Question about Mitsubishi WS-55511 55" Rear Projection Television
Mitsubishi WS 55511 rear projection NO SOUND
Mitusbishi 55511 - Had the t.v. sound on mute for a few minutes. After trying to resume the sound with the remote and manually - no sound. I tried the reset button, nothing changed. I put new batteries in the remote eventhough they had been changed fairly recently. It is like it is locked in Mute mode. Is it possible that the remote is just worn out, and needs to be replaced, Or something much bigger than that? I cannot find anyone on the site that has posted that problem, I just had a new Convergence chip replaced 2 months ago. Has anyone had experience with this?
  • 3 more comments
  • jacki3 Feb 09, 2009
    I would like information on what might cause the no sound problem. I have someone who might be willing and able to fix it for me if I know where to purchase any defective parts, etc. He is good with electronics. I had a repairman replace the convergence, and it was very costly.
    Thanks for the response and any info you may offer.
  • jacki3 Feb 11, 2009
    Thank you for the prompt response and suggestions. The problem is now solved. There was an issue with the Cable Co. provider. It was internal and they walked me through. I really should have called them first, but it did not occur to me that it could be the Cable Co. Thank you, again.
  • Anonymous Feb 12, 2009
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    Let split problem in 2 sections to minimize it.
    Please check is there TV Audio Out (at rear of TV) available by hooking any Amplifier / HiFi
    If you get sound on TV audio out pins, that means sound amp chip is fried. And if no sound there that means sound digital circuit is bad.
    Let me know results to proceed further.
    I can guide you to locate defective part for sound problem if you have good knowledge of electronics and sound experience of TV repair with necessary tools.
    Let me know do you want to repair TV by yourself or just need info what might cause of no sound.
  • 10,594 Answers
Thats great that problem is resolved. Have a nice time.
Posted on Feb 11, 2009
Mitsubishi 55" MODEL WS 55513 1080 HDTV blue screen
I plugged my Dell desk top in and the XP screen comes up, but when windows comes on I getablue screen. Any ideas?
Jan 21, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Bypass Mitsubishi HDTV Lock
Bypass Mitsubishi HDTV Front Button Lock
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Would you like to bypass, defeat or reset your Mitsubishi HDTV Front Button lock?
If you have misplaced your remote control, and have engaged the Mitsubishi HDTV Front Button Lock, you can bypass the front button lock by pressing and holding the MENU button on the front panel for more than 8 seconds.
I hope that helps.
Reset Mitsubishi HDTV VChip Password
Mitsubishi Projection HDTV Manual Download
on Apr 30, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-55511 Manual Download
Download Mitsubishi WS-55511 HDTV Manual
Have you misplaced your Mitsubishi WS-55511 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Mitsubishi WS-55511 HDTV Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
Bypass Mitsubishi HDTV Front Panel Lock
My television only puts out a pic in 480. The 720 and 1080 are not working. Getting sound no picture
No input on a WS-55511 is capable of 720p . Inputs COMP1 and COMP2 ONLY accept 480i/480p . Input DTV accepts 480i/p and 1080i . When using Input DTV with a component connection(YPbPr) and you get a green or no picture then you will need to navigate the menus and setup input DTV for YPbPr instead of RGB.
Oct 13, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Mistubishi WS-55511 won't stay on
23 is a horizontal deflection error could be ho transistor flyback or high voltage splitter
Sep 17, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Press in together the menu button and the Device/input button on the set and hold them both in together for 5 seconds and see if the led will blink a two digit error code, then respond to this same post and let me know if it gave a error code and what the two digits were.
Aug 02, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-48613
Did you try reset? Unplug AC cord for a while,plug in try again...
2) With paper clip, activate reset thru access hole on front of
TV ( consult owners manual) recheck.....................
3) Leave set unplugged from AC overnight.................T.
Please rate this solution........................
Nov 11, 2007 | Mitsubishi WS-48613 48" Rear Projection...
Missing voltage = open fuse in power supply?? soldered-in
pico fuse?
Does light blink continuos up front?
Can you hit power again with same result or must unplug/plug
AC cord??
Oct 24, 2007 | Mitsubishi WS-55515 55" Rear Projection...
TV wont turn on
know problem of bad caps.
replace DM
Picture of bad caps
The DM board is the one with the digital connectors on the back panel. If you already have it appart, you may as well check the caps on all of the boards. The caps that go bad are typically Jamicon brand caps in 1000 uF and 330 uF values. There are also a couple of 3300 uF caps in the PS that cause problems.
Oct 22, 2007 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
122 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
