Question about LG 15LW1R 15 in. LCD Television
LG15LW1R Just Gone Blank!!
The TV's on the stand and plugged into a mains socket, and although the light on the front panel for the battery is on, the TV doesn't come on - just a blank screen, nor does the blue light on the wireless box come on.
Tried switching it on with the remote but nadda!
I've only had it for 18mths - have noticed the side gapes a bit, but it can't have gone kapput already, surely?
Help pleeeeeese!
  • 2 more comments
  • an359 Mar 16, 2009
    Fantastic - it worked just as advised and the TV's functioning back to normal. You really know your stuff!!!! THANK YOU!!
  • Anonymous Mar 21, 2009
    I had the same problem. Received no help from either LG or Currys.
    Removing and replacing the battery WORKED. TV working again. Thanks a million.
    Will check here again first if any further problems in future.
  • an359 Aug 29, 2010
    an359: It went again. I eventually got through to an LG (so-called) service centre based in Slough and they directed me to an official repairer on the North Circular Road near Staples Corner, London called Atlantic Electric. They charged me a standard £50 just to look at it. I returned and saw it working in the workshop - the guy said it was probably interference from other wireless/remote controlled devices and being taken out of my house to another location allowed it to find itself, but when I got it back home it wouldn't come on so I took it back again. Eventually they got it working. They didn't charge me after the initial £50. So it may be worth trying to pair it up away from other electronics if you have this problem.
    Since then I've been getting a picture - the receiver is in the living room
    .....and the monitor's in the kitchen and at times they do still have a problem finding each other so I get the same no connection error message - sometimes it struggles and is off for a couple of days - but now more often than not it's working again.
Remove the battery from the back and then put it back in. This resets the TV and should get it to work again.
Posted on Mar 14, 2009
Lg tv power light comes on but screen stays blank
If you can't see a faint picture with the flashlight then the T-con board is gone. If you can see a faint picture, then the led driver or ballasts for the back lights quit. You can get parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Dec 05, 2016 | LG Televison & Video
When i plug in the tv nothing happens. the red stand by light does not even turn on.
Hi Frazier,
The power supply board of your TV needs to be repaired or replaced.
Apr 15, 2016 | Televison & Video
Television reset
Just unplug it from AC mains wall socket, and re-plug it back after 20 minutes or so. This procedure should make it right. Electro help
Jul 17, 2014 | Toshiba 37AV500U 37 in. LCD TV
Why does my asus notbook not turn on and is blank?
Sounds like the battery is completely flat.
Ensure your charger is plugged into the mains socket and plug into your notebook. Leave to charge for about an hour, then it should switch on.
When you have finished using it, make sure it is shut down correctly and leave it charging over night for a full charge. (When it is switched on whilst charging, it takes much longer to charge.)
Jun 24, 2014 | ASUS B50A-B1 (90NQ9A1232244EQL150YB50AB1)...
Switch the plug socket on the red light comes on then nothing works model numberps50a457p1dxxu
Your TV is stuck in stand by mode. It may be a main board problem. Unfortunately there is nothing you can do about it yourself. Please consult some one qualified to do the job.
Jan 13, 2014 | Samsung Televison & Video
Unplugged tv and when plugged back in doesn't come on
Hello
If you have unpluged the TV from wall socket and it doesn't come On when you plug in back, either its power supply system or its stored memory has the trouble. Look whether the power indicator light coms on. Ensure that the main power ON/OFF switch at the front panel of the TV is ON. If the front panel power switch, control switch of your wall socket, and all the other electrical connections are OK, and still the TV doesn't come ON, surely the power inverter baord has the trouble and must be either repaired or replaced. if the power indicator light comes on, and your TV doesn't come ON by remote POWER ON button, the settigs that were stored has vanished, and resetting it to its original setting is necessary. Follow its manual for 'initial setup" and so all the recomended setting there. OK.
Apr 11, 2011 | Emerson LC320EM9 32 in. LCD HDTV
My tv won't turn on anymore. The power light and the opc light blink twice at the same time and then the opc blinks once and it keeps doing that. Please help!
Hi
Make sure the AC cord is not loose or disconnected. Check to ensure the cord is firmly plugged into the outlet at one end, and firmly connected to your television at the other end. The AC cord connects to the television about midway across the back of the set, near the bottom of the back panel. The hole for the AC connection is shaped like a figure eight. Try powering up the TV with the cords firmly connected.
Check the "Main Power" to ensure it is on. Locate the button on the top of the television among the "Volume" and "Channel" buttons. Press the button to switch the television on. If the "Main Power" button is off the remote will not turn on the television. Wait to see if pressing "Main Power" will activate the TV.
Press "TV Power" on the remote control to power up the TV from stand-by mode. If the power light on the front of the television glows red when you press "TV Power" on the remote, press the "Main Power" button on top of the television to remove the TV from stand-by. If the TV is accidentally in stand-by mode it may not come on when pressing certain buttons.
Check the circuit board. If your set still won't turn on and you hear a clicking noise when you plug it in, you most likely have a defective circuit board.
Oct 23, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
How to connect a tv to a wii
After getting everything out of the box, decide on where you want to put your Wii. It should be near your TV and near an electrical outlet. You can either lay the Wii flat or sit it on its side. If you’re laying it flat, move on to step 2, Connect the Cables. If you want to place the Wii in a vertical position you should use the Wii Console stand, which is the gray base unit. Attach the console plate to the bottom of the stand, put it on your shelf and then place the Wii on it so the beveled edge of the console aligns with the beveled edge of the stand.
There are three cables that connect to the Wii: the AC Adapter (a.k.a. power cord); the A/V connector (which has three colored plugs on one end); and the Sensor Bar. The plug of each is distinctly shaped, so each cable plug will only fit in one port in the back of the Wii. (The two small, same-sized ports are for USB devices – ignore them for now). Plug the AC Adapter into the largest of the three ports. Plug the Sensor Bar plug into the small red port. Plug the A/V Cable into the remaining port.
To connect your Wii to your television, find the sockets on your TV that, like the A/V Cable, are colored yellow, white and red. The sockets are generally on the back of the TV, although you might also find them on the side or front. You may have more than one set of ports, in which case you can use any of them. Insert each plug into a port of the same color.
The sensor bar can be placed either on top of your TV or right below the screen, and should be centered with the middle of the screen. There are two sticky foam pads on the bottom of the sensor; remove the plastic film covering them and gently press the sensor into place.
Next, simply plug the AC adapter into a wall socket or a power strip. Push the power button on the console. A green light on the power button will appear. The remote comes in a rubber jacket, designed to protect it, which you will have to partially peal off in order to open the battery door. Put in the batteries, close the battery cover and pull the jacket back on. Now push the A button on the remote to make sure it is working (a blue light will appear at the bottom of the remote).
The Wii remote that comes with your Wii is already synced up, meaning your console will communicate properly with the remote. If you have purchased any additional remotes, you’ll have to sync them up yourself. To do this, remove the battery cover from the remote and press and release the red SYNC button inside. Then open the little door in the front of the Wii where you will find another red SYNC button, which you should also press and release. If a blue light goes on at the bottom of the remote then it is synced up. When using the remote, slip the Wii remote wrist strap around your hand first. Sometimes when people are waving their remote around it slips out of their hand and breaks something.
Turn on your TV. Set your TV input for the input channel your Wii is plugged into. This can usually be done through a button on your television remote generally called “tv/video” or “input select.” Read any onscreen text. This will be either a warning, in which case you can press the A button, or a request for information, such as whether the sensor is above or below your TV and what the date is. Point the remote straight at the screen. You will see a cursor similar to the mouse cursor on a computer. The “A” button does the equivalent of a mouse click.
Once you have answered all the questions you are ready to play games. Push a game disc into the disc slot; the illustrated side of the CD should face away from the power button.
The main Wii screen shows a bunch of TV screen-shaped boxes, and clicking on the top left one will take you to the game screen. Click the START button and begin playing.
Feb 15, 2010 | Samsung LN-S3241D 32 in.LCD HDTV
Pressed 'D/A' button on remote and tv and tv has stopped working
This is the Digital/Analogue input choice. The TV has probably locked up due to a signal failure, try switching the TV off from the mains electical plug, leaving it for 30 seconds, then plug the TV back into the mains socket & try switching it back on.
Jul 08, 2009 | Televison & Video
LG 15LW1R 15 in. LCD Television Logo
469 people viewed this question
Computer Repairing
Computer Repairing
