I'd like to replace the CD-ROM drive in my i-series Thinkpad with a DVD drive, ideally a TEAC (which is apparently what IBM uses in this line.) Does anyone know of a good source for such an item where the prices might be lower than what IBM wants for this drive?
Hmmm . . . looks like buying from anyone other than IBM might be more of a gamble than it's really worth -- certainly an external unit is going to be considerably more expensive than getting the internal drive from IBM (only around $200.)
Thanks for all the information, Paul!!
Was this solution helpful? Show your Appreciation by rating it:
Show your appreciation by commenting on Cheap source for OEM DVD drives?:
Solution #2
posted on Aug 01, 2007
M0nica L - usenet poster
Rank: Apprentice Rating: 0%, 0 votes
The BIOS might not let you boot from the wrong brand of DVD drive, so be SURE you know what brand IBM uses before you get the drive from a different source. Operating-system-level support shouldn't be a problem. BIOS-level support is a different story.
If your Thinkpad CD drive has a special bezel that matches the color, texture, and profile of the computer's case, expect to replace this with the generic bezel from the new DVD drive. Even drives from the same manufacturer (e.g. TEAC's CD-224E and DV-28E) have incompatible bezels.
Note also that some portable computer manufacturers obtain their CD and DVD drives from different sources. Sony, for example, seems to use TEAC CD- ROM drives and Toshiba DVD-ROM drives.
I learned everything the hard way and have built up a great collection of incompatible slim CD/DVD drives, mounting brackets, screws, bezels, and external cases!
The best source of low-priced slim DVD drives is a computer store that can order repair parts. You could also research inexpensive modular drives made for discontinued computers (e.g. VST's Macintosh PowerBook G3 expansion bay DVD-ROM drive). As a last resort, research inexpensive external portable DVD drives (Addonics brand, for example). Doubtlessly you will find something with the right brand of drive inside.
-- Posted via CNET Help.com #
