Question about Kodak EASYSHARE G610 Thermal Printer
Can't connect printer to computer
Hav followed all directions with ubs cable and power line. what is green light on power cord
  • 2,120 Answers
The green light tells you only that the AC adapter is GOOD.
Posted on Feb 10, 2009
  • Leroy Elliott
    Leroy Elliott Feb 10, 2009
    The answer is on page ID 10t
On the power and reset it for 15 sec wait for the green to light up but the green light dont light up . keep lighting orange light keep on light up. pls help
switch off your printer. remove power cord from its main source and remove usb cable connection from printer to computer. wait for 5 minutes then connect back the usb cable to you computer and plug in the power cord ,switch on the printer
Sep 02, 2015 | Office Equipment & Supplies
Printer won't turn off
Check the power supply cords; make sure they are attached properly. If you are using a power strip, surge protector or any other device where the power supply cord is not plugged directly into a wall outlet, bypass them and plug the printer into a wall outlet; see if that changes anything.
If that doesn't work, remove the printer's power cord from the outlet and all the other cables that the printer connects to the computer to.
Wait 5 or 10 minutes for the printer's CMOS and RAM chips to power off completely.
After enough time has elapsed, plug only the printer's power cord into the wall outlet (do not hook up any of the communication cables in e.g. USB, or serial cables, or network cables.)
Then press the power "on" button.
If the error message is gone, power off the printer.
Uninstall the printer and all its programs from the computer.
Do a clean install and follow the procedures of hooking up the printer as though you are installing it for the very 1st time.
You may have to obtain firmware and/or software updates from HP on your specific printer.
You may also have to check with your OS vendor to make sure you have all the updates/service packs on your PC or laptop
Nov 23, 2013 | HP Photosmart C7280 Printer
My green light wont come on . i have a lexmark 5300 series printer
Please go through the following checklist
- Make sure the power cord is plugged in securely and directly to the power outlet. Power surge protectors can draw power away from the printer.
- Disconnect the power cord from the power outlet and the back of the printer and then reconnect it.
- Check the power supply box (if there is one) to see if it is warm or cold, as there could be a defective power supply issue.
- If there is access to a voltmeter, test the power supply to ensure that it registering the correct amount of voltage (most Lexmark printers have a 30Volt output).
- Make sure the correct power supply is connected to the printer.
Source: The Printer is Not Powering On
May 04, 2011 | Lexmark All-in-One Printer, Scanner &...
My Lexmark C544dn laser printer just up and died - I had just put in new paper, hit print on my Mac and when nothing happened, I realized the machine was off. Yes, I checked the power cord at the machine...
Please try to do the following steps
• Check the AC line voltage. Is the line voltage correct? If not connect it to the correct line voltage
• Check if the AC line cord damaged. If damaged replace the AC line cord
• Is the LVPS cable correctly connected at JLVPS1 on the controller board? If not Reconnect the cable at JLVPS1
• Turn the printer off, and then on. Does the problem persist?
• Damage to the printer is possible. Be careful to touch only one conductor at a time, Rest the probe against the connector to steady it.
• Replace the LVPS - Low-voltage power supply (LVPS)
Please contact Lexmark Technical Support for further assistance.
Mar 26, 2011 | Lexmark C544dn Laser Printer
Both the orange and the green lights are blinking and printer will not print.
The printer is waiting to receive a document to print. Choose the print command from the software program that you are using.
Wait for the printer to complete the current task.
If the printer continues to blink after several seconds, follow these steps:
    1. Turn the printer off, and then turn it back on.
    2. If it does not turn off, unplug the power cord from the back of the printer.
    3. Unplug the power cord from the power source. Wait 30 seconds.
    4. Plug the power cord into the back of the printer.
    5. Plug the power cord into the power source.
  • Restart the computer and the printer. Try printing again.
  • Make sure there is a direct connection from the printer to the computer. Remove scanners, switchboxes, and so on.
  • Try another cable.
  • Try connecting the printer to another computer. If the printer prints, then the problem was with the main computer, possibly a software or device conflict
Aug 11, 2009 | HP DeskJet 5550 InkJet Printer
My computer cant find my printer its a lexmark 2600
Have you tried the following steps?
1. Power off your computer.
2. Power off the printer and remove the power cord.
3. Check the cable connection between the printer and the computer to make sure it isn't loose.
4. Put the power cord back in the printer and power it up. Do all lights show up as normal? Green? Or are some flashing?
5. Power on your computer.
6. Under the printers folder, right click the installed printer and go to properties. Print a test page.
How is the printer connected? USB or parallel port?
Apr 19, 2009 | Office Equipment & Supplies
I brought a DCP -7030. I could not use the scanner. The last step was not complete. It was failure connection between computer and printer. UB cable ok.
1)right click the my computer icon
2)click properties and then click hardware n go to device manager.
3)uninstall all usb ports and then scan for hardware changes
4)ur pc will detect your printer and ask for printer drivers
5)re load drivers and your pc will communicate with your printer
6)for reloding install the cd follow the instructions on the screen and click next
7)restart when the printer is loded.connect the wires and cords properly.
Nov 29, 2008 | Brother Office Equipment & Supplies
Screen was all fuzzy and red ring was at bottom right side!
from the description you stated it sounds like the following error code
E74: AV cable error... There is a problem with the AV cable, try using a different AV cable. If the cable is known to be working then there is a 90% chance it's a scaler chip problem (the "ANA" or "HANA" chip connected directly to the AV cable) in rare cases it is the GPU.
  1. Try restarting the console.
  2. If restarting the console does not resolve the behavior, follow these steps:
    • Turn the console off.
    • Unplug all the power and AV cables from the console.
    • Unplug the power cord from the wall socket.
    • Firmly reconnect all the cables.
    • Turn on the console.
  3. Also examine the lights on the power supply. When you turn on the console, the power supply light should illuminate green
try that and if nothing works I have more to follow.
Sep 16, 2008 | Microsoft Xbox 360 Console
Copier not coping documents placed on the copier. In addition, when coping from the computer it only copies part of the document.
If you are able to print form the computer.
Then follow the following steps:
Take out both the cartridges from the printer and unplug the power cable from the All-In-One and the wall outlet.
Leave the power cord unplugged for at least 1Mins time.
Connect the power cable directly to a wall outlet without a surg protector.
And before connecting the power cable back to the All-In-One press and hold the # and No 6 button and connect the power cord do not release the keys untill you see a message as Semiful reset.
And if the unit is turned Off then release the keys and turn the power on and try copying or printing.
Good Luck
Aug 31, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Kodak EASYSHARE G610 Thermal Printer Logo
81 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
