Question about Canon PC-1080F Plain Paper Laser Fax
Canon PC1080f copies coming out blank
We changed the toner cartridge and the copies still come out blank.
    Genius:
  • 2,120 Answers
Did you pull the plastic tape off of the cartridge?
Posted on Feb 15, 2009
I have a Canon NP 7130F which prints out only blank paper
check cartridge setting how-
check all spring on correct place
check ITR spring touch point
check printer to cartridge touch point
Apr 01, 2014 | Canon NP 7130 Black and White Copier
Copies come out blank.
several possibility of problem are:
- empty toner (you must check it)
- moist paper (solution = the copies which come out blank return to paper case, to use again. it is mean to use not moist paper)
- lifetime of the drum is over.
Jun 21, 2011 | Canon PC-1060 Black and White Copier
Paper tray light is on (the small copier on front). Copies come out blank. Just before this happen I tried to copy cardstock, it went through, the second time it would not. Now copies come out blank. New...
Check and clear any dust or peice of paper on the sensor. Also power off the printer and power on to clear the buffer memory may resolve your problem.
Revert back for more assistance.
Jan 29, 2010 | Canon imageCLASS MF6550 All-In-One Laser...
Canon pc1080f make dirty double image copys
Sounds like a cleaning blade streaking in the drum modual. If this is a used cartrige it might be full of toner and causing the toner to continue to rub against the drum.
Other problems might be the discharge cortron not working. Sometimes if they have a cortron wire they can arc, even in the blocks on the inside and outer board of the channels. If they can be dissasebled with care, they need to be scrubbed, cleaned and reassembled. Most times the entire channel needs to be replaced.
The wires and channels need to be cleaned. Special care needs to be attended to becuase they are hairlike thing wires, they break very easy.
The machine might have a discharge voltage that may not be working to nuturalize the field on the drum. This would retain old images on the drum putting the old image on the copy over and over.
Some machines have high voltages, called "Bias Voltage" which is monitored by a speical circit board, High Voltage Power Board.
These boards are cortron power supplies, sometimes they do fail causing these types of problems.
Also, a worn out fuser roll can retain old toner on the surface of it, and causing the old image to be put back on the next copy after it. The fuser presure roll can retain toner and it can put dirty images on the back of the copies.
For major indepth service repairs, contact this vendor for a service call by a service technition.
Oct 13, 2009 | Canon Office Equipment & Supplies
I changed my toner cartridge today and now it's not copying
Having 2 (defective?) cartridges that behave in exactly the same way seems too unlikely to me. So I have to ask the obvious question....did you pull the seal to release the toner? If it's an original there should be one, if it's remanufactured, there may or may not be one on it.
Jun 20, 2009 | Canon Office Equipment & Supplies
Replaced toner in a Canon image runner 2200 copy comes out blank
1) you do not dump toner into the drum! Juo dump it into the toner unit.
2) didi you after replacement put the blue toner handle (right from toner unit) into the left position?
May 27, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Blank vertical streaks
the toner cartridge is running low on toner and it needs to be replaced
Mar 26, 2009 | Canon imageCLASS D320 Digital Copier
Canon PC941 Copier: Wide white bar down middle of copies
Try replaceing the cartridge the toner has run out.
Any problems please get back to me.
Thank You
Mar 25, 2008 | Canon PC-940 Black and White Copier
Blank Copies
The Unit where you've put the toner cartridge could be to far from the drum. Make sure your developer unit (unit where you've put the cartridge in) is locked in place.
Mar 14, 2008 | Canon NP 7130 Black and White Copier
Image classD661 blank copy
If you just changed the toner cartridge, you probably forgot to remove the metal foil seal, from the side of the new toner cartridge.
Dec 07, 2007 | Canon imageCLASS D661 Digital Printer
Canon PC-1080F Plain Paper Laser Fax Logo
127 people viewed this question
old marine
old marine
