Question about Sharp DT-400 Multimedia Projector
DT-400 Sharp, won't turn on. Power light on & Lamp light on
The unit was turned on more than 4 times after lamp life. I now have a new bulb, but cannot turn the unit on to reset. both the red power light is on and the red lamp light is on. Any ideas?
  • rheid Feb 09, 2009
    Grrrrrrrrrrr Didn't work.. Thanks for the try
    I replaced the lamp. It did turn on prior to replacement. It turned on once after replacement, but didn't restart. it restated with the problem I now have. I also put the old lamp back in, same problem
  • Sharp Master
  • 13,433 Answers
Unplug, hold down the power button and plug back in. see if that resets it.
Posted on Feb 09, 2009
  • 3 more comments
  • Ekse Feb 09, 2009
    Also try the suggestions offered on this page
    http://www.fixya.com/support/t396704-lam...
  • Ekse Feb 09, 2009
    checked the page I sent you yet?
  • Ekse Feb 09, 2009
    I think I may have missunderstood your problem, so the unit doesn't turn on at all. well there where a few possible solutions on the link I sent you earlyer have a look there and see if it helps.
    did you replace with the same model lamp?
    The supported lamp for this model is Sharp AN-K2LP.
    before you got the two red lights, did the projector turn on with the old lamp?
  • Ekse Feb 09, 2009
    heres the lamp timer reset process
    Lamp indicator Red on, possible faults:
    Birnt out lamp
    Lamp circuit failure.
    Would suggest to carefully replace the lamp again. got the same manual there?
    Check that ventalation is ok, noting is blocking and there is not too much dust.
    I have contacted a person that might have more information for you. I suspect to get a answer within 24hours.
  • Ekse Feb 11, 2009
    Hi again,
    Have you reinstalled the new lamp and checked that everything looks good?
    Do you still have the same problem, do the leds blink or are they both steady red?
    Thanks,
    Ekse.
The "lamp" light keeps blinking red. Does this
The lamp life becomes 0%, when used
for approximately 4,000 hours with "Eco
Mode" or when used for approximately
2,000 hours with "Standard Mode" (see
page 43).
When the remaining lamp life becomes
5% or less, " " (yellow) will be displayed
on the screen. When the percentage becomes
0%, " " will change to " " (red),
the lamp will automatically turn off and
then the projector will automatically enter
the standby mode. At this time, the
lamp indicator will illuminate in red.
If you try to turn on the projector a fourth
time without replacing the lamp, the projector
will not turn on.
If you require the manual to help with changing the bulb, send me an email to LBrown18062@hotmail.com Put SHARP PG-B10S in the subject line. I will send it to you right away. Lawrence Brown
Oct 26, 2011 | Sharp Notevision PG-B10S Multimedia...
I have a LG rear protection tv. I believe 52sz8d-is. When I plug it in the red power led light comes on and the bulb led flashes green but it won't Turn on
Tries change the tv projection lamp.Tv projection lamp ben in the tv like 1 1/2 or 2 years already,tv watches daily 4 or 5 hours every day.Yes.Than the tv projection lamp life are ended,now tv require a new tv projection lamp replacement.
Jun 05, 2011 | LG RU-52SZ51D 52" Rear Projection...
I have a Sharp DT400 projector. I replaced the lamp, and the unit powers on, and displays a picture during warm up but only for a few seconds. The lamp indicator and power lights go back to red and unit...
If you try to turn on the projector a fourth time without replacing the lamp, the projector will not turn on.
Press ON, INPUT, UNDO, left arrow, ENTER and right arrow on the projector in order, and then press ON.
The lamp 0000H is displayed on the lower left of the screen.
Mar 26, 2011 | Sharp DT-400 Multimedia Projector
My projector blew a bulb after installation what the problem generic bulb
Hello :
Check out the Power supply to the lamp . It must not be high . . Check if the voltages are correct to the lamp's unit and it's PCB [printed circuit board]. I recommend using a service manual .
Check for manual here please :
Sharp DT-100 Multimedia Projector manual .
Here is how to replace a projector's bulb correctly :
1:Make sure that your power switch is off and that the power cord is unplugged from the electrical socket.
It is also wise to unplug any other cables and label them in order to restore them in the right way once the lamp is replaced.
2:In order to see the lamp, remove the access handle on the outside cover. You may need to use a screwdriver.
3:Pull out the used lamp and clean the relevant parts using micro fiber products and not paper.
Please note that in some projectors a small inside filter should also be replaced.
4:Insert the new lamp into the projector carefully avoiding touching the glass of the lamp itself.
Touching the lamp will deposit skin oil that will likely damage any new lamp during use.
5:Reassemble the access panel, repluge the cables and power up the projector.
Things You'll Need:
new projector lamp
screwdriver
micro fiber duster
Warning:
avoid touching the bare projector lamp
I hope this will help .
rate please !
Mar 21, 2010 | Sharp DT-100 Multimedia Projector
Projector sharp dt100 not working!
It is possible the lamp has died even though you only got 800 hours. Rated Lamp life is always up to and never a surety of those actual hours in the brochure will be acahieved. If you would like a quote for a replacement lamp let me know as we ship internationally. Regards Kevin Andreassend http://www.iceav.co.nz +0064-9-4142348 iceavtech@gmail.com
Dec 22, 2008 | Sharp DT-100 Multimedia Projector
Lamp life over 2000. can't turn on again after replaced
sharp xv z9000u bulb reset
Hold down Enter + down arrow + right arrow and then power on.
Mar 13, 2008 | SharpVision XV-Z9000U Multimedia Projector
Correct voltage for lamp connection?
(Lamp may light and go out) suspect bad lamp part # 915P020010 2. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977020 3. (Lamp may light and go out) Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if low or missing check C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the Power PCB (part # 930B921002) 4. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977020 5. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977020 6. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on and does go to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Lamp Power PCB (ballast) part # 939P978010 7. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977020 .
Oct 06, 2007 | Mitsubishi WD-62725 62" Rear Projection...
Sharp DT-400 Multimedia Projector Logo
407 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
