Question about Acer Aspire One PC Notebook
Acer Aspire One - Time settings
I have a Canadian version of the Acer Aspire and since new it has never been able to hold the correct date and time. no matter how many times we reset it, it just loses days. we have tried syncing it with the internet but this does not work either. Also, its 8 weeks old and now the fan is starting to make a noise.
Its running Windows XP.
    Genius:
  • Acer Master
  • 1,102 Answers
Click the icon then remove check from lock taskbar
then click to adjust time and date then set your timezone
then in internet time check automatically syncronize then
time.windows.com then update and then apply
then click icon again and check beside lock taskbar
if this does not hold your time then redo remember to unlock taskbar first this time in internet time click server and change to time.nist.gov
then update and apply
if problem persists change back internet time to time.windows.com let me know if problem fixed please don't forget to rate me
thanx
Posted on Feb 09, 2009
  • Acer Master
  • 2,404 Answers
Sounds like the small penny size battery that connects to the motherboard may be faulty which is why it may not be keeping the date and time. Try going into the BIOS of the laptop and set the time there and save the settings to see if that solves that. If it doesn't then its the small battery.
If the fan is starting to make noises, make sure there is no debris in the fan.
That is the fan that goes on top of the CPU. If there is no debris in there then the fan is faulty.
Patriot d600 lap top telling me bios is wrong on boot up.
You can answer Ihm that it is not to trust throug set the correct Date and Time on the Bios!
Aug 02, 2013 | Acer Aspire 3680 Laptop
Tip
How to replace the CMOS battery in an Acer Aspire laptop.
General info
All laptops have a CMOS battery. The main purpose for the CMOS battery is to store the system time, date and BIOS settings even if the computer is turned off or the main battery dies. Individual Acer Aspire laptop models differ somewhat, but the general steps are the same when replacing a dead CMOS battery.
Before you start
1) Read through the owner's manual for your particular Acer Aspire laptop to determine what kind of CMOS battery you need.
2) Purchase the battery through Acer or a local or online computer parts dealer.
3) Turn the laptop off and unplug it. Also unplug any external hard drives, cameras, or other external devices.
4) Turn the laptop over (bottom facing up), then touch something metal to remove static charge.
Removal of the CMOS battery
Remove the Phillips screws that secure the motherboard cover (refer to your owner's manual if necessary), then release the cover from the clips on the bottom of the plastic casing. Lay the cover aside then locate the CMOS battery cable on the right side of the motherboard. Unplug the cable then remove the battery.
The battery should look something like this
Plugging the new battery in
Plug the new CMOS battery cable into the motherboard. Slide the battery partially under the laptop casing (somewhere to hold it in place), then align the cover with the slots on the bottom of the laptop housing. Replace the screws then turn the laptop back over.
Finalizing
1) Turn the laptop on.
2)Enter your BIOS (usually by pressing the "Delete" key) before the operating system loads.
3) Follow the BIOS prompts or refer to your Acer Aspire owner's manual to reset your time, date and desired system settings.
Reason: Anytime the CMOS battery is unplugged for more than a few seconds your BIOS will be reset to the default manufacturer settings. If you make any changes to the BIOS that cause problems with your Acer Aspire, unplug the CMOS battery for 3 to 5 seconds to correct the problem.
Please rate this tip by clicking the thumbs up at the bottom right of this solution. Your rating is much appreciated.
<SPAN style="LINE-HEIGHT: 115%; FONT-FAMILY: 'Arial','sans-serif'; COLOR: black; FONT-SIZE: 10pt; mso-fareast-font-family: 'Times New Roman
on Nov 12, 2010 | Computers & Internet
Bl51 motherboard
All laptops have a CMOS, or "Complementary Metal Oxide Semiconductor," battery.
The main purpose for the CMOS battery is to keep the system time, date and BIOS settings even if the computer is turned off or the main battery dies.
Individual Acer Aspire laptop models differ somewhat, but the general steps are the same when replacing a dead CMOS battery.Preparation
Also unplug any external hard drives, cameras or other external devices.
Removal
Lay the cover aside, then locate the CMOS battery cable on the right side of the motherboard. Unplug the cable, then remove the battery.
Installation
Slide the battery partially under the laptop casing to hold it in place, then align the cover with the slots on the bottom of the laptop housing.
Replace the screws, then turn the laptop back over.
Settings
Plug the laptop in and turn it on.
Enter your BIOS (usually by pressing "F1," "F2," F10" or the "Delete" key) before the operating system loads.
BIOS Reset
Any time the CMOS battery is unplugged for more than a few seconds, your BIOS will be reset to the default manufacturer settings.
If you make any changes to the BIOS that cause problems with your Acer Aspire, unplug the CMOS battery for 3-5 seconds to correct the problem.
http://support.acer.com/us/en/default.aspx
Acer aspire laptop battery replacement
http://www.youtube.com/watch?v=mQTZ1AUR0uw
Jul 24, 2013 | Acer Aspire 5100 Notebook
Acer aspire 5741 wont charge to more than 28%
how old is the battery it might be past its used by date
how long will it hold charge if it does not hold charge for very long and it takes a long time to charge you need a new one
hope it helps
Jul 01, 2012 | Acer New Aspire 5251 5551 5551G 5741 Upper...
The system clock will not stay set, when I turn off laptop the clock stops and calendar stops . I reset it every time I turn it back on so I receive all up to date updates . Windows updates are set to ...
You need to set the correct date and time in your system BIOS. To access that you need to press the correct key when the computer is first booted (usually DEL or F10/F2/F11).
Most computers will have a message stating press xx Key to enter setup or etc.
If this problem persists even after setting the correct time in your BIOS, your laptop needs a new CMOS battery. I recommend having a professional do this.
May 09, 2011 | Acer Aspire 6920-6422 Notebook
Green function key locked on acer laptop
Hey, I've just been having this problem. Try pressing CTRL + SHIFT + FN all at the same time. I found out that I had to press them once to turn on the green keys, and then press them twice more to turn it off. I hope that works for you.
Feb 12, 2010 | Acer Aspire 4530-5889 Notebook PC
Motherboard Dater
Hello. To get date and version:
The only BIOS upgrade I find listed for that model (T160 Aspire) on Acer Website for the Aspire T160 Desktop is:
Acer BIOS R02-B1 868.5 KB 2008/12/09.
If you received your computer before that date and you have not added a new BIOS flash to your PC since that time, you can be sure you do not have it. http://gd.panam.acer.com/home/ Search their site by your full Serial Number if possible, and then model number to be most certain.
Other options:
When first turning computer on, at first signs of any text on your screen before it actually boots up you may hit the "Pause - Break" button on the keyboard and try to get the on-screen messages to stop so you can read it and write it down.
This text on the screen should include/tell you what date and version your motherboard BIOS/Firmware model is. You can usually pause that with a few tries, and/or just hit CTRL+ALT+DEL right then (after pause and before Windows or Unix starts) to try again.
If that does not work hit the correct key to enter BIOS Setup (access long before Windows boots) and read all information about your system there in the BIOS screens (usually always has BIOS version date listed in there).
NOTE: Adding a new BIOS flash always calls for caution as if it fails or goes wrong for any reason mid-install you may not get the computer to work again.
Oct 29, 2009 | Acer Computers & Internet
Acer 5630
That's weird. can you check that you have the proper timezone settings under "date/time settings" and that your system is not automatically syncing itself through the "Internet Time" tab?
Oct 29, 2007 | Acer Aspire 5630 Notebook
Ace aspire 3610
If it keeps going into setup, check that the date and time is correct, if not correct it and go to standard cmos settings menu and see if your hard disk drive is recognised, if so exit and save settings and reboot. If sends into set up again, check date and time again and if incorrect again, then the cmos battery is flat and needs replacing, if time and date is ok, then look in standard cmos settings again and look for a line reading 'Halt on all Errors', dissable this and next time it boots it should boot to the part where it gives a clue as to the fault.
Apr 16, 2007 | Acer Aspire 3610 Notebook
Acer Aspire One  PC Notebook Logo
194 people viewed this question
Brian Sullivan
Brian Sullivan
Mohammed Ebrahim M
Mohammed Ebrahim M
