Question about Philips Magnavox 27MS343S 27" TV
Single horizontal line
Hi i have a magnavox television console and it only displays a single horizontal line on the screen there is noise sound but it only displays a single horizontal line what can i do
  • 4 Answers
This problem is field collapse usually causd either by the field oscillator or field output stage to advise you further i would need to look at the circuit diagram
Posted on Feb 10, 2009
My Magnavox plasma screen tv, model number: 42MF237S/37 makes a clicking sound when I try to turn it on. No sounds, no picture, just the clicking noise. Things I have tried so far: 1) Turning the TV off...
You either have a cold solder joint in your horizontal deflection circuits or your or in your horizontal output circuit. please be careful due to the fly-back transformer still holds power even unplugged until you discharge it.( ground it out). Hope this helps.
Jan 03, 2010 | Philips Magnavox 27MS343S 27" TV
Magnavox 32MF337B/27 power supply works and like another writer when power is turned on the audio works the channels change and you can tell that all remote and on set keys work, but no picture except an...
hi i have a 50" magnavox that has a problem, i was looking at several websites and i find out the dirfferent posibilities.
in your case i have 2 posibble answers.
1) negative image
tv turns on and shots down in 2sec
flashing pixels on screen
dark image
has sound but no video
screen goes black and then return to normal picture
vertical color lines on screen no video
vertical color lines with video
vertical bars on screen
horizontal lines on the image
picture goes red after while
2) just left part of screen working
just right part of the screen is working
vertical and horizontal lines on screen
part of screen not working
some functions not working
no video but has sound
functions not working at all
TErry HerreRA
Oct 04, 2009 | Philips Magnavox 42MF521D/37 Television
Magnavox ts2543 with a single horizontal line
Most Probably the Vertical Output IC has failed. If it has, it also could cause resistors that supplt the +/- Voltages to the IC to fail as well.
Hope this helps,
Jun 20, 2009 | Televison & Video
White horizontal lines in my 27 in Phillips Magnnavox tv
I have seen this on mine. Check the cable going into your TV and make sure it is good. The ground portion of the cable could not be making a good connection.
Jan 17, 2009 | Philips Magnavox 27MS343S 27" TV
Magnavox 27 Inch TV- no picture but has sound
the vert. circuit need to be rebuilted
Aug 04, 2008 | Televison & Video
Horizontal lines
may be vertical deflection circuit bad capacitors and is a job for experienced tech
Apr 01, 2008 | Philips Magnavox MS2530C 25" TV
From what I can understand, your problem is:
1. either a single horizontal line (from left to right), very bright, no picture but with sound, if yes then it is a failure of the vertical section. More often, it is the vertical IC that is at fault, sometimes the vertical capacitor. Still, in other cases, it is a case of cold solder; or
2. multiple lines across the screen with the picture overly bright and with sound. If yes to this one, then it is a matter of excessive screen voltage. This is adjustable using the HV Screen control that is at the rear of the Flyback Transformer.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 10, 2008 | Televison & Video
Philips magnavox 32" TS3260C1
Sounds like retrace lines. Leaky caps or worse can cause this.. Are you getting any vertical foldover at the top of the screen?
Jan 18, 2008 | Philips Magnavox 27MS343S 27" TV
Screen only showing single line of video in center.
hi there, is the single line horizontally or vertically? if horizontal line, you do have a vertical section problem, check some parts at vertical section, the vertical ic, the power source of vertical section ie diode & resistors. ty
Dec 26, 2007 | Zenith Z32X31D 32" TV
JVC 27" CRT TV AV-27BP3 display shows single horizontal line
I have a similar problem on my CRT computer monitor (AcerView 76c). It is an old screen and I think it is just at the end of its life, much like your TV. Having some background in physics, I would be pretty sure that the problem is with the cathode ray tube's vertical deflection system. The horizontal deflection electrodes are working while the vertical one is not. This results in a display of a single horizontal line (or in my case, a few superimposed) in the centre of the screen. Where both X and Y (horizontal and vertical) deflectors fail then the electron gun firing would result in a single bright spot in the dead-centre of the screen.
So really, we have no choice but to move on and buy a new set as repair is probably just as, if not more, expensive than replacement with a new device. Seeing as your post was in 2007, I hope you managed to solve the problem.
Best wishes,
SZ (Sydney, AUS)
Dec 24, 2007 | Televison & Video
Philips Magnavox 27MS343S 27" TV Logo
278 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
