Question about DeVilbiss Pulmo Aide Compressor Nebulizer
Am i hooking this nebulizer up right
I haven't use this nebulizer in a long time I thought it threw off sream Please help thanks
First when you turn on the neb is it running and putting out air
second is the circuit or medicine cup you have new?
if not replace if yes connect tubing to spout on neb, connect other end to bottom of cup open up and put medication inside ( you can do a trial run with water just to make sure its puffing before you waste meds.
put on mputhpiece turn on should puff out like steam if not you compressor may not be putting out enough air if over 5 years old insurance should help purchace a new one with a dr rx if not call company you got it from they usually have a 5 year warranty on them.
Hope this helps
Posted on Feb 10, 2009
Omron vibrating mesh nebulizer quit working
You must be having trouble with the battery. Also please keep the nebulizer properly cleaned as instructed on the pack. Check the connection properly or replace the batteries if needed. Also check out for more information about Omron Nebulizer on the web. It would help you a lot.
Aug 06, 2012 | Omron Health & Beauty
My ne u22v is not making mist
You should check if the battery is working fine. I don;t think Omron U2 nebulizer can have any other problem as it works really good for me. Also it is important to clean the Nebulizer properly and please check out the manual for more info. which you would have received while purchasing the Nebulizer.
Aug 06, 2012 | Omron Ne U22V Microair Vibrating Mesh...
We got this omron nebulizer but when we used it we noticed that the air following through the nebuliser is very slow or low ....the time taken for the medicine to finish is taking nearly 25 minutes. This...
Most nebulizers are slow the whole idea with a breathing issue is to slow the system down and let the medication work, can you try turning on TV or colour with her, making it something you do together may make her more comfortable and sit longer, story time, do a chapter book they take longer and you always have to come back for the next chapter. I do not know how old she is but the little house on the prairie books have dozens of chapters and there are at least 10 books in the series! hope it helps.
Nov 07, 2017 | Omron Compair Compressor Nebulizer System...
Timer isn't working
YOU CAN LOOK THREW THE LITTLE WINDOW TO SEE THE GEARS TURNING ON THE CLOCK .. IF NOT ..Intermatic Timer Motor WG1573 / WG1573-5 clock POOL FIX ON EBAY
TO INSTALL THIS MOTOR REMOVE SCREW ON LEFT AND JUST BACK SCREW ON RIGHT A FEW TURNS, TIMER WILL ROCK UP OUT OF BASE THIS WAY . UN-HOOK WIRES ONE AT A TIME AND INSTALL WIRES FROM NEW MOTOR ONE AT A TIME.. THESE TWO WHITE WIRES GO TO LINE 1 AND 2 THESE ARE THE WIRES THAT GO TO THE 220 VOLT BREAKER ... NEED MORE HELP JUST GIVE ME A BUZZ. .. VOTE PLEASE THANKS... JAY
Apr 10, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Where is filter?
It is located on the back of the penquin to the right of the on/off switch. It looks like a black knob. Simply pull it out.
Nov 11, 2009 | Penguin Nebulizer Neb U Tyke Ic Nebulizer...
Respironics Side Stream Nebulizer tubing with condensation
try this...
let the compressor run with only the tubing attached for a few minutes. The warm air
from the compressor will dry the moisture or condensation in the tubing. Use a damp
cloth to wipe the exterior of the tubing.
hope this helps..good luck...
May 02, 2009 | Respironics HS860 Sidestream Reusable...
Step by step hookup
Hi Again
Thank you for all the fast responding e-mails That was very nice of you
But, I still don't have an answer to my problem Now please keep in mind that this is a unit to help me in an emergency to BREATHE AGAIN
I think that for the price it cost I should be able to use it more than once or at least get some help with a simple question Oh well I just thankful that I wasn't having an attack and trying to use this Please keep in mind I am over 70 and live alone All the so called devices that are suppose to keep the oldtimers alive are killing us
Thanks again
Feb 10, 2009 | DeVilbiss Pulmo Aide Compressor Nebulizer
I threw the manual away for the krups FME 2-11 coffee maker and can't remember how to set the time on the clock to the time of day. Can someone please help? Thank you/ Ron
You can get the instructions here.
Dec 16, 2008 | Microwave Ovens
DeVilbiss Pulmo Aide Compressor Nebulizer Logo
383 people viewed this question
Top DeVilbiss Health & Beauty Experts
syspro
Tom Chichester
Are you a DeVilbiss Health and Beauty Expert? Answer questions, earn points and help others
