Question about Westinghouse LTV-32w3 HD Television
Freezes during auto programming
When I use the auto scan for channels the tv locks up at 85%. It gets all the way through the regular channels and starts on the digital channels. I have had the tv for about 3 years but just noticed it when I tried to add channels without using a cable box.
  • fusionx22 Apr 24, 2009
    I have a Dynex DX-LCD32 and mine locks up at 79%. It used to work fine, but then all of a sudden, it stopped. Any ideas?
  • 92 Answers
The atsc or qam tuner in your Westinghouse LTV-32W3 HDTV is malfunctioning and needs to be replaced. Unfortunately you will need to purchase a new mainboard since it is integrated. Another option is to return to using an external tuner like your cable box.
Posted on Feb 07, 2010
What do i need to get regular channels on the tv
How to get regular TV channels?
Your HDTV should have a digital TV Tuner (ATSC) which may need an indoor antenna. Change your TV's input selector to TV or Antenna or Digital (probably one of those three) and scan for channels. If you don't get any channels, then you do need an antenna. Probably another $10.
How to get basic channels on new HDTV without cable - HDTV ... What do need to get regular channels on the tv Google Search
Dec 12, 2016 | Televison & Video
If there is no channels after scanning is it the outside antenna?
Do you see any channels [as a glimpse], during auto-tune. If you see them for a moment during channel auto scan, and do not store them in the TV memory, after the channel scan has been finished; the fault is with the TV itself. If you do not see that glimpse of programs during channel auto scan, there are two possibilities.
1. The tuner of the set is faulty.
2. The set do not get any signal to process [might be antenna].
Aug 14, 2016 | Televison & Video
19" Element HD Digital LED TV Model ELEFW195 Does not scan Digital Channels just Analog Channels.
Auto-channel search can't find digital channels - Community ...
Aug 6, 2010 - When I ran the auto-channel search it could only find 4 analog ... Notgetting Digital Channels on NS-26L450A11 ... I've plugged the cable from the wall into the TV, and preformed the auto channel scan, with "cable" selected.
Troubleshooting Guide for Digital-to-Analog Converter Boxes
Federal Communications CommissionIf you aren't receiving digital signals on your analog TV, you can purchase a ...antennas are designed only for reception of either VHF or UHF signals (but not both). ...The channel scan will automatically search for digital broadcast channels ...
Antennas and Digital Television ' Federal Communication
Jan 13, 2016 | Televison & Video
I have an Element ELEFT502 50 HD Digital tv. I am trying to connect my cable line to the TV but cannot get the past the auto scan screen
put the co axel cable in the back , bypass this tv programming stuff put your tv on channel 3 or 4 and use the cable remote , no tv channels just cable
Feb 26, 2015 | Element Televison & Video
Why will my new tv not pick up any channels when using the auto channel search
It depends on if you have cable or are using an antenna. If you have cable, make sure you have the cable that runs in between them hooked up to the correct spots. If you're using an antenna, you might need to get a TV converter box. A couple of years ago, they stopped making regular TV channels and switched to only digital channels. Most older TVs don't work with digital channels, so you need a box that will convert the picture. You can get one at any place that sells TVs (walmart, amazon, etc)
Feb 02, 2015 | Televison & Video
Whilst watching digital channel, tv suddenly said channel not tuned. Same problem with all channels. Now comes up channels not stored, and when trying auto start up, says no channeels found.
Ur tv,u are using and getting a over the AIR free broadcating tv channels signal wright?Ur antenna are using,have problems might not work anymore in ur area.Tries manual channels scanning ur tv should get it back or buy a better antenna deign like a Digital antenna design for a hook it up for a better signal prob and longer signal ranges tries scanning for Free over the AIR channels again should solved this problems.
Aug 27, 2011 | Sony BRAVIA KDL-46V3000 Television
I can only get channels 600 through 900 which I have never see before.I cannot get regular channels or cable channels.It is not a flat panel t.v.Q1435A is the model number
Hi -
If you have a cable TV line connected directly to the TV, an antenna or a cable box connected by coaxial cable, I would suggest running the automatic channel scan (AUTO-PROGRAM) again:
1. Press the AV key on the Advent remote control repeatedly until TV is displayed in one corner of the TV screen. If you don't have the Advent remote, use the TV/AV button on the front of the TV.
2. Press the MENU key on the advent remote or the front of the TV to open the on-screen menus.
3. Use the CH+/- keys on the remote or on the front of the TV to highlight PRESET then press VOL+ to select.
4. Use the CH+/- keys on the remote or on the front of the TV to highlight ANTENNA then use the VOL+ key to select either AIR (for antenna) or CABLE.
5. Use the CH+/- keys on the remote or on the front of the TV to highlight AUTO-PROGRAM then press the VOL+ key to start the automatic channel scan.
Once the channel scan is complete, the TV should automatically return to viewing the first channel found during the scan. Do not press the MENU key during the scan or the scan will not complete.
If you are using a cable/satellite receiver and it is connected to the TV by any means other than a coaxial cable, you do not need to run the channel scan. You should simply select the correct AV input using the AV key on the remote or the TV/AV key on the front of the TV (see step 1 above).
If you have done all of the above and you are still unable to get the channels on your TV, please post back for further assistance. You can reply to me by clicking on "Add a Comment" below your question. Please let me know whether you are using a direct cable line, antenna or cable box, etc.
Mar 26, 2011 | Televison & Video
How do I retune my Panasonic Viera TV?
To tune your Panasonic Plasma to on air TV channels do the following:
Connect the antenna connection to its antenna in at the back panel.
Automatically searches and adds available channels to the memory.
Select "ANT in"
Select Cable or Antenna Select "Auto"
Select a scanning mode
Auto channel setup
Select "Auto program"
Select "ANT in"
Select "Auto"
Select scanning mode (ALL channels/Analog only/Digital only
Start scanning the channels
Available channels (analog/digital) are automatically set.
All channels: Scans digital and analog channels
Analog only: Scans Analog channels only
Digital only: Scans Digital channels only
Confirm registered channels
If OK is not pressed after selecting "Apply", the channels will not be saved.
The channel will be saved when no operation is performed for 60 seconds and
the "Manual program" menu will also exit automatically.
If you perform scanning more than twice, previously saved channels are erased.
About broadcasting systems
Analog (NTSC): Conventional broadcasting
Digital (ATSC): New programming that allows you to view more channels
featuring high-quality video and sound
[Use "UP ' DOWN ' RIGHT ' LEFT] AND 'OK"] keys to selcet and proceed.
Mar 07, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
How to tune channels first time when you purchase a new Sony Kdl 32EX600 LED tv?
Do connection to the antena if you wants to set the TV auto tuned.
During this initial setup, you can perform the following:
1 Select the language for the on-screen display text.
2 Select HOME or Retail mode. [Here you have to select "Home" mode if the set displays "Retail"
3 Connect cable or antenna, then select OK to run Auto
• If you have cable and antenna available, please connect cable first.
• IMPORTANT: Auto Program is only effective when cable or
antenna is connected. If you cancel Auto Program before completion some channels may not be
4 Auto Program will scan for available channels from the signal source directly connected to
the TV's CABLE/ANTENNA input and may take sometime to complete the process. Follow
the help text provided on the screen to run Auto Program.
Feb 23, 2011 | Sony KDL40EX600 TV
There is no local channel,cable only international..i lost my manual,
Here is the procedure for auto tuning. Pleas go through it. Connect the antenna to the rear antena socket marked as &% ohms antena and continue.
If you have already run the Auto Tuner as part of the quick setup earlier in this guide, please
skip ahead to "Channel Summary" to continue setting up your television. In Auto Tuner Setup,
the TV automatically scans through all available channels, memorizing the active ones and
skipping over blank ones or channels with weak signals. This means you scan using the
CHANNEL +/- buttons), you will receive only clear active channels.
Press the MENU button
?® To operate
?® To choose CABLE or AIR
Press the OK button to start
Initial Setup
Auto Tuner Setup
Programming will take approximately 1 to 2 minutes. The auto tuner is finished when the
message PROGRAMMING OVER! appears onscreen.
Channel Summary
Channel summary allows you to customize the line-up of channels received by your TV. You
can add or delete channels from the line-up or prevent any unauthorized viewers from watching
any or all 181 channels.
?® To operate
The Channel summary screen will now be displayed with
the channels set to scan marked with an "?". You can delete
channels from the scan by removing the "?". If any channels
were missed during auto tuner setup and you wish to add
them, you may by placing an "?" next to the channel number.
?† ?® To the SCAN column
Press the OK button to include or delete from scan
Press the MENU button when finished
You can block access to a channel by activating the channel lock.
?® To operate
?† ?® To the Lock Column ( )
Press the ZERO button to lock or unlock that channel
If you wants any codes, contact me through Fixya. Ok
I'm quating these procedure from the manual I've with me, and it is for JVC AV32S565.
Nov 08, 2010 | JVC AV-32S575 32" TV
Televison & Video Logo
372 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
