Question about Cannon 10476G Dual Fuel (Electric and Gas) Kitchen Range
Top Oven/Grill not working on Cannon Dual Fuel Henley Pro
We just installed a second hand (4 year old) Cannon Henley Professional Dual Fuel Cooker. It's a beauty, thought we'd have it professionaly cleaned as we got a bargain at £50. I trust the former owner that it worked perfectly well and saw their new built in oven in their posh new kitchen, so I doubt that there was a problem before transporting it.
Here's what happened. Our electrician installed a new 45amp dedicated RCD supply. Unfortunately this was after the oven was cleaned by ovenu, so I can't say if their work had any effect. We turned on the supply and the RCD tripped. We turned it on again, and this time it was fine. Turned the main fan oven on and it worked fine, then a few seconds later the bulb blew. ( The main fan oven still works fine, even with the timer). On trying the top electric oven and grill there is no sign of life. The thermostat light doesn't come on, and neither does the oven light (with a new working bulb). I'm nervous about taking the back off, pertly because the gas inlet appears to be on top of the back panel. any ideas? I'm guessing thermostat or element? But is there anything else that could be knocked out of place?
Many Thanks
Mark
2 Suggested Answers
SOURCE: Gas in main oven
hello, i have looked into the problem and have come up with a fix for mine at least. take out all the trays, and peer into the rear. you will see a silver section which has three srcews. remove the centre one to get access to the burner which has the white igniter on it. this just slips sideways and off. with the aid of a small mirror you should see a small brass nut where the gas comes from. there is a small pinhole in the centre,mine was slightly blocked and this reduced the flow of gas. i cleaned this with a pin and the gas flow improved. i am not an expert and take no responsibilty if it goes wrong. it appears to have worked for me so the choice is yours.
regards. flask
Posted on Jan 14, 2009
Blows house trip when oven is turned on
Here is a diagram showing how the range receptacle should be wired. I would begin by checking there.
http://www.make-my-own-house.com/electrical-wiring-diagrams.html
Apr 16, 2009 | Kitchen Ranges
Oven Ignition Keeps Clicking
it is the spark generator at back of cooker they are about £65
Mar 16, 2009 | Cannon Chesterfield C60G Kitchen Range
Id number for range
The id number is in the right hand oven on the right. It sounds ans though the cooker is a 90 or 100 wide with chef top or fish burner. An instruction bookcan be sent in pdf format by contacting www.britannialiving.co.uk
Dec 21, 2008 | Britannia SI10T6L Dual Fuel (Electric and...
TECNIK 1285 RANGE COOKER
I have a Tecnik Range cooke that was in the house when i bought it. The secong oven has no cover for the heating element at the top so everything I put in browns at the top. Should this oven have a metal plate underneath so that I can use it as a conventional oven or should it be like that
Dec 19, 2007 | Tecnik TKC1285 Dual Fuel (Electric and...
Oven cuts out after about 15 minutes
most common fault is the cooling fan is failing to come on, whreas the fan will be okay ( check windings with ohmn meter ) it will normally have a ceramic 10k resitor in series with the live which goes open circiut
Sep 25, 2007 | Stoves 900DFa Dual Fuel (Electric and Gas)...
Left hand oven
The left hand oven needs a new flame failure device fitted , it is a normal oven not for slow cooking . This repair can only be carried out safely by a registered Gas Safe engineer . Visit WWW.gasSafeRegister.co.uk or ring freephone 0800 408 5500 to find one in your area.
Jun 02, 2007 | Rangemaster Classic 110 (Dual Fuel) Dual...
Cannon 10476G Dual Fuel (Electric and Gas) Kitchen Range Logo
317 people viewed this question
Top Cannon Kitchen Ranges Experts
Paul Carew
reyaazm
Level 1 Expert
Tom Chichester
Are you a Cannon Kitchen Range Expert? Answer questions, earn points and help others
