The rinse agent does not turn on at all. The pump motor tests out all right. Also shows P2 code.
You need to test if there is voltage to rinse pump from timer/control panel. Assuming that pump is already tested, if there is voltage from panel on rinse cycle, and the pump does not have voltage , then replace wiring harness.
If there is no volts from panel, when reading timer board connectors with a multimeter, then replace control assembly.
If the pump does not work when energised , then replace pump.
It is a Lxih, ML# 130017
The rinse pump is not turning on at all. I am helping a friend with this, it is not my machine. The rinse aid bottle is partly used, so I am sure that it just quit. I am not sure about the icon.
The rinse icon is on. I already checked the motor and it is alright. Thanks for the help
You wrote that the chemical board is not sensing the rinse agent. Is the board bad or is there something else I should be checking?
There are three different circuit boards on this machine. There is the main board, a relay board, and a board that the detergent and rinse agent flow through. The rinse agent does not turn on at all. The rinse icon is on, but the pump is not turning on. The pump motor tests out all right. The relay board was switched as it had an obvious problem. The probe that was making it flash P2 was also switched out. That leaves the main board and the chemical board. Are you familiar with Hobart and and sure that it is the main board, as we are talking hundreds of dollars.
I do not know what else to add to what I have already posted. Anyone a Hobart expert???
