Question about Sylvania Televison & Video
Sylvania tv model sst4272 no vertical
My tv has no vertical, only a line going horizontally accross the center of the screen. I am looking for a schematic to determine which part has gone bad
    Problem Solver:
The LA78041 IC has failed. I replaced it twice before I cleaned the high voltage connection to the CRT. It was very cruddy from cigarette smoke. A high voltage discharge to the yoke takes out this IC. They are available for under $4.00 Good luck.
from Lincoln Hubbard at lwhubbard@cox.net
Posted on Mar 26, 2009
Horizontal lines accross the top of my TV they turn everything upside down when you look up on a video game like mountains and things and make normal Television fuzzy
the problem is in the Vertical circuit of the set, fold over and/or retrace lines at the top.
Problem will be either a bad vertical output IC or caps around it that are bad.
Unless you know how to solder and what to look for it will be a shop repair, if it is continued to be used this way sooner or later it will go to just a white line left to right in the middle of the screen.
Let me know if you need more information.
SD TECH
Nov 26, 2010 | Sylvania 6427FB 27" TV
Horizontal white lines 27A43.
You have some bad capacitors. They are located very near and next to your vertical IC. I would guess you would have to replace maybe four of these! Thanks for asking!
Jun 12, 2010 | Toshiba 27A43 27" TV
Black blob on bottom rh of screen,vertical & horizontal lines
The blob is a phisically damaged part of the LCD screen. Unfixable, the screen must be replaced and it will be expensive.
May 04, 2010 | Lenovo 3000 N200 Intel Pentium Dual Core...
My 15 year old Toshiba Televisiononly shows a narrow horizontal band in the middle of the screen. Sound OK.
Hiii fairley,
You aren't specsificly dercribe yor tv set.
For common TV horizontal problem ;i.e : White line accross the horizontal screen, horizontal band,etc..it's can solved by replacing the IC Vertical/Transistor, and olso to replace the cap nearest the IC.
For common TV Vertical Problem :i.e : White line at the center of the screen (top to bottom),Vertical band,etc...It's can cure by Replacing the Horizontal IC/Transistor,and offcurse the cap's.
Tha's what all I know....
Hope can help you to solved the problem.
Thank's
h3liax
Jun 22, 2009 | Toshiba 32A33 32" TV
Philips TV (old) showing a horizontal line in center of screen
Check for the cracked solder joints on the IC or dried capacitors on the vertical side
Mar 28, 2009 | Televison & Video
Line accross top of the screen with flashing black and white boxes
Thin white dashes on top of screen is PERFECTLY NORMAL. It is nothing wrong with the TV, it is the broadcast. What you are seeing is the very bottom of the timecode running. It doesn't happen all of the time or all channels. It usually happens with old 4:3 commercials predating "Digital TV." This is mentioned in your Users Manual. You should be able to adjust the horizontal/vertical position in the menu settings.
Jan 02, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sylvania 27 in tv picture
It sounds like your vertical has shrunk, causing the picture to look squashed. Most likely a bad component in the vertical output stage.
Dec 19, 2007 | Sylvania 6413TC 13" TV
Sylvania SRPD442: picture has lines and particles in it, can't make picture out
The fault can be the screen itself, or one of the driver boards for the screen. This has to be verified by trying the boards.
I don't know for your model if the backplane lamps can be replaced. In most of the models they can be.
Jerry G.
Nov 21, 2007 | Sylvania SRPD442 42 in. EDTV-Ready Plasma...
Sylvania srcd 223
it depend on what vertical ic was mounted your tv mainboard
Oct 27, 2007 | Sylvania SRT4127P TV
No vertical sweep
You might be able to take care of it yourself,you are corret when you said no vertical sweep,if you can identify the vertical IC it will be easy,you are looking for loose conections but by now it might have a bad vertical Ic and it needs to be replaced along with the safety resistor that power the IC,the ic should be mounted on a heat sink and the resistor should have low resistance,very straight forward repair and while you are there make sure and check for overheated areas and loose conections specially in the power supply , horizontal drive circuit and convergence IC's.Be careful you still have high voltage witch can be dangerous.
Sep 30, 2006 | Mitsubishi CS-35505 35" TV
Televison & Video Logo
212 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
