Question about IBM ThinkPad T23 2647 Notebook
Function (fn) button does not work properly?
I have IBM laptop,if i press fn button it directly goes to hibernation mode,so i can not use other facility of function button.
  •  Neil Patterson
    Neil Patterson May 11, 2010
    Possible Bad BIOS or Need keyboard replaced. Any other symptoms or keys malfunctioning?
    Sergeant:
    Champion:
  • 275 Answers
Contact IBM as it seems some hardware issue in case if the keypad is done u have to change it so incase if the system is under warranty contact them
Posted on Feb 09, 2009
F buttons description
F1 - Security System
Press and hold the "Fn" key on the lower left-hand corner of your Toshiba keyboard.
Press the "F1" key to activate the security system.
Your laptop's screen will go blank so others can't see what you are working on or accessing.
Sponsored Links
Computer Repairs (Melb)
No Fix, No Fee. Same Day or Free. We Come To You - 1300 723 628
www.thepcdoctor.com.au/melbourne
Press any key or touch the touchpad to exit the security mode.
F2 - Power Save Mode
Press and hold the "Fn" key.
5
Press the "F2" key to activate the Power Save mode and make changes to how your laptop handles operating on battery or AC power.
6
Press "Fn" and the "F2" key again to exit the power save mode.
F3 - Standby Mode
7
8
Press the "F3" key to place your laptop in Standby mode.
The Standby dialog box will appear.
9
Verify you want to enter Standby mode. Press the power button on your Toshiba laptop to exit Standby mode.
F4 - Hibernation Mode
10
11
Press the "F4" key to activate the Hibernation mode and save whatever documents and files that are open to your hard drive.
12
Verify you want to enter Hibernation mode. Press the power button on your Toshiba laptop to exit Hibernation mode.
F5 - Active Display Device/F6 and F7 - Toshiba LCD Screen Brightness
13
14
Press the "F5" key to change your laptop's active display device from the laptop screen to an external monitor.
15
Click on the display configuration you want: displaying on both the laptop and external monitor; only on the laptop; only on the external monitor; or a specific screen resolution.
16
Press and hold "Fn" and "F5" to accept the new display settings. Press and hold "Fn" and "F5" again to return to your laptop's display only.
17
18
Press the "F6" key to decrease your laptop's screen brightness. Press the "F7" key to increase the brightness.
F8 - Wireless Connection/Bluetooth
19
20
Press the "F8" key to select the wireless Internet or Bluetooth connection you want to use.
21
Press and hold "Fn" and "F8" to make your selection. Release the keys to confirm your selection.
F9 - Touchpad Control
22
23
Press the "F9" key to enable your laptop's touchpad.
24
Press and hold "Fn" and "F9" again to disable the touchpad.
F10 and F11 - Numeric Keypad/F12 - Scroll Lock
25
26
Press the "F10" key to enable your Toshiba laptop's numeric keypad.
27
Press and hold "Fn" and "F11" to enable the cursor control keys on the numeric keypad.
28
Press and hold the "Fn" and "F10" or "F11" key to disable the numeric keypad or cursor control keys.
29
30
Press the "F12" key to lock your cursor on a specific line of text. Press and hold "Fn" and "F12" to turn scroll lock off.
hope this helps
Sep 25, 2012 | Toshiba Satellite A100-S8111TD Notebook
Blue function keys
Theres no function key lock, just the blue Fn button on the lower left corner of the keyboard.
If you cant get any of the function keys to work and the keyboard just thinks that you are pressing the standard button without pressing Fn, then this could be a fault with the contacts in the Fn key.
You might want to try
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-4YQKLQ
To help you troubleshoot your keyboard. I think you need to get a diagnostic utility running to be sure the key is faulty.
Oct 19, 2007 | IBM ThinkPad R31 2656 Notebook
Fn+F4
If you are using hibernation mode it causes all kinds of problems, not working, corrupting window files so you are forced to do a fresh install. The reason is windows needs to be properly shut down, other wise it will become unstable to the point you won't be able to access files. I strongly reommend to disable this function or at the very least make a backup recovery disc.
Apr 12, 2012 | Acer TravelMate Computers & Internet
I want to know how to use the function button
The function button, or FN button, is used just like the shift key or ctrl key. Hold the FN button down and press the key with the pre programmed function you desire to use. For instance, on an HP 1245 the function or short cut key to put the computer in sleep mode is FN+F5. The Keys with functions have that feature indicated by a symbol for the function in a squared circle. Most of these are your F keys at the very top row of the keyboard. Some are on the number pad keys.
Oct 27, 2011 | IBM ThinkPad R31 2656 Notebook
Hi, My IBM ThinkPad R51 type 1829 will not come out of hibernation/sleep mode. I have tried using all the FN and F keys, removing battery, etc. I recall this happening about a year ago and I had to...
This is called an ATX reset.
Remove the battery and the power cable.
Press and hold the power button for 30 seconds.
Put the battery back in and power cable.
Turn back on.
Apr 26, 2011 | IBM Computers & Internet
Computer goes in to sleep/ hibernate mode and I can not wake it up without shutting it off, and restarting
If we are talking "hibernate", then that's what the computer does - it saves the whole memory contents on the hard disk and shuts down. You then have to power it up and it boots like always on power up, but instead of loading the system the usual way, it reads the hibernation file and restores the state in which it was when hibernated.
"Sleep" or "standby" mode is different - the system stops execution of all the running programs, switches the processor into low-speed, low-power mode, executing only the basic functions of waiting for wake-up signal. Depending on machine and settings, it will be woken up by keyboard event, system event (like laptop battery running out - time to hibernate), network activity, or the power switch.
It should wake up when the Fn key on keyboard is pressed, the lid is lfted up (if it was closed of course), or when you momentarily press the power button. If it does not, then something is wrong with your ACPI/Power Management setup, and/or there are some drivers missing or corrupt. You can try going to IBM/Lenovo website and looking for updated system drivers for your model.
Dec 03, 2009 | IBM ThinkPad T43 Notebook
I need to activate my bluetooth in my IBM r52 model,how do i do
Press Fn+F5 to open the Wireless Radio Control and turn on the Integrated Bluetooth features.
Whenever you start the computer or resume operation after it has been in standby or hibernation mode, you must turn on the Bluetooth features.
Feb 23, 2009 | IBM ThinkPad R52 Notebook
Hibernate
When Windows opens then -
Open Control Panel - then click on Power Options - Click on Hibernate tab and uncheck Enable Hibernate - Click OK
Feb 13, 2009 | IBM ThinkPad T23 2647 Notebook
I have IBM R40 Laptop
Try pressing the power button next time. That will help you to turn on from an Hibernation.
Alternative you can disable this feature (not recommended for laptops)
  1. Open Control Panel.
    • On the Windows XP default Start menu, click Control Panel.
    • On the Windows XP classic Start menu, point to Settings, and then click Control Panel.
  2. In Control Panel, open Power Options.
    • If the computer is in Category View, click Performance and Maintenance, and then click Power Options.
    • If the computer is in Classic View, double-click the Power Options icon.
  3. In the Power Options Properties dialog box, click the Hibernate tab.
  4. On the Hibernate tab, clear the Enable hibernatation check box, click Apply, and then click OK.
Jan 10, 2009 | IBM ThinkPad R40 2897 Notebook
Restart from hibernation
go to the system tray and click once on the "Safely Remove Hardware Icon"
click on your dvd/cdrw to stop it. when it says it's safe, go ahead and remove the drive.
reboot
reinstall the drive and windows should automatically pick it up
also. go to --
Start -> Control Panel -> Power Options ->
Under Power Schemes set all the options under the ac power header to NEVER
unless you want it to hibernate, go to the hibernation tab and uncheck the enable hibernation box
go to the Advanced tab and under power buttons --
Close Lid = StandBy
Press Power Button = Shut Off
Press Sleep Button = StandBy
Oh and while you are there make sure the
always show icon in taskbar is checked, so you can keep an eye on your power
click apply and click ok and reboot
let me know if this works for ya
Dec 26, 2008 | IBM ThinkPad R40 2722 Notebook
IBM ThinkPad T23 2647 Notebook Logo
134 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
