Question about NetGear RangeMax WPN824 Router
Port Forwarding not working on Port 80 from our website
We are having trouble forwarding our Netgear Range Max Router if you click on the following link on our website http://70.177.13.75/LoanServicingSystem/index.php It should display the application page. 70.177.13.75 is the static ip address for our router which has been programed to forward service http on port 80 to a database server on our local area network. It works for all computers on our local area network but not for "outside" users. They get a page could not be displayed message. Any ideas on how to solve this Thanks Bob
Twenty-First Century
website: http://www.21stcenturycompany.com
email: tfc@21stcenturycompany.com
phone: (888) 961-6677
fax: (805) 964-5007
  • tfc1 Feb 10, 2009
    the problem is not internally but externally.
    For example if you go to our website
    click on loan systems in the orange box in the upper left corner
    Scroll down to Web System Demo and click on the blue button
    This link is directed to our netgear router which has been programmed to forward incoming requests on port 80
    to display the application page. As you will see, the forwarding is not working.
  • tfc1 Feb 11, 2009
    Found the problem. ISP is blocking http on port 80.
    changed the link to port 88 and its working fine now.
  • 258 Answers
The best way to test this is to forward it to a test webpage on another PC or server first to make sure it is working correctly, before trying the unix/linux php server.
In my experience external addresses do not work internally, unless you have your ISP allocate you moe than one external static ip
Please post your results, the provider and whether you already have multiple static ip addresses purchased
Posted on Feb 09, 2009
  • Peter Conway Feb 10, 2009
    Yes I understand the question.
    You could allocate static IP addresses if you have them from your provider and turn off NAT
    However to solve this problem with forwarding put a test html page in the root public_html on the database server and i'll try and access it.
    If it's working internally then it could be a firewall on your router or on the server itself blocking that port
    eg. index.html
Router port forwarding
I got the following from Netgear support on how to do port forwarding on my Netgear model # WNR1000
1) Start > My Network Places > View Network Connections to ensure Network connection is enabled
2) Open a browser and access the router by entering 192.168.1.1in the address bar.
3) User name: "admin" and Password: "password"
4) Click on Port Forwarding under Advanced on the left side of the Router page.
5) Click on "Add Custom Service" button.
6) Specify any name for the Service. Service Type - TCP/UDP
7) Specify the Start Port and the End Port. (80 & 90)
8) In the Server IP Address, Enter the IP address of the device (192.168.1.x).
9) Click on the "Add" button.
10) Follow the above steps to open any other ports with different service names.
11) Click on Apply.
Aug 12, 2014 | Computers & Internet
Tip
Port Forwarding for PLAY STATION on NETGEAR routers
The following steps will help you forward ports on the NETGEAR router for Play station network (PS2, PS3, PSP). At time you can not access or play online games through your PS and in such cases you need to make sure that you have the required ports forwarded on your router as mentioned below. The below steps are applicable for NETGEAR router model WGR614, WGT624, WPN824, WNR2000, WNDR3300, WNR854T, WNR834B etc
1. Open a browser (Internet Explorer, Mozilla Firefox or Safari) on your computer connected to the router.
2. Access the router, usually by typing 'http://192.168.1.1' or 'http://www.routerlogin.com' in the address bar.
3. Login to the router (Username = admin and Password = Password unless you have changed it).
4. Click on Port Forwarding under Advanced.
5. Click on 'Add Custom Service' button.
6. Specify any name for the service (PSN1). Select Service Type as TCP/UDP
7. Specify the Start and the End Port as 80.
8. In the server IP Address specify the ip address of the PS3.
9. Click on 'Add' button.
10. Follow the same steps to open the below ports
Start = 443 End = 443 use name as PSN2
Start = 5223 End = 5223 use name as PSN3
Start = 3478 End = 3479 use name as PSN4.
Start = 3658 End = 3658 use name as PSN5.
Start = 10070 End = 10080 use name as PSN6.
Click Apply.
These steps would allow you to access online games on your PS connected through the NETGEAR router.
on Mar 18, 2010 | NetGear WGR614 Router
Can't view IP cam externally
Follow The Process:-
1.Visit https://www.yougetsignal.com/tools/open-ports
input the port 5000 and check is it open or not, if it is not open it means you need to check port forwarding in your main internet router/modem.
2. By Default Routers/Modems Http port it 80. so you need to change ip camera http port 80 to 81 and do port forwarding and to view on android devices check another ports in ip camera network settings. so same port forwarding and check in yougetsignal website.
Visit Here for next level help:-
CCTV Networking Technical Support
Jun 10, 2017 | D-Link Securicam Network DCS-950G Wireless...
NetGear WGR826V has no clear port forwarding section in the setup, the mamnual is as clear as brick as to forwarding...so how do I forward a port on this brain dead router?
Forwarding Port – If you select 'Same as Incoming port' then all incoming traffic on specified Service is forwarded to LAN server without modifying Destination Port. – If you select 'Forward to another port range' then all incoming traffic received on the Service port (or range of ports) is forwarded to this port or range of ports of the LAN Server. – This field is disabled if action selected is "Block Always". – If you want to forward the traffic to a single port then enter port value in start port and leave finish port empty. – If you want to forward the traffic to range of ports then enter non zero value in finish port and make sure that service record attached to this rule has range of ports and range is equal to that of forwarding ports. – For example if you select Service as HTTP (TCP/80), LAN Server IP address as 192.168.15.10 and Forwarding port as 8080 then all traffic coming from internet on – TCP/80 (HTTP) to this Router is redirected to TCP/8080 port of 192.168.15.10 • WAN Users: These settings determine which packets are covered by the firewall rule, based on their source (WAN) IP address. Select the desired option: – Any All IP addresses are covered by this firewall rule. – Address range If this option is selected, you must enter the "Start" and "Finish" fields. – Single address Enter the required address in the "Start" fields. • Log: This determines whether packets covered by this firewall rule are logged. Select the desired action. – Never - never log traffic considered by this firewall rule, whether it matches or not. – Match - Log traffic only it matches this firewall rule. (The action is determined by this firewall rule.)
Ok well this is out of the manual, to me it seems straight forwards, but it is a brick too though, there is an example to help you, basically you tell it the Address of the PC, (Right click on NIC and get address) that you want ports to go to.. then ALLOW it, UN-disable actually.. in the tables.
Feb 05, 2010 | NetGear WGR826V Router (wgr826vna)
How do i set my tcp port range and udp
Following steps will help you out:-
1)Open the router gui with 192.168.1.1 or http://routerlogin.net by typing it in the address bar for the user name as admin and password as the word password only.
2)On the Netgear smart wizard .left hand side you will find a small blue/purple column with different categories , look for the one that says advanced and click on port forwarding/port triggering and select port forwarding from there and click on Add custom service from the bottom .
3)A new screen will appear which will have the following options:-
Service name:-
Service type:-tcp , udp , tcp/udp
Starting port:-
Ending Port:-
Server Ip Address:-(enter the value in range) and apply the setting's.
Nov 16, 2009 | NetGear RangeMax WPN824 Router
I have a question
In this scenario we can open port numbers on the router but for that we need the list of ports that has to be open and that we'll get from ps-3 support services
Get the port numbers and follow these steps to enter them:-
Service name:-(any name)
Starting port:-
Ending Port:-
Server Ip Address:-(enter the ip address of ps-3) and apply the setting's.
The value for the starting and ending port will be same i.e if suppose we have a port no. 80 for the ip:-192.168.1.15 and tcp as the service to open then this is how it will be done:-
Service name:-abc
Service type:-tcp
Starting port:-80
Ending Port:-80
Server Ip Address:-192.168.1.15
After forwarding all the port numbers go for the connection test on ps-3.
Nov 15, 2009 | NetGear WGR614 Wireless Router
Set NAT to open for Xbox only, not computers
This is entirely not the issue for NAT setting's . In this case we have to open the port numbers on the router to get the successful connection test.
The port numbers will be given by the Microsoft support services . Once we have the port numbers and the Ip of the Xbox following steps can be taken to enter the given numbers:-
Service name:-
Starting port:-
Ending Port:-
Service name:-abc
Service type:-tcp
Starting port:-80
Ending Port:-80
Go for the connection test after forwarding all the port numbers.
Nov 14, 2009 | NetGear WGR614 54Mbps Wireless Router...
Port forwarding & Remote Management setup on Linksys WAG200G
here is how you set up port forwarding:
1. log into the router;
2. Click the Applications & Gaming link near the top of the page. 3. You should now see a new menu. Click Single Port Forwarding or Port Range Forwarding.
4, Enter sth like: HTTP; 80; 80; TCP; 192.168.0.1; check
5. When you're finished, click Save Settings near the bottom of the screen to save your changes.
go to administration-> remote administration to set up remote management
Remember, remote Administrator requires you to forward the 4899 ports.
Mar 23, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Port forwarding
hi there,
this is a basic step used to forward ports to your system.
Port Forwarding Steps for Routers 1. Log into your router. Usually the URL is http://192.168.1.1/, and enter the username , and the password . If you have never set a password, the password (which you should change) is admin. Consult the manual if you have never set up your router before or need to reset the password. 2. Click on the "Applications & Gaming" tab or Under Advanced, click Port Forwarding.
3. Click on the "Port Range Forward" tab .
4. In the "application" field, type "web" (if you are forwarding wb traffic on port 80) or "torrent" (if you are forwarding bittorrent traffic on port 40156). This is just a "nickname" so that you can recognize what you were trying to do when you come back to it.
5. In the "Start" field, enter: 80
6. In the "End" field, also enter: 80
7. Set "Protocol" to TCP. Web and Bittorrent servers use only TCP, so there's no reason fo forward UDP traffic too and create an unnecessary security risk.
8. In the "IP Address" field, enter: 192.168.1.11 or your system IP address.
9. Click "Save Settings." Forwarding should begin immediately.
Apr 15, 2008 | Computers & Internet
NetGear RangeMax WPN824 Router Logo
443 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
