Question about Sony KP-51WS500 51" Rear Projection Television
Picture alignment is off and the bottom and top are cut off
I think I may have knocked the picture tubes out of alignment.  Would I be able to open up the TV and align them myself?
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    let me know problem with little detail as I assume that you have 3 color picture (out of converge)
    Scholar:
  • 150 Answers
Hi, if you haven`t opened the covers yet your tubes are fine .. you can`t move them without removing the rear covers, if you have a 3d look ie; colors are seperated your convergence circuit has failed, stk`s will have to be replaced which requires soldering equipment, video-tek
Posted on Feb 10, 2009
Sanyo lcd tv align picture
need codes for sanyo and sony trintron
Jul 28, 2013 | Sanyo Used Original DP37649 Remote Control
I got a Zenith Z56DC1D the bulb was replaced and its clean. I have blurry picture and it seems out of alignment there is a large black stripe on bottom and the top of the picture is cut off. How do I fix...
Without seeing a photo it sounds like the picture is letterbox with top and bottom black areas---if not that it sounds like a possible issue with the optical light engine the set uses to project the image on to the screen----most of this is not customer repairable.
Dec 04, 2012 | Zenith Z56DC1D 56" Television
Screen is out of alignment. The picture cuts off a portion of the bottom and top of the screen.
let me give you a photo and you tell me if your set looks anything like it: let me know what you think.fdd8919.jpg
Dec 13, 2009 | Mitsubishi WS-48315 48" Rear Projection...
Thin red line appears on screen. Purchased Nov. 2007
the minute parts near the picture tube might have misaligned ,,,,,, you need to align those parts .... contact a good tv mechanic .... he will use a magnetic type material and align every minute parts correctly near the picture tube, the red line wont appear again
Mar 05, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
That guy explains the different adjustments on a T.V.
I'm not sure if you want the colors aligned of the general heightwidth adjustment.
http://www.youtube.com/watch?v=nz5BBic44hk
Be sure to watch this also,shows how to safely discharge your set, it's a safety precaution that can't be overlooked.
http://www.youtube.com/watch?v=WX43sT0hMJk
Feb 21, 2009 | Sanyo DS20425 20" TV
Picture is concave on top and bottom. With ed and green ghosts.Worked fine, turn set off and on about 15 minutes later and picture was as described. Help!
The convergence chips in your tv have gone out. They control the three picture tubes and align them so that they create one picture on your screen. I recomend having a qualified technican replace them and realign you convergence. Thanks.
Apr 02, 2008 | Akai PTH5498 54" Rear Projection...
AKAI CFT2726 picture sides cut off.
If it is a picture tube type TV not a plasma or lcd try degausing the picture tube. I think Radio Shack carries degausers or find the plans for one on the net.
Feb 22, 2008 | Televison & Video
Convergence
Color tubes are OK. Do not adjust. The issue at hand is called
convergence alignment.The repair involves-------
1)Pull chassis
2)Replace convergence IC's
3)Recheck alignment
work should be done by a skilled technician........T.
Oct 24, 2007 | Philips 60PP9202 60" Rear Projection...
Convergence issue resolved but concave picture remains
Set will need new convergence IC's.Requires chassis pull===technical & mechanical skill mandatory.After repair,re-aligment necessary.
Sep 26, 2007 | Philips 55PW9363 55" Rear Projection...
Picture cut off
No adjustment needed on these LCD projection. Your problem is in your setup menu. Your default is now is set ZOOM. That is why the bottom of the picture is cutting off. Go to Menu, setup and screen size or something close to that.
Best regards
Circuitcity
Jul 27, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Sony KP-51WS500 51" Rear Projection Television Logo
61 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
