Question about Casio Parts Cash Register PC Desktop
CASIO CE 3700 HOW CAN I CHANGE THE RECEIPT HEADER?
I have the service and the instruction manual and still can't find how to change the header. Please help, Thanks.
  • 737 Answers
Hi.
The 3700 is a drum printing register, so it has no header since it can't print text. If there is one at the moment, then it will be cut into the stamp. to remove the stamp, lift the receipt paper roll, look in the back of the receipt side of the printer where the paper goes into the slot, there is a little handle. Pull it, and the stamp will slide out. take it to a stamp maker and they can cut your details into it.
Mark
Posted on Feb 10, 2009
Casio ce-3700 showing some percentages on it's reading.how take that out?
Which percentages? Which reading? You will need to be more specific. If it is part of the daily report, the user manual should be able to show you what they mean. If you need more information, the Casio CE-3700 manuals are here:
CE-3700 Operation/ programming manual:
http://the-checkout-tech.com/manuals/cashregisters/Casio_CE-3700_operators_and_programming_manual.html
CE-3700 Service (repair) manual: http://the-checkout-tech.com/manuals/cashregisters/Casio_CE-3700_and_CE-3750_service_manual.html
Sep 19, 2011 | Casio Parts Cash Register PC Desktop
I'm trying to reprogram the receipt header to show our change of address on a Casio-CE-4700. I have all the character codes I need, but I don't have the code to end a line and start a new one. ...
The codes are listed under file 32 worksheet, so look through your manual until you find the worksheet with file 32 listed, then you will see the line codes for header foot, commercial message etc.
If anyone needs more information, the Casio CE-4700 programming manual is here: http://the-checkout-tech.com/manuals/cashregisters/Casio_TK-2300_and_TK-2700_and_CE-4700_programming_manual.html
Aug 26, 2011 | Casio Parts Cash Register PC Desktop
We moved to a new location and I would like to change the address on the machine. How do I do that?
You can change the address on the receipt header by going into the Setup menu. The options will be different based on who your credit card processor is. Different companies use different programs. However, the basic menu structure is pretty similar. Go into the "Merchant" option and hit F2 for Next until you see the Header Line 2 value. Press F3 to Edit. Type the new address, using the ALPHA key to make letters. Space is 0 alpha alpha. When completed, press the green Enter key. Do the same for Header Line 3. Press F4 to exit. It will ask you if you want to save changes, choose "OK." Press the red X key until you get back to the main screen.
NOTE: Changing what prints on the receipt header will not change the information on your merchant account. You still need to call the merchant services provider and provide them with your new address.
Jul 20, 2011 | VeriFone VX570 Credit Card Terminal (Dual...
I have a casio CE3700 cash register. The machine locked up. I followed the normal procedures to resolve this, however when I turned the power back on from the socket the machine fails to turn on at all...
It sounds like there is a good reason for it locking up the first time then. Most commonly it is caused by a printer problem. Most Casio models will run the printer before they turn the display on, so if you can't hear the printer run at turn on, I'd start there. Look for paper jams. make sure the motor can turn freely. If the motor is okay, check the battery. You can experience weird problems if the battery has not been replaced on time. ------------------------------------------------------------------------------------
If anyone needs more information, the manuals are here:
Casio CE-3700 Service (repair) manual: http://the-checkout-tech.com/manuals/TOC/cashregisters/Casio/CE-3700%20and%20CE-3750%20service.TOC.pdf
Casio CE-3700 User and programming manual: http://the-checkout-tech.com/manuals/TOC/cashregisters/Casio/CE-3700%20operators%20and%20programming.TOC.pdf
Jun 10, 2011 | Casio Parts Cash Register PC Desktop
Casio ce-3700 error 04 on till please help
The machine is trying to complete an initialisation. It has probably not had its battery changed on time, or it may have been left off for too long. You need to check the internal rechargeable battery and replace if necessary. You can re-program it once the battery has been checked/ replaced.
C-tech has a CE-3700 manual here if you want to re-program it yourself: http://the-checkout-tech.com/manuals/cashregisters/Casio_CE-3700_operators_and_programming_manual.html
If you need information on servicing it, the service (repair) manual is here: http://the-checkout-tech.com/manuals/cashregisters/Casio_CE-3700_and_CE-3750_service_manual.html
Jan 21, 2011 | Casio Parts Cash Register PC Desktop
I have acquired a casio CE 3700 without a manual and need to change the company name that is printing on the receipts - please help
A very rare but great machine. You need to pull the stamp out from the back of the receipt side of the printer (there is a small black handle that you pull just under the paper entry). Then take the stamp to a stamp maker to get your name, tax number etc cut into a new stamp.
If anyone is looking for a Casio CE-3700 manual, there is a user and programming manual here: http://the-checkout-tech.com/manuals/cashregisters/Casio_CE-3700_operators_and_programming_manual.html
Oct 11, 2010 | Casio Parts Cash Register PC Desktop
I have casio ce-3700 cash register and i have problem E04 and noies come beep any one help me plz.
This is caused by incomplete initialisation. it means the program may be corrupt from being unplugged for too long, or you may have a bad battery inside the machine (change it every five years).
Firstly, try a flag clear to jump it back to REG mode:
Turn power off at wall Turn key to program position Hold down RECEIPT FEED button. Keep your finger on it. Turn power on at wall Wait 5 seconds, then let go of RECEIPT FEED Press SUBTOTAL
Turn key back to REG mode and try it. If the programming is corrupt, you will often see the decimal point in the wrong place.
If you want to re-program it, there is a manual for the CE-3700 here:
Aug 26, 2010 | Casio Parts Cash Register PC Desktop
I have a Casio CE-3700 cash register. How do I
tina -
I found the service manual here:
ftp://ftp.totalpos.co.nz/Oldmanuals/Casio-CE3700.pdf
It is New Zealand, and the file is a little over 3 MB. If you have a problem, contact me and I can email it to you.
It has a section on programming the CE-3700.
Michael
Jul 02, 2009 | Casio Parts Cash Register PC Desktop
Casio ce-3700 e01
Hi. You have turned the key before you finished what you were doing in another mode. A flag clear will jump you back to reg mode. Try this:
Turn power off at wall.
Turn key to program mode.
Hold RECEIPT FEED button down.
Turn power on at wall and let go of RECEIPT FEED after 5 seconds.
You should see 'FFFFFFF' on display
Press SUBTOTAL
Turn key back to reg mode and try it.
Mark
Sep 11, 2008 | Casio Parts Cash Register PC Desktop
Casio CE-3700 cash register MAC instructions
Hi. I would advise both of you to try a flag clear first to see if you have any program left.
Turn key to program. Power off at wall.
Hold RECEIPT FEED, and turn power on at wall.
Wait 10 seconds, then let go of RECEIPT FEED.
When you see 'FFFFFFFFF' press SUBTOTAL.
Turn key back to REG and try it.
If you still need help, let me know.
Mark
Apr 15, 2008 | Casio Parts Cash Register PC Desktop
Casio Parts Cash Register PC Desktop Logo
198 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
Gareth Cockram
Gareth Cockram
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
