Question about Mr. Coffee 072179228578 12 Cup Coffee Maker
Mr Coffee Maker FTX25 - coffee tastes bad
This coffee maker constantly brews coffee that tastes like mildew or old water. It could even be a plastic smell - but, I try to clean regularly. We've had it for a couple years and it's been not tasting right for awhile? Time to get a new one or am I doing something wrong?
  • Anonymous Mar 24, 2014
    Our coffee maker always smells musty inside. Is there any help?
  • Anonymous Mar 26, 2014
    water will be dripping through the part that is glued. What glue is safe to come in contact with water I will be drinking?
  • 131 Answers
Try running a 1/3 white vinigar -2/3 water mix into the brewer, let it brew, then run several pots of clear water through it. This should clean up any bad taste.
Posted on Feb 13, 2009
Coffee tastes bad in old and new coffee makers
Have you tried first just running distilled water through it, then again with spring water and then test with enough coffee for 1 cup to see how the cofee taste then. Also you may want to use distilled or spring water when making that one cup of cofee to test.
Dec 17, 2013 | Mr. Coffee Coffee Makers & Espresso...
Coffee tastes funny. does machine need to be cleaned?
Yes, in this type of machine, put a little bit of vinegar and water in top and run a couple times through machine, with of course filter basket on, not with filter or coffee, and brew a couple times. Use 25percent to water ratio, do this twice then do it again, twice with only mineral water. Then make a pot normal, and let me know how coffee taste now. Thanks Mr Bean Man
Jun 09, 2011 | Bunn VPR Coffee Maker
The light is on to clean it and I do not have an owner's manual. Can you please explain? How do I get the light to stop blinking?
Most coffee makers are cleaned by filling the reservoir with undiluted white vinegar (3 cups). (Do not add coffee.) Remove the water filtration disk if you use it before starting. Then start the brew cycle as if making a cup of coffee (including putting a paper filter or the permanent filter in the filter basket and close the lid). Put a decanter on the warming plate. After brewing, turn off the coffee maker and let stand for 30 minutes. Run another cup of vinegar through the coffee maker. Take the decanter filled with vinegar and discard the liquid (pour down the sink drain). Rinse the decanter. Fill the reservoir with clean water and put in a new paper filter (or clean the permanent filter and put it back). Again do not add coffee. Run a brew cycle to rinse the unit. Discard the water that is in the decanter after the brew cycle. Do a second clean water only brew cycle (with new empty paper filter or permanent filter after cleaning again). However, if you notice an odd taste, repeat the rinse cycle.
You can alternatively use the Mr. Coffee Coffee Maker Cleaner (mix as directed on that package). In either case, this removes mineral deposits (calcium from hard water). For soft water, the cleaning should be done every 80 brew cycles. If you have hard water, do this every 40 cycles.
The manual is available from www.mrcoffee.com/Product.aspx?pid=121 , if I have the correct product version. For some reason this site isn't coming up for me today. Check the manual to find out if there is any specific details for cleaning that aren't shared with other Mr. Coffee products.
I hope this helps.
Oct 29, 2010 | Mr. Coffee 12-Cup Programmable Coffeemaker
Coffee won't brew - lights turn on - clock works - clicks little.
2 years old I would pitch and buy a new one.
Cleaning generally won't help a machine that does not work.
Heating element has probably burned out.
(I am not talking about the heating pad for the carafe!)
For future reference for all the coffee drinkers out there:
Simple quick way to clean a drip coffee maker is use Vinegar.
Let it brew through the system as you would water.
Discard and run fresh water through the system to clear out the vinegar residue left behind. (Make SURE the system has cooled first before running the fresh water through!)
For those that have hard water and the coffee tastes funny.
Try a small pinch of salt in the filter basket ON top of the coffee grounds. This will soften the water and hopefully take the bitter taste away.
Guess it is possible large enough calcium deposits could block the hole in the holding tank to prevent the water from percolating to the filter basket. You may wish to check this before tossing. Last minute thought before pushing the post button.
Oct 04, 2009 | Mr. Coffee TFTX85 Coffee Maker
My coffee maker won't brew the coffee. Mr.Coffee GBX25
you tube is clogged pour in 2 cups of vinagar an brew this will eat away the calcium deposits. in your coffee maker if you water is hard where you live you may want to by distilled water or use some type of filter or water softener
Jun 23, 2009 | Mr. Coffee TFTX85 Coffee Maker
Mr Coffee stopped brewing
Sounds like there are a couple of problems -
First, are you certain that the coffee basket is clean? If the coffee basket has a valve on the bottom that allows you to remove the carafe to pour a cup of coffee, make sure the valve is clean. Being dirty would cause it to trickle coffee slowly into the carafe, and will hold coffee in the basket too long.
2nd, you may need to flush the water heating system as they can become corroded with precipitated solids from the water.
To do this, mix 1 part vinegar to 2 parts water in the carafe. Pour into the coffee maker and tell it to make coffee. Do this a couple of times, using a fresh mix of vinegar and water each time. Pour the used mixture down the drain.
When you feel it is clean, follow it up with a fresh pot of water. Then wash and rinse the carafe.
The coffee maker is now ready for it's next use.
Jan 30, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
Coffee tastes like plastic!
We have had our DCC-1200 for 3 months. The plastic taste occurs about every 3rd pot, and it does NOT get better. We've wasted over a pound of coffee. Cuisinart says we are the only people in the world with the problem. Well, I guess not...
Jan 16, 2009 | Cuisinart DCC-1200 Coffee Maker
Plastic Smell & Taste
Just because its made of plastic doesn't mean it should taste like plastic! The engineers made a mistake in design! Get your money back and don't risk taking in carcinogens!
Feb 25, 2008 | Mr. Coffee 072179228578 12 Cup Coffee...
Mr Coffee
If your coffee maker is under a year old, take it to a authorized service center for free repair or replacement.If its over a year then the complete heating element assembly must be replaced.However, this part is only available to authorized service centers and is not sold to consumers.
Nov 04, 2007 | Mr. Coffee 072179228578 12 Cup Coffee...
My bunn is too slow
Use the de-liming spring to clean the copper tube behind the spray head. Pour several pots of clear white vinegar through the unit to further remove lime and scale from the interior of your coffee maker. My Bunn is 24 years old, and the only replacement parts I've ever required are new carafes and the 4041 silicone washer repair kit.
Sep 15, 2007 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Mr. Coffee 072179228578 12 Cup Coffee Maker Logo
1,044 people viewed this question
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Henry  Thomas
Henry Thomas
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
