Question about Soyo DYLM24D6 LCD Monitor
DVI CABLE AND AUDIO CABLE. NO EXPLAINATION OF HOOKUP OR USE
WHERE ON COMPUTOR DO I RUN THE AUDIBLE CABLE. WHAT IS THE DVI CABLE(oPTIONAL ) AND EXPLAIN THE HOOKUP
  • 1 more comment
  • danaom Feb 09, 2009
    THANKS , I THOUGHTI MIGHT TRY THAT BUT WAS UNSURE. A DVI CABLE WAS NOT INCLUDED BUT OPTIONAL. IS THIS NECESSARY ?
    WHAT IS A DVI CABLE AND WHERE ON COMPUTOR DO YOU [LACE SAME, DANAOM
  • danaom Feb 10, 2009
    THANKS AGAIN FOR YOUR HELP DANAOM
  • jim beckwith May 11, 2010
    I put mine in the micrphone area
    Genius:
  • 2,120 Answers
Plug the audio cable into the LIME GREEN port on the computer.
You can onlly use a DVI cable if your Video Card has that kind of connector.
Trust me, you don't need one. Use the D-shaped 15 pin connector.
Posted on Feb 10, 2009
  • Leroy Elliott
    Leroy Elliott Feb 10, 2009
    Thanx for the FixYa!
How can i connect my hp pavillion s5610y to my bravia tv
This is a bit complicated since there is no HDMI output capability to the PC, only VGA and DVI. First, check to see if the Bravia has one of its HDMI ports listed as DVI capable. If it does, it should have accompanying audio jacks (red/white) for it. What you would need to get is two different cables for interface. The first is a DVI-to HDMI cable to run from the PC DVI port to the Bravia DVI-compatible HDMI port. You cannot run the DVI to a regular HDMI port because if you do you will get only picture and no sound. DVI outputs, unlike HDMI outputs, do not carry the audio signal. A DVI-compatible HDMI port on a TV set will connect the video from the HDMI port and the audio from the reserved audio port accompanying it. The second cable you need will be a mini stereo audio plug to RCA jacks. This will connect between the PC audio out (green), and the DVI audio plugs on the set. See pictures for cables below
Once you have this done, selecting the appropriate HDMI port on the set should result in audio and video getting to the unit. If you only need the video (you are going to use the PC speakers), then you don't need the audio cable and you can use any HDMI port, but you cannot control the volume using the TV set remote. You would need to use the PC volume settings. (Just as an afterthought if the set has no DVI-compatible HDMI port).
Jan 26, 2016 | HP Computers & Internet
How do i set up multi screen on my 42" HDTV Insignia
You may use an HDMI / DVI cable to connect to your computer. Next if you have windows 7 hold your windows key and hit the letter "P" (for projector) this will allow you to bring on the multi-montior feature on your computer. Make sure to select the option that says EXTEND. Please note that when connecting a DVI device you must use the HDMI IN1 (dvi) jack on the back of your TV. you cannot use HDMI In 2.
1. Turn off your TV and all connected equipment.
2. Connect an HDMI/DVI cable or DI-HDMI adapter between the HDMI in 1 (dvi) jack on the back of your TV and DVI OUT jack on the DVI device.
3. Connect an audio cable between the DVI audio IN jacks on the back of your tv and the DVI audio jack on the dvi device.
turn on the tv then turn on the dvi device.
May 02, 2011 | Computers & Internet
How can I connect Panasonic TH-37PX60U Flat panel plasma tv to my computer?
It will depend on your video output options on the computer. If you have HDMI output, just use an HDMI cable and an audio cable (this will need to be a 3.5 mm to RCA audio cable). If you have a DVI output, use a DVI to HDMI cable and the audio cable (or a DVI to HDMI adapter and either a DVI or HDMI cable depending on which side you want to put the adapter). If you only have VGA out from the computer, use a VGA to DVI adapter and the DVI to HDMI connection and the audio connection. (Theoretically this should work but each adapter will have some signal loss issues.)
Some graphics cards have a video output, S-video or Component video, which would also connect to your TV with the audio cable. (Read your cards manual for more information)
I hope this helps.
(For DVI to HDMI cables, you will need to check if you have a single link or dual link DVI output. The wrong cable may not work.)
Feb 20, 2010 | Panasonic TH-42PX60U Television
Trying to hookup new Aqous led/lcd 40 in to sony blu ray disc home theater system. Get incompatible audio signal message on tv
incompatible... hmm sounds like you're not using the correct Cables, are you using DVI or standard rca?
Oct 04, 2009 | Sharp Televison & Video
When i hookup dvd 2 dvi i get pic but no sound
I think I know what the problem is. I have the same tv and been going through the same thing. Looking in the manual it says you need to get sound through the pc audio its the green audio jack. you have to get a female Y analog to pc cable. I saw one on ebay for $2. My problem is I've also got my computer hooked up.
Dec 26, 2008 | ViewSonic N2750w 27 in. HD-Ready LCD...
Audio but no video from Sony Blu-Ray w/ HDMI hookup to RX-V663
Okay...my first contribution to any forum but I have the same problem (Yamaha RX-V663 and Samsung Blu Ray) and found the solution. The problem is you probably have your HDMI cables from your DVD player and reciever connected to a DVI input on your TV. The DVI may have problems communicating--not HDCP compliant. My system was working great then I hit a button on my remote...just playing around. I think it was the pure audio and I turned off the receiver. After that, the audio worked but there was no video. After many frustrating hours, the fix was to unplug the HDMI and DVI cable then turn the power off, cycle the power again, and plug the HDMI and DVI cables back in (the DVI was the last cable plugged in, not sure if that matters). By unplugging everthing you've reset the communication between the HDMI components and the DVI TV.
See page 18 of the yamaha owners manual, second to last note on bottom right of the page. It says there may be a problem...
I also noticed that the yamaha reciever was sending 1080p (my older tv is 1080I) and that is why the video wouldn't display on the TV. You can see this in the video signal info screen, unfortunately there is no setting to switch it back, just recycle the cables and power and it should reset.
Uncredibly frustrating but I got my picture back!
Jason
Dec 01, 2008 | Yamaha RX-V663 Receiver
Hdmi and audio
It may be the top of set box.. Most times the sound and picture are auto detected by the set when HDMI is used. Both sound and video are carried in a HDMI cable but not with a S video cable. Try another HDMI cable *** dont buy the expensive one the tv don't care if they cost $125 or $25.
May 23, 2008 | Insignia 37" LCD Flat-Panel HDTV
Dvi hooked to hdmi
DVI cable is only video you will need to hookup some standard red and white audio cables in addition to the DVI
Apr 10, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Soyo dylto32c
The DVI input on this set is meant for picture only.. ex. to display computer picture.
if you want audio with your picture. you must connect to either inputs YCBCr or YPbPr which both of those inputs has audio inputs.
Mar 19, 2008 | Soyo DYLT032C 32 in. LCD Television
Hooking up a sony playstation 3 with digital optical cable
Here's one solution, if you have an audio output from your tv, you can go from the audio output on your tv to the audio input on your receiver that way anything that is playing on your tv for example, playstation 3, dvd player etc. Anything playing on your tv will have audio on your onkyo home theater system. The other thing I would try if you want to hook ps3 directly to receiver is go to your connection settings on your ps3 menu and change your connection method to digital optical cable.
Dec 27, 2007 | Onkyo HT-S790S System
Soyo DYLM24D6 LCD Monitor Logo
141 people viewed this question
Top Soyo Computers & Internet Experts
Roy May
Matson Kurian
Matson Kurian
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
