw3 clothes still wet
If there is water remaining after the drain then the drain pump must be checked. Also check the TILT of the washer and must be inclined to the drain side.
If the clothes are wet then the SPIN RPM is insufficient or the program cycle time is not adequate. Please try with another cycle or check the motor, belt, capacitor as the RPM is low.
Jun 28, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
KENMORE FRONT LOAD WASHER MODEL # 417.44052400 WILL NOT SPIN. CLOTHES REMAIN SOAKING WET.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 03, 2011 | Washing Machines
Maytag Atlantis Clothes washer. Unit spins but clothes remain very wet. Where do I start to look for the problem???
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Sep 03, 2010 | Maytag Washing Machines
Clothes sopping wet at end of all cycles
Here is a tip that I wrote a bout front load washer spinning and draining problems...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 16, 2010 | Frigidaire ATF6000ES Front Load Washer
My washing machine drains but does not spin
Look for a motor belt that is worn out and make sure that the drum turns freely (machine off).
Aug 01, 2009 | Magic Chef CAV2000AWW Top Load Washer
Wet clothes
the reason the clothes are wet is the washer is not shifting to high spin,does the washer have a speed switch(normal wash spin,high wash spin)if its not the speed switch than the clutch is bad,how old is the washer?mike
Apr 19, 2009 | Kenmore 24032\24036 Top Load Washer
Neptune washer
If the water is draining out o.k. then either there is no signal from the water level pressure switch, no signal from the control board or a problem with the Spin windings.
Mar 11, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Cloths remained wet after spin cycle
This is a direct drive washer and the trans is not hard to replace. You want to make sure it is the trans giving you the problem. The trans is covered for 5 years under warranty parts only. Other problems could be a worn spin tube, brake or clutch. Did the washer loose its nuetral drain? If your washer is over 8 years old, maybe it's time for a new one. Otherwise, check out the link for the trans. http://www.repairclinic.com/0080.asp Catriver..post back.
Feb 27, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag PAV2300 Top Load Washer Logo
144 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
