Question about Cuisinart CBK-200 Bread Maker
I can't get the Menu to change from 1 to anything else.
I put the ingredients in the pan, put the pan in the machine, and plugged it in. It immediately started to mix! So, I hit the "Pause" button. It won't let me change to a different item on the Menu. So, I looked in the book that came with the machine for some help. There was nothing. So, now I am on line.
The machine started to run again, so I unplugged it. What do I do now? I'm afraid my bread will be ruined! Help!
  • 8,596 Answers
Hold in the stop/pause button for about 15 seconds - it will reset the breadmaker. Then you should be able to make your selections. Unplugging the breadmaker for longer than 15 minutes will also reset it.
-Tha Mp3 Doctor
Posted on Feb 14, 2009
Is there anything I can do?
I don't know about your specific model, but in most bread makers there is a removable paddle that goes in the bottom of the bread pan after you put that in the machine. The paddle usually has a flattened side on the hole which slides on to the post sticking up from the bottom of the machine. If you look at the post straight down from above it should be D shaped. The usual procedure is to put the pan in the machine, install the paddle, and then add your ingredients. Assuming you are doing this and it is still not working, trying running it through a mix only cycle (like for pizza dough) with the machine empty to see if the paddle is engaging and spinning properly. If it is not, contact the manufacturer for assistance.
Aug 08, 2014 | West Bend 41053 Bread & Dough Maker
How do I know my breadmaker is working, I set it at #7 for sweet
Some bread machines warm the ingredients before starting. If your machine hasn't started within 30 minutes of you pushing the start button then your machine may be broken. google me at
Daryl Wayland Nash if you need more help
Nov 11, 2013 | Sanyo SBM200 Measuring Kit Bread Factory...
When I plug in the machine I get at dash and 2 zeros. The directs say I should see 3. I cannot get it to do anything else. Do I have a lock somewhere?
without any ingredients in the pan....after plugging in your machine,,,,push "select" button.... choose program #1.....this is the basic white bread push the "start" button... your machine should start mixing either right away or within 15- 20 minutes...if it does then your machine is functioning properly.....
May 09, 2011 | Breadman Kitchen Appliances - Others
The first time i tried my bread maker i can't get the settting to work at all what did i do wrong
press clear until beeps......unplug..... remove the pan from the machine....put all the ingredients in....yeast goes in last....put the pan back in the machine....plug back the "select" button.....choose the program you want....choose the loaf size....choose the crust color......push "start" relax your bread will be ready in about 3 hours.....
Feb 22, 2011 | Sunbeam 5891 Bread Maker
After placing the pan full of ingredients inside the bread machine, I get a quick "beep" when I plug in the machine. I can get a flash of numbers on the screen. I have tried different outlets and...
What you are describing doesn't sound abnormal. Just put all your ingredients in per your recipe. After it beeps just choose your program, loaf size, crust color and then push start.
Nov 23, 2010 | Sunbeam 5891 Bread Maker
Needing the recipe for white 3lb sandwich loaf for the all in one model B2300. Lost the manual and there is nothing online
Hi Lyndseycoone:
Here is the recipe from the manual
3 cups of water (80 to 90 F)
3 tbsp butter or margarine, cut into pieces
1 tsp salt
3 tbsp dry milk powder
4 tbsp sugar
5 1/2 cups bread flour
1 1/4 tsp active dry or bread machine yeast
1. Measure ingredients into bread pan in the order listed
2. Insert bread pan into unit, close lid. Plug unit into wall outlet
3. Select Sandwich setting and appropriate loaf size (3 lb)
4. Press start button
5. The Complete Signal will sound when bread is done.
6. Using pot holders remove bread pan from the unit and carefully remove bread from pan and turn right side up. (Kneading blade may remain in bread. Remove blade when bread is cooled.
7. Allow bread to cool on wire rack until ready to serve at least 20 minutes.
Hope this helps...
Nov 06, 2010 | Black & Decker B2300 Bread Machine
Need the operting Manual for PerfectBaker PB571
Here's some info;
Here is some operating instructions one baker used for this machine;
But here's how to actually use it:
Put wet ingredients in loaf pan. Heap dry ingredients on top. Make a well in dry ingredients and add yeast, ensuring it doesn't touch liquid if you want to use the timer. Put pan in breadmaker, clicking into place.
Plug in breadmaker but DO NOT touch the on/off button till the very last.
Using the "menu" button, choose what type of bread you're making (the top two rows -- normal, fruity etc).
Using the "crust control" select how dark you want your crust.
Using the "timer" select how long till you get the finished product. The minimum is 3 hours for quick bread/medium crust, which I often use, the maximum 14 hrs 30mins. It goes up in 30 minute increments with each push of the up arrow. Remember, what the timer shows is when the finished bread will be ready.
Once you're satisfied with your settings, press on/off
If you choose "fruity bread" the timer will beep into the kneading process to tell you it's time to add the fruit. It goes in at a later stage.
When the bread is finished, it will keep on a warm cycle for a while until you switch it off.
I use high grade flour and add 1 tsp gluten flour to each cup of flour. The bread rises more.
Apr 25, 2009 | Breadman TR888 Corner Bakery Bread Maker
Need to make gluten-free bread
bobs redmill gluten free mix for bread machines. we just use the standard bake setting but select B for doneness level. found it gets a little too dark on A.
Mar 20, 2009 | Toastmaster 1183N Bread Maker
How do I set the dough setting on the machine
Once you have your ingredients in the pan and the bread pan in the machine you close the lid and plug it in. Now you need to push the menu button until # 8 displays in the left hand side of the display screen. This is the setting for the dough cycle. The cycle time will display to the right of the cycle number, they will be in bigger numbers than the dough cycle number. The time is 1:30 for a 1.5 lb loaf and 1:40 for a 2 lb loaf. Now you need to select the crust colour and the loaf size. Now press the start button and the cycle will start. I have included the link to the owner's manual in case you don't have one. I hope this helps you. Good luck!
Feb 02, 2009 | Black & Decker B2250 Bread Machine
Regal ware k6751
Look at the box first. Many times it will have instructions on it. However sometimes it may not and have only the the dry ingredients. If the box has no instructions, see how many cups of flour the mix uses. If it uses 3 cups of flour total, the mix is for a 1 1/2 pound loaf. If the mix uses 2 cups of flour it will make a 1 pound loaf. Box missing this info? It's time to take the flour out of the box to measure it with at measuring cup. Mixes sometimes combine all the ingredients together so it will measure bit more than 3 cups for a 1 1/2 pound loaf or 2 cups for 1 pound loaf. After finding out how big the loaf is going to be then get the bread pan and instruction manual and start constructing the dough. I'd find the recipe in the manual that matches the mix the best to find out how much liquid to use. (for a classic whit its 1 cup for 1 1/2 pound leaf and 3/4 cup for 1 pound loaf) Then I put the liquid in the pan first along with butter (if necessary), followed by the dry ingredients in the mix with the yeast at the top. Put the pan into the bread machine and select 1 or 1 1/2 loaf or if it is a french or sweet bread. Press start. Unfortunately I have a different machine than you do, but I think this will help.
Jan 15, 2008 | Regal Ware K6725 Kitchen Pro Bread Maker
Cuisinart CBK-200 Bread Maker Logo
555 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dale Anderson
Dale Anderson
Level 1 Expert
Tom Chichester
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
