Question about Keurig Single Serve Ultra Brewer
Need Keurig B3000 Cups & Pivots
I have 3 commercial B3000 that needs cups. I am willing to buy 6 if I can find them. Looking for a solid source for parts and troubleshooting commercial brewers. Great machines. Poor Repair Center or Support for Keurig commercial equipment. Why do these cups keep breaking? How can I prevent the cups from just coming off the hinges? Please let me know!
    Champion:
  • 213 Answers
My Keurig only brews a part cup
Most likely you need to change the filter and descale it as well.
I use a CleanCup once a month:
https://www.amazon.com/CleanCup-Single-Machine-Cleaning-Capsules/dp/B00E0QAS34/ref=sr_1_1?ie=UTF8&qid=1480095410&sr=8-1&keywords=keurig+cleaner+cup
I change the filter once every 3 months:
http://www.keurig.com/Accessories/6-Pack-Keurig%C2%AE-Water-Filter-Cartridge-Refills/p/Water-Filter-Cartridges
And I descale it every time I change the filter using this:
http://www.keurig.com/Accessories/Keurig%C2%AE-Descaling-Solution/p/Keurig-Descaling-Solution
Otherwise, the tubing is going to get clogged up in your machine and produce smaller and smaller cups of coffee, not to mention, when you keep your machine clean, your coffee will always taste its best!
Hope this helps!
Nov 25, 2016 | Keurig Coffee Makers & Espresso Machines
It's the Mini. Just dribbing and not filling more than 1/3 of the cup
It might be time to clean your Keurig. Fill the water tank with vinegar and run through 5-6 glasses after that it should start brewing regular sized cups again.
Apr 04, 2015 | Keurig Coffee Makers & Espresso Machines
Adjust water level. electric control turns off early.
It may need de-scaling. When my Keurig did what yours is doing, I filled the reservoir 3/4 way with white vinegar, and ran the machine repeatedly until it all passed through. I then re-used that vinegar and did the whole pass through 3 more times. that cleared it up. Did that 9 months ago. Use: 6 cups/day.
One other source of this problem are the metal pieces that punctures the top and bottom of the K-cup. Coffee grinds can find their way in there, and can be cleaned out with a paper clip or mini-pipe cleaner. But clogging of the bottom puncturer usually results in overflow, unless the top is also blocked.
Good Luck
Jan 01, 2015 | Keurig Coffee Makers & Espresso Machines
Keurig problems
what is your model and serial num ?
Sep 02, 2017 | Coffee Makers & Espresso Machines
Regardless of setting, I have not been able to get any more than 1/4 to 1/3 of a cup of coffee. The water barely comes out and now the descale message is on the screen. I need instructions for...
Although this is in "Problem with Vacuums," I found it while searching for a solution to my steam cleaner vacuum problem. You must be talking about a Keurig or Breville-Keurig coffee maker. Tap water, especially chemically softened tap water, contains minerals that require periodic descaling, as often as every two months if you make only a couple of cups a day.
Filling the tank with white vinegar and making multiple large mugs without a Keurig coffee cup in the holder will remove most scale. There are products that claim to do better than white vinegar if this does not work. Amazon sells a couple of brands in its Keurig section.
It will take several tank fulls of clean water to rid the machine of the vinegar or commercial cleaning solution. Use distilled water for this. Then switch to good bottled water without a heavy mineral load.
Jun 13, 2011 | Vacuums
Am looking for the part that holds the K-cups, have lost it and can't seem to find site where I can buy another
if you are talking about the black part, there is this site that sells them, they sell all kinds of keurig parts http://stores.ilikenew.com
Jun 12, 2010 | Keurig B60 Coffee Maker
I broke the peice that puts water through the coffee basket on a Keurig Elite B40 Coffee Maker where can I buy parts for this?
If you are talking about the K-cup holder that punches the bottom of the k-cups, they usually are not for sale, and you can only find them on ersale sites like Ebay.etc...
you could also go buy a "Keurig My K-Cup Reusable Coffee Filter"
and just use the main grey plastic filter holder... but you will have to puncture the bottom of the k-cups yourself before dropping them into the holder...
You wont need the filter basket or the lid if your using k-cups... just the filter holder...
dont forget to punch a hole in the k-cup first...
May 14, 2010 | Keurig Elite B40 Coffee Maker
Trying to locate the Keurig plastic holder that the commercial K-cups fit into
If you’re looking for Keurig Parts, you can find them on this website.
http://www.igotsweetdeals.com
most parts for Keurig b30, b40, b50, b60, b66, b70, and b77 In stock.
Apr 17, 2010 | Keurig B50 Coffee Maker
Keurig Special Edition B60
I assume your coffe maker used to produce more coffee for each use. Roughly 6 ounces per large cup, and now is only making 3 oz. cups.
If your coffee maker is sputtering and not able to "suck" enough water to fill your cups of coffee it is most likely due to cavitation caused in the little pump due to a stoppage, which is most likely lime or scale buildup somewhere in the pump line.
To fix it, don't take your coffee maker apart. Get a bottle of distilled white vinegar, and pour it straight into the empty water resevoir. Press brew with no coffee pod so you are just running the vinegar through the system. Pour the vinegar out of the cup and back into the resevoir. Add some ice to cool it off. Repeat about 10 times. This should clear out the toughest lime scale clog.
After you notice the cups are filling full of water, Replace the vinegar with fresh water. Run about 5 or 6 cups of fresh water through the system to get rid of the vinegar.
Make coffee/tea/whatever.
Jade
Oct 06, 2007 | Keurig Special Edition B60 Coffee Maker
Coffee Makers & Espresso Machines Logo
430 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
