Question about Kenmore 24032\24036 Top Load Washer
The towels and wash cloths have a metalic smell
When the towels and wash cloths get wet they have a metalic smell
Despenser is not releasing bleach and washer has odor as well as clothes.
Posted on Feb 12, 2009
I have a whirlpool cabrio washing machine. I have a problem. Our clothes are coming out smelling musty and nasty. They dont start smelling until they are wet, like with sweat Or the towels when we dry off...
If you dont wash whites with clorine bleach, you may want to every once in a while. Clorine kills germs and backteria which can smell. washer pumps do not get 100% of the water out.
Sep 23, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My Daughter and us both have 2 yr old FP washing machines and our clothes smell when they get damp, mainly towels. We use all hot water, liquid tide with bleach and are even adding oxi-clean. I know...
Hi just read your posting.Now could you please confirm your model number for me.Also from the information in your posting when the clothes are wet they have a smell on them.Is this after the clothes have spun dry or when they are washing?Please reply on the model number and the cycle you are using with any of the options you might have chosen.Looking forward to your reply.
Aug 07, 2010 | Fisher Washing Machines
Smell after drying
Try drying your clothes without the dryer sheet and see if the smell is still there. If it is not, then the problem is the dryer sheet.
If it is, then you need to describe the smell better. Different people handle smells differently. What smells musty to you may smell fragrant to others.
You need to determine if the smell you don't like is really a musty smell, or is it a fragrance you don't like. Have some friends (not family members) smell the clothes and verify if what you are smelling is musty or fragrant.
It could also be that even though the clothes smell OK out of the washer, that the detergent you are using is the cause.
Dec 16, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Clothes smell from Kenmore Front Loader
run 3 cups of bleach on high water setting with hot selected as water temp, repeat as ness to eleminate odor
Sep 11, 2009 | Washing Machines
After final rinse and spin cycle clothes are still wet
I can't solve this but am having a similar problem. There is no water in the tub but the spin cycle does not get enough water out of the clothes and they're very wet. This causes the towels especially... to smell really bad. The tub is very loose. How can this be fixed.
Jul 23, 2009 | Frigidaire ATF6000ES Front Load Washer
Clothes have "dirty dishrag" smell after washing
If you open the door of your Neptune, you'll notice a small trough between the door gaskets (inner and outer) There is a drain at the bottom that can get blocked by lint and other funky stuff. Next time you do a load of towels, take a small dirty towel and wipe that area of your machine out real well. Secondly load a slightly smaller load in your machine. Be sure to use a HE compatible soap...less foaming- it does make a difference.. Also the swishy slushy sound is normal and there is liquid in the drum for balancing...it's normal.. I think with a clear door drain, a bit smaller load .you'll find it won't be smelly.. I've got one of these and the only time it gets ordoriforous is when I've jammed it to max capacity. Let me know if all this helps you out. k
Jun 08, 2009 | Maytag Neptune MAH5500B Front Load Washer
Towels smell oily and moldy--really stink
Don't use fabric softener. I had the same problem and read somewhere to stop using the fabric softeners. I don't know why but after about two cycles (they smelled really bad) it worked! I always used fabric softeners with out a problem but one day I just started getting REALLY smelly towels. I always take my wet wash out as soon as the cycle ends and dry it completely so I was surprised when they smalled so bad. Give it a try.
Jan 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The clothes dried on high or medium heat come out smelling like heated metal
hi .thanks for the question .yes i would check all venting from dryer to the outside . clogged venting, or dryer too close to the wall could cause this problem . thanks the appliance doc
Sep 30, 2008 | Kenmore Elite HE4 Electric Dryer
Clothes/towels smell like mildew
Front load washers are so tight ( to seal in water ) that they tend to leave water in door gaskets and other places.. This water gets stagnant and can build up mildew etc..Home depot and other home goods stores sells a product called AFRESH and you use it about once a month ( with no clothes in washer).. It does help a bit..
Other techniques you can try would be to wipe down the gasket around the door opening after a wash is complete and to leave the door open between washes to let it air dry.. You should be using HE type laundry detergent and very little of it ( sveral drops is enough per load)..
hope that helps you...
Aug 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
127 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
