Question about Maytag Washing Machines
Performa washer smoking and smell of burnt plastic
Two different times my wife has said that are performa washer was smoking and smelled like burnt plastic. boyh times i have looked it over and cant find any problem. we turn it back on after sittin awhile and it seems to work fine but this concerns me any help would greatly appriciated
  • Maytag Master
  • 3,463 Answers
It could be the pump or the motor overheating.
Remove rear panel, and run washer through a rinse and spin cycle.
After it has finished, unplug the washer, and feel the pump and the motor, they should be relatively cool to the touch.
If either the motor or pump feel hot, then that is probably the cause of the problem.
Also check for a worn or slipping drive belt.
Please rate my fixya solution.
Thanks.
Posted on Feb 09, 2009
I wrongly plug jensen jta 460 turntable to 220volt power outlet. Can it be repaired? What is the dc out put of th?s power adapter? Can I change this original adaptor with 220volt ac dc adaptor?
Depends on how big it is, probably not, either the transformer coils might be burnt, causing a short (did you see or smell magic smoke?), or the diodes might be burnt (did you see or smell magic smoke?) or capacitors might be blown (did you see or smell magic smoke?)
As far as a different adaptor, see my response to your other question:
http://www.fixya.com/answer/answerpageslideview.aspx?ctg=mine&fml=0&brd=0&p=2&thid=25839291
Aug 27, 2015 | Computers & Internet
2000 buick lesabre ac compressor smoking/not working
either way i wd. replace the assembly! ck. alll the idelers and tentioner pulleyys
Jun 06, 2012 | 2000 Buick LeSabre
MAYTAG PERFORMA MODEL# PAV2300AWW, REVISION#12, SERIAL#12296390ZM Washer filled but made loud grinding sound while agitating. I couldn't drain water on spin cycle. Now it has stopped working, I smelled...
hello you need to change drum rollers but if u remarked water dawn the washer and burn smell it could be the motor OR THE BELT because when the drum stop turning or turn slowly the motor turn fast on the belt when spin time it make this smell .
Sep 11, 2010 | Maytag Performa PAV3200
MOTOR SMELLS OF BURNT MOTOR WINDINGS. iS IT NORMAL
No, the pump works while spinning. The burnt smell is probably the belt, especially if your wife saw smoke. Did she put a big load in it at the time?
The belt will slip until the tub catches up with the motor. If there is a heavy load, it can burn the belt up. I would replace it. Make sure the idler pulley on the motor moves freely also.
http://www.partselect.com/MultiModels.aspx?ModelNum=ALW480DA&searchTerm=&RefineSearch=0
Jan 22, 2010 | Amana ALW480DA Top Load Washer
Washer is making a loud noise when its trying to rinse
you will have to open up the panel to check where the smell comes from. It could be on the motor which may cause also a loud noise or from the electrical, loose connection or bad relay may cause a noise of a different kind.
Sep 21, 2009 | Maytag Performa PAV3200
My dishwasher smells like an electrical fire!
the smoke could be plactic silverware that fell on the heating element,or a plastic lid. this is not an easy fix.sometimes it is more cost effective to replace a unit than to repair it.good luck with yuor project.
Aug 04, 2009 | Maytag JetClean II MDB8551 Built-in...
Acrid smoke emanating from the refrigerator
Check and see if the smell is coming from the bottom back of the frig by the compressor, this models start device on the compressor has been known too do that.
Mar 19, 2009 | Whirlpool ED2FHEXMS Side by Side...
Washer stopped filled with water, smells like burnt plastic
REPL/ PUMP BURNT PALSTIC SMELL ,AND RUBBER SMELL, ONCE REPL./ SHOULD FIX
Nov 29, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Dryer smelled of burning plastic, smoked stopped turning on
check the power cord itself, if you see on the back side of the cord a burnt or blackened spot then the cord is the issue
Apr 12, 2008 | Dryers
Washing Machines Logo
202 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
