Question about Brother MFC-8460N All-In-One Printer
Can send but can't receive faxes on MFC-8460N
My fax line is vonage
fax machine indicates a fax is being received and then goes to sleep mode
  • perse_9 Feb 10, 2009
    So I do I resolve the issue and still use a digital phone line
    Genius:
  • 2,120 Answers
Fax machines are ANALOG devices and will not work reliably on DIGITAL phone lines.
Posted on Feb 10, 2009
  • Leroy Elliott
    Leroy Elliott Feb 10, 2009
    Well, there is no workaround. You would have to have an analog phone line installed to use your fax.
    The millions of fax machines out there are the only reason that Digital hasn't completely taken over. That day is rapidly approaching, then i'll be out of a job.
    An alternative is to use your scanner for scan-to-email.
  • meir
    meir Jul 14, 2014
    can notrecieve fax mfc 7360
How do i remove the sleep mode so i can recieve faxes?
The Brother machines go into sleep mode to save power, in the machine setup you select how long to wait before going to sleep. When all is working, it will wake up as soon as a fax is received, so you really don't need to change it. If you use menu to reports and select the user settings to print, it will tell you where the setting is at.
Nov 02, 2009 | Brother MFC-8460N All-In-One Printer
Trying to have a fax sent to me and they tell me that the line is busy... They keep trying to send it with no luck... I can call out on the machine but it won't receive calls at all...
Call your fax machine with your cellphone to see if the fax machine responds.
The other party is probably calling a wrong number (your main voice line).
Oct 07, 2009 | Brother MFC-8460N Laser Printer
Printing blank pages when receiving fax
Ask if the ones sending are sending legal size, it may be using 2 sheets to get all from a legal size document.
Jul 29, 2009 | Brother MFC-8460N All-In-One Printer
Fax machine sleep mode
have you tried to unplug the machine from the wall and then plug it back in this reboots the machine
Dec 23, 2008 | Brother IntelliFAX 2800 Laser Fax
Able to receive fax but cant send
sleep mode is just a status of the machine when it is in idle mode.you cannot turn this off however you can delay the time before the unit goes into a sleep mode.it has nothing to do when you are sending out faxes.so here are a few things you need to check when sending a fax (1)dial tone by pressing hook/hold button (2) insert the doc into the adf, make sure it will change to "enter fax # and start,or copy press copy (3) dial the number (4) wait for fax tones of the receiving unit before you press start. now if you can hear an operator on the line,that has to be verified with your phone company since brother machine does not restrict incoming and outgoing faxes UNLESS that is restricted from your phone line.
Nov 18, 2008 | Brother IntelliFax-2820 Laser Fax
Can't Send or Receive Faxes from MFC-7820 N
You may not need a separate fax line from Vonage. If you don't need a dedicated fax line, you can try changing the "Bandwidth Saver" settings on your Vonage voice line from your account on the Vonage website. Perform the following:
1. Login to your Vonage account online and click the "Features" tab.
2. Scroll down to the "Bandwidth Saver" link and click on the "Configure" button.
3. You will see a scrollbar with 3 settings: 30kbps, 50kbps and 90kbps
NOTE: My "Saver" was set to 90kbps (Highest Sound Quality) by default.
4. Click on 30kbps (Normal) and click "Submit".
5. Wait about an hour before testing as it could take that long for the change to take effect.
6. Send a test fax to the HP fax test service at 1-888-hpfaxme (1-888-473-2963).
NOTE: This is a GREAT service provided by HP. If your fax goes through correctly, you will receive a return fax within five minutes.
We upgraded to Verizon FiOS and never thought the increased upload speed (4mbps) would present an issue sending faxes. WRONG. We never had fax issues with DSL, Comcast or even Broadstripe VOIP service but for some reason Vonage + FiOS = no fax. That is until we set our Vonage VOIP sound quality to "Normal". Our phone voice quality has been much more reliable since throttling back. This sentiment has also been shared by other Vonage users who have experienced echoing and noise when utilizing the higher quality settings.
Your phone coversations may not have FM quality sound but they will have AM quality and usually that is just fine.
If your fax machine has a Telephone Answering Device (TAD) setting, you can share your voice line with your fax machine and be able to receive faxes and voice messages. Hopefully this will work for you.
Dave Grannas
Nov 04, 2008 | Brother MFC-7820N Printer
I cannot recieve faxes
There seems to be an internal fault, either with the receive relay or another board component. Can you receive a telephone call? If so, I would say it's a component failure and should have a repair shop look at it. With this kind of problem, the repair facility will use bench testing equipment to prove it. then exchange the faulty board. If it's not under warranty, it will be expensive.
Aug 18, 2008 | Brother MFC-8220 Fax
Trouble faxing and receiving fax from "Brother 575".Can you help me with my fax machine? I have vonage, and I still can't receive any faxes. The machine makes copies, and receives calls,send faxes, but not...
Try changing the "Bandwidth Saver" settings on your Vonage account from the Vonage website. Perform the following:
Dave Grannas
Jun 01, 2008 | Brother FAX-575 Plain Paper Thermal
Vonage vs Brither 4100
Have you called your own fax line and just listened to the fax hand shake? might sound simple but I have called fax lines before and it just rang, or it was busy or static, if your not getting a clear fax hand shake, then it is the phone line, if there is no answer you may have turned your fax to manual receive mode, If you don't know how it should sound call a friends business fax line and listen to it. I have actually gone out to businesses that reported send or receive problems just to call the line and listen to a disconnect message, that would make it difficult to fax.
Jan 13, 2008 | Brother IntelliFax-4100e Fax
Brother MFC-8460N All-In-One Printer Logo
542 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
