Question about Kenwood KVT-512 Car DVD Player
How do i connect my itouch to kenwood kvt-512???
Im having problems connecting my itouch to the stereo, the thing is that i dont know if i need a special cable or i just hookup the one that came with the ipod to the USB.....
Can I connect my itouch to a portable DVD player.
Posted on Oct 12, 2009
Hi there! You need a Kenwood KCA-iP300V iPOD VIDEO DIRECT CABLE.
Posted on Feb 11, 2009
Ive got a kenwood kvt-512 n im tryin to hook an amp n subs up but dnt know where to plug my RCA jacks from the amp 2 the radio!
Your unit should have 2 plugs in the back...one for the audio and power wires to connect to your factory connections and the other plug is just RCA connections for your video, subs and front speakers. If you have a 4 channel amp and a amp for your subs, you will have to split the 4 channel amp down to 2 and run them to your front RCA connections. Subs will connect to the sub connections. If yours are not listed then you may have to track down a wiring diagram. Hope this helps.
Jun 12, 2011 | Kenwood KVT-512 Car DVD Player
I got a kenwood kvt-512 and my ipod seems like it doesnt work ?
go to :- http://kenwood.com/cs/ce/mm/firmware/2008/eng.html
then change the file to an iso and burn to a disc.
put the disc into stereo and press dvd and let the disc do the rest.
hope this helps works on all kvt systems
Dec 31, 2010 | Kenwood KVT-512 Car DVD Player
KVT-512 Car DVD Player: Battery was disconnected ans car stereo locked out...
Sorry...KENWOOD codes are only available from the Main Dealer or a Radio Decoding Service
May 17, 2010 | Kenwood KVT-512 Car DVD Player
I plug my ipod to the stereo but my stereo screen still says discconected
you have to go to the kenwood site and download the firmware update go to this page http://www.kenwood.com/cs/ce/mm/firmware/2008/eng.html
after you download the file unzip it and burn it with either nero or roxio, as a data file insert the cd on your kvt-512, if it reads DISK ERROR, press the reset button on the front of the stereo, once the screen comes back up select the DVD function, the system update should start from there. let it finish once it does then you'll be able to plug in your ipod. oh and ofcourse for this you should know that you need the ipod adapter, depending on what you want to do with it for instance i have the KCA-iP300V which allows me to view videos from my ipod as well.
Jan 27, 2010 | Kenwood KVT-512 Car DVD Player
Kenwood KVT-512 iphone compatibility
Just ignore the airplane mode prompt and if your wiring is correct everything should work.
With my BMW I had to connect both the solid blue (pwr ant) wire and the blue with white stripe (p conn) to the solid blue wire from the factory harness.
It isn't obvious that either of these are needed as the KVT-512 has it's own power supply but the way most factory power amps are installed the power from the KVT-512 is not used and the car manufacturers power amp needs to be turned on.
If you are listening to the radio the pwr ant wire will turn on the power amp, this didn't seem obvious because the BMW doesn't have a power antenna. And when you are using the DVD player or the iPod connection you need the P Conn wire to turn on the car power amp as the ant pwr is disabled because you are no longer using the radio and Kenwood assumes you will not need the antenna so no power to this lead.
Solder all three wires together and you should have sound all the time.
Jul 01, 2009 | Kenwood KVT-512 Car DVD Player
Does anyone knows where to conect the dimmer wire of a kenwood kvt-514 or kvt-512??
Connect to the side light live. So when you turn the lights on it dims the display.
Jun 15, 2009 | Kenwood KVT-512 Car DVD Player
Bypass parking brake for dvd player Kenwood kvt 512
Just connect the purple safety wire to the car's ground location or to the other ground wires.
Dec 25, 2008 | Kenwood KVT-512 Car DVD Player
Need installation instructions
do you still ned the intructions on how to install your kenwood kvt-512??
Nov 20, 2008 | Kenwood KVT-512 Car DVD Player
How do i set up my bluetooth for my kenwood kvt-512. im trying to find the bluetooth app in the settings
The Kenwood 512 works with the Kenwood KCE-BT200 module. You need to have this box plugged into the main unit to work. If not, then Bluetooth will not be available. When you do have it connected, use your cellular phone to initiate the connection. when prompted on your phone for a passcode, it will be 0000. After successfully pairing your phone to the unit, you can access the telephone menu by holding the "FNC" key on the front of the Kenwood or pressing "TEL" from the source screen.
Aug 11, 2008 | Kenwood Car Audio & Video
Kenwood KVT-512 Car DVD Player Logo
621 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
