I have no Heat yet 220 receptacle has got 110 to each leg and is hooked to a single double breaker. Everything works but no heat. Is there a fuse inside I can Check
Thanks Mike
Yes Mike there is. First check the wiring to the back of the dryer and the terminal block inside the back. The likely problem however, is a thermal overload switch located underneath the top of the dryer at or near the drum. You can bypass it and see if it works. If so, replace it for abotu 20 dollars. If not, your next area would be the element itself. Check it for continuity or take it out of the cage and visually inspect it. I am assuming the drum does work and is turning but like you said, no heat. Let me know about this and we will go further. Hopefully, this will take care of it.
Which way should the drum be turning clockwise or counter clockwise and what is the part number of the thermal overload switch.
Thanks Mike
