Question about Ariston Technologies L63 Free-Standing Dishwasher
Ariston dishwasher i have an ariston built in dishwasher. It wont start washing cycle, and has 2 flashing lights from the left (total 4 lights)...can anyone help. i cant find the model number on the machine. The lights looking like sprinkiling water..i have filled the salt, and rise etc but still it wont come on please help
I have a brand new ariston ll-64 and the wash cycle won't start and two flashing lights
Posted on Feb 14, 2009
Empty out the dish trays, **** out as much water you can from the sump. Unplug the power, water supply and drain line. Pull unit out from bench, and place it face down on a old blanket, and soak up residue water as you do so. This will get you underneath the unit. Remove three screws and the cover plate, which exposes the pump units. remove the smaller pump unit from the sump, by removing it's one screw. Turn pump a 1/4" anti-clockwise and remove. Check O-ring seal is in place and in good condition. With a pair of pliers, remove the drain hose and clamp. Take a screw driver and rotate the impellor, check for **** etc. Blow out with compressed air if you can. Get a torch, and look into the back end of the internal pump unit, you will see a white plastic fan. Take a small screwdriver, and carefully rotate the fan to ensure pump is free to rotate. If not, remove and clean. Assemble the lot, vacuum out dust, dead mice etc. and close unit up. Re-connect hoses and power. Put dial into the "R" position, and turn on. It will beep a few time, then go to your selected cycle, and it should hopefully go, mine did.
Posted on Oct 29, 2012
I have an ariston ll64 and it is stopping a the last cycle button which is the picture of wine glasses. It then flashes with a green light.any ideas?
Error messages:
Your dishwasher is equipped with a safety system which is able to detect any operating anomalies. These anomalies are reported by one or two wash cycle indicator lights "E" flashing rapidly.
24432725-0h3kxpflbez5mdeb5anq3st4-3-0.jpgFlashing Led diode below button with the image of wine glasses means faulty thermistor NTC. So, could be faulty: thermistor NTC (defective or not positioned), wiring, control board.
Dado
May 16, 2014 | Ariston Technologies LL64WNA Built-in...
How to repair - no water is entering the dish waterr
Your dishwasher is equipped with a safety system which is able to detect any operating problems. These anomalies are reported by
one or two wash cycle indicator lights "E" will flash rapidly.
Any flashing combination of LED diodes (Intensive wash, Regular wash, Eco wash, Rapid wash, Soak and Crystal care) means different error code. Take a note of which lights are flashing?
If you have problem with fill water than following two LED should be flashing.24428775-0h3kxpflbez5mdeb5anq3st4-3-0.jpg
In this case could be:
  • Water valve disabled
  • Turbine disabled
  • Control board faulty
Dado
May 15, 2014 | Ariston Technologies LL65 Built-in...
I have an ariston built in dishwasher. It wont start washing cycle, and has 2 flashing lights from the left
Here is a dishwasher manual search engine, they will find the Beko user manual within minutes. Just send them a search request for your model.
Aug 11, 2012 | Dishwashers
Ariston LS 2020 taking more than two hours to go through cycle.
Ariston and on and on...lol
The water temp thermostat is to blame or the water is not heating.Basically what happens is the washer fills with cold water and starts to wash and heat at the same time.Once the water reaches a certain temperature it moves onto the next stage of the wash program.If the water is not heating or the thermostat is not working the programmer wont get the signal to move on.Hope this helps.
Apr 26, 2010 | Ariston Technologies Dishwashers
My dishwasher doesnt start
1) Ensure the dishwasher is turned off. 2) (may not apply) Turn the plastic blue lever located under the sink to the vertical position (this opens the valve, so water can go into the dishwasher) 3) Pour powder indo the dishwasher 4) Turn the dishwasher controller to the top position (the 12 o?clock position) ? this is the eco-setting. 5) Press the on/power button on the dishwasher, so that it now turned on (a light will display) 6) Move the dishwasher controller to the ?R? position (it?s on the very left), and leave it there a second or two. 7) Move the dishwasher controller back to the eco-setting (the 12 o?clock position
Apr 22, 2009 | Ariston Technologies LL64WNA Built-in...
DIshwasher wont start, flashes pre-wash and was lights
1) Ensure the dishwasher is turned off. 2) (may not apply) Turn the plastic blue lever located under the sink to the vertical position (this opens the valve, so water can go into the dishwasher) 3) Pour powder indo the dishwasher 4) Turn the dishwasher controller to the top position (the 12 o?clock position) ? this is the eco-setting. 5) Press the on/power button on the dishwasher, so that it now turned on (a light will display) 6) Move the dishwasher controller to the ?R? position (it?s on the very left), and leave it there a second or two. 7) Move the dishwasher controller back to the eco-setting (the 12 o?clock position).
Apr 19, 2009 | Ariston Technologies L63SNA Stainless...
Ariston Elixia LI68 Duo dishwasher will not start
Same problem , i fixed by opening the door compleet then cleaning the bottom of the door with a kitchen cleaning paper that may do it afther that disconect the power compleet whait 1 minut connect it al again and it should work , don't ask me why this cleaning action i just found it out
Feb 05, 2009 | Ariston Technologies Dishwashers
Ariston Dishwasher LI 675 DUO
4) Turn the dishwasher controller to the top position (the 12 o’clock position) – this is the eco-setting.
6) Move the dishwasher controller to the “R” position (it’s on the very left), and leave it there a second or two.
7) Move the dishwasher controller back to the eco-setting (the 12 o’clock position
Sep 16, 2008 | Ariston Technologies LI640S Dishwasher
L63 Salt light is flashing
goes for short time and 2 ljghts flash the red salt light wont go on
May 16, 2008 | Ariston Technologies L63 Free-Standing...
Hotpoint bf162 built-in dishwasher error codes
2+4 - Heating circuit not working. Possible causes - Heating element, connections, timer relay.
Maybe too late a response.
Ian
Feb 10, 2008 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Ariston Technologies L63 Free-Standing Dishwasher Logo
1,728 people viewed this question
Top Ariston Technologies Dishwashers Experts
Electro Med Services...
Renee Knafel-Bullock
Are you an Ariston Technologies Dishwasher Expert? Answer questions, earn points and help others
