Question about Intel Pentium III , 866 MHz ( 64ttt )
Intel Pentium II Processor Upgrade
Does anyone know the highest Processor Speed the Intel Pentium II went up too? I am currently using a IBM ThinkPad 380Z 233MHz, Windows XP Professional. The 380Z came with a Intel Pentium II 233MHz or a 300MHz Processor. Did Intel make a 1GHz Pentium II Processors?
    Problem Solver:
  • 6 Answers
No, this highest the P-II went to was either 400 or 450 Mhz. Upgrading a thinkpad CPU may be difficult. Considering prices on used laptops now, I wouldn't think it would be worthwhile, either.
Neil
Posted on Feb 09, 2009
What is the maximum limit of Processor my OPTIPLEX GX26- can support? i have currently 2.4ghz processor working and i want to now what is the max limit i can upgrade it to, can i place intel core duo?
Sorry, the GX260 can not support a intel core duo. The processor sockets do not match the motherboard.
Also, it can handle any pentium 4 processor that uses an 800MHz bus speed, because the highest bus speed that the GX260 motherboard supports is 533 MHz. The fastest processor available for the GX260 is 2.6 GHz.
Here are the tech specs:
http://support.dell.com/support/edocs/systems/opgx260/en/ug/specs.htm#1110653
Dec 29, 2010 | Dell OptiPlex GX260 PC Desktop
Will a 366 pentium II processor from a thinkpad 390E work in a thinkpad 390 with a 266 pentium II processor?
According to IBM's documentation the ThinkPad 390 will only officially support three processors:
Intel Pentium MMX Processor 233 MHz, L2 cache
Intel Pentium II Processor 233 MHz, L2 cache
Intel Pentium II Processor 266 MHz, L2 cache
Hope this helps
Apr 18, 2009 | Computers & Internet
IBM ThinkPad T41, Upgrade my Intel Centrino Processor
make sure that the socket supports your new max Intel.
Feb 04, 2009 | IBM ThinkPad R40 2722 Notebook
DELL OPTIPLEX GX150 Upgrade to Intel Pentium 4
Upgrading to a PIII to a PIV usually requires a new motherboard. Especially with that kind of speed you want to go to. The processor uses a different socket set and requires a different motherboard to absorb twice as much heat as you are putting out of the computer right now (the faster the processor, the more heat is released). Power supply should be around 400 watts as well because you will be needing a different cooling system as well.
Jan 18, 2009 | Dell OptiPlex GX150 PC Desktop
Upgrading IBM ThinkPad T20 Intel Pentium III to Intel Pentium 4
Patrick, I'm glad to see your enthusiasm to explore and expand on your computer knowledge. Unfortunately I have to be the first to let you know that in this case your ideas on upgrading your systems by simply changing the processors just won't work.
First of all a Pentium 4 (or Centrino, which is the mobile version) literally will not fit into any of the systems you mention. All CPUs are made in specific form factors to fit into different sockets. Most Pentium 4 processors were made for Socket 478 or 478B sockets, which mean they have 478 pins on a chip roughly an inch and a quarter square. The high number of pins allow more signals and data to be passed simultaneously to the motherboard, one way the speed of the CPU operations were increased. Pentium III and older Celerons were mainly socket 370 chips on a chip almost an inch and three quarters square. The lesser number of pins were aligned in six concentric rows with a blank central square. Pentium II and even older Celerons used Socket 7 and any of a half dozen other schemes and were often put on daughtercards to make them somewhat interchangeable. It would be like trying to put a square peg in a round hole.
They also make other forms, like socket 775, 939, and the newest AM2, all of which are pin-incompatible. In certain situations there are adapters that will let you put a newer CPU into an older socket but the specific upgrades you mention have no equivalent.
There are other engineering factors to be considered as well. Not all CPUs run on the same voltage. Many desktop motherboards have been designed that are adjustable either by selecting the operating speed with jumpers (old style) or by electrically sensing the optimum speed of the CPU. Then there are the memory and bus speeds. The CPU has to be able to interact with the memory so they must share a signal speed. This is the Front Side Bus. Older Pentium 4 CPUs were designed to use PC-133 memory but more powerful CPUs. certainly any in the 2.0GHz and up range, are designed for Double Data Rate (DDR), which is PC-2100 up to PC-3200. The pin configuration of the memory is different also to reflect and optimize the faster design. Of course there is now a DDR2 design and most recently DDR3. Core-Duos and Quads use the DDR2 and DDR3 type memory.
Another factor is heat. Faster CPUs run hotter. the system must be designed to accomodate and release the greater amount of heat generated, thus there are larger heatsinks and fans and more vent holes. Otherwise the CPU would start acting erratically and eventually burn out.
Things would be slightly different if you were talking AMD chips, as the socket 472 was much more versitile and could handle a wider range of CPUs and speed, from Duron to Sempron to Athlon XP, all because of the way AMD designed their chips. Of course, they too had to upgrade to surpass physical limitations, leading to the socket 754 and other newer designs.
Desktop machines are much more flexible to upgrade because of the space available and the fact they are designed with expansion slots. If you need a higher video card to run games, or more com ports to run extra printers or whatever, you can generally place a card in a slot to add the functionality. If you reach the design limits of a motherboard you can usually swap it out. Not so with laptops.
Laptops in particular are hard to upgrade because everything is integrated into or designed to plug into the motherboard, which has to fit the case properly like a jigsaw puzzle. This is not to say it is impossible to upgrade somewhat, but usually for laptops it means putting a faster CPU of the same form. Here is an example that is specifically for the IBM T40 laptop:
http://bsnugroho.com/t40upgrade.aspx
No, if you want to upgrade to Pentium 4 or Core Duo or Core Quad speed and performance, you will have to go out and buy a laptop.
Please do not let this discourage your enthusiasm. You share the spirit of the old school to push the limits that has made all of these computer evolutions possible. Consider formal training to round out your knowledge and to expose you to more within the field.
Dec 31, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
My borther has a 390x ibm thinkpad 2626 and he is looking for a upgraded processor
Current processor should be a Pentium III 450 MHz.
As far as I know, the standard RAM os 64 MB and maximum RAM is 512 MB. Even a memory upgrade will cost you around 80$.
I would honestly suggest to forget a processor upgrade because it will cost you a lot of money. Probably more than a new laptop.
Sorry...
Nov 26, 2008 | IBM ThinkPad 390X 2626 Notebook
IBM ThinkPad T20, Intel Pentium III 700MHz Upgrade to Pentium 4?
Max CPU for IBM T20, 21, 22 is Pentium III FCPGA2 1000MHz (1GHz). Max memory is 512MB (2 x 256MB PC100/100MHz). Max hard disc is 250GB ATA. Newest BIOS is from April 2004 at the homepage Lenovo.
Nov 06, 2008 | IBM ThinkPad T20 2647 Notebook
Wireless
Since you have the slot for the wireless card, you can purchase an internal card for the machine, try Price Watch or Ebay. On the processor, the G40 came out with Pentium 4 2.0ghz, 2.4ghz, 2.6ghz, and 3.0ghz. any of these will work as long as they were designed for IBM Thinkpad. I buy most of the processors for my shop off Ebay. I would check there. If you do buy from Ebay, be sure that the processor came from an IBM machine.
Jul 22, 2008 | IBM ThinkPad G40 Notebook
Ibm thinkpad 2647
Your limited with the T20 series, the biggest you can go is 1ghz. Try the Pentium M chip, make sure that it's the same mhz (frequency) that's in it now, the board frequency matches the processor frequency. (either a 100 mhz or 133 mhz, you can tell by what memory it uses PC100 or PC133)
Jun 09, 2008 | IBM ThinkPad T22 2647 Notebook
Intel Pentium III , 866 MHz ( 64ttt ) Logo
258 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
