Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
Printer does absolutely nothing
My printer came out of the box, the set up went well but when we pressed the scan button or any other function for the fact nothing happens and I have tried calling the customer service tech assist line and all you get is a busy signal. Please someone help I dont know what to do with this so called miracle printer from Kodak that I assumed would be reliable if you go by the brand name that is. I have installed the software and nothing turned it on and off and all there is a noisy movement from inside printer and nothing prints
    Brigadier General:
  • 8,619 Answers
Hi!
Try pluging the usb cable to a diffrent USB port.
Is it showing any error message?
Have you installed the print cartridges correctly?
Which OS(xp or vista or mac) are you using?
Please rate the solution and ask for any further assistance.
Thanks
Rylee
Posted on Feb 09, 2009
Reset mp390
1. Press ON, ADDITIONAL FUNCTIONS, SCAN, COPY, SCAN
This will enter into Service Mode
2. Select Test Mode, last selection, use + button then press SET
3. Select #8 Printer Test, use + button then press SET
Printer will start and stop
4. LCD will shown 8-2, press + to move to 8-3, press SET
5. LCD will shown EEPROM CLEAR
Select Ink Count option 0 and press SET
6. Press STOP/RESET
7. Press ON
Dec 31, 2013 | Office Equipment & Supplies
Hello am using sharp ar165 m copier machine .and am installing my pc also but scaner is not working please help me.
How are you doing? In order for scanner to work in all multi-functional printers, you must install all functions. While installing printer Sharp Ar165m, it will ask you if you need to install scanner and you must select that box otherwise it will install printer alone. Also there is an option where you are to configure the button keys on scanner function, please configure the buttons while installing. This will allow you to press scanner key on the copier to start scanning without necessarily selecting from the computer otherwise --- will appear and nothing happens. So insert the software CD and remember to select scanning option.
Dec 15, 2010 | Sharp Office Equipment & Supplies
My black ink went empty about 3 weeks ago. I replaced it today with a new cartilage but it still won't print. I performed a cleaning from the printer maintenance tab and still nothing. What do I need to do...
This reset procedure might help you.
1. Turn on the printer
2. Press the MENU key
3.
Press SCAN button
4.
Press the COPY button
5. Press the SCAN button then wait until it enters the service mode.
6.
Select NVRAM ACCESS further OK
7.
Select SET ABS-M LEVEL and set value equal to zero
8.
Select SET ABS-R LEVEL (if any) and is set to zero.
9.
Turn off the printer
Aug 09, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Konica Minolta C652 Fax/Scan Button and User Box Button
The hard drive is not turned on. enter service mode ( utility, meter count, details, stop, 0, 0, stop, 0, 1 - this should be pressed in exact succession) then go to system 2 and look for a place where it asks you about all the installed perifferals. Turn the hard drive setting on.
Jul 14, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
When i press the start scan button it says 'options not set'
To use the scan features, the HP All-in-One and computer must be connected and turned on. The HP Photosmart Software must also be installed and running on your computer prior to scanning. To verify that the HP Photosmart Software is running on a Windows computer, look for the HP Digital Imaging Monitor icon in the system tray at the lower right side of the screen, near the time.
NOTE: Closing the HP Digital Imaging Monitor icon in the Windows system tray can cause the HP All-in-One to lose some of its scan functionality. If this happens, you can restore full functionality by restarting your computer or by starting the HP Photosmart Software
Dec 14, 2009 | HP OfficeJet G55 All-In-One InkJet Printer
My canon printer wont scan my picture to my hp computer
You will need to have installed the software that comes with your printer for scanning and the other functions before these buttons will work.
There may also be settings in the software which dictate what the buttons will do that need to be defined.
I'd check your CD and see if there's anything you didn't bother to install originally and then see if that fixes the problem.
Mar 12, 2009 | Canon Office Equipment & Supplies
Blue screen when the tv is on
The TV or converter box might have lost the cofiguration for the converter box
Feb 02, 2009 | Televison & Video
Printer maintenance is in progress. Scan after it is complete. Code:2,114,0
The solution is very simple. No need to change your USB cables or press every button like a piano to kill the printer. All you have to do is this:
1. Press and hold the "Stop/Reset" button for 5 seconds.
Jul 12, 2008 | Office Equipment & Supplies
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
90 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
