Question about Sewing Machines
Singer 750 how to rewind the bobbing? - Sewing Machines
  • 11,896 Answers
1. Push in indent (illustration 1) on hand wheel disc. This will stop the needle from moving.
2. Place spool of thread on spool pin.
3. Slide spool pin holder/cap (illustration 2) firmly over rim of spool to prevent thread from tangling.
4. Lead thread passing it first through the lower slot of the thread guide. Next through the upper slot, leading the thread to the right and around (illustration 3).
5. Wind thread clockwise around front of bobbin winder tension disc (illustration 4).
7. Pass thread end, from inside, through small hole in rim of bobbin.
8. Holding thread end, step on speed controller to run machine until desired amount of thread is wound. (Winding stops automatically once bobbin is full.)
9. Cut thread; push bobbin to the left and remove it from bobbin winder pin.
10. Trim thread end from top of bobbin.
11. Press the bobbin winding indent on hand wheel to its original position. If necessary, turn hand wheel to engage needle movement.
Singer 750 how to rewind the bobbing - 8497168.jpg1908795.jpg4f61c9e.jpgbfd406b.jpg
Posted on Feb 09, 2009
I have a Singer 7258 (Stylist). I took it apart to adjust the timing, and now the feed dogs do not seem to be engaging. This machine does not have adjustable feed dogs. Any idea how to fix?
It is important to know how to time a sewing machine so I hope you did this part right. Anyway, the feed dogs aren't engaging gives me an indication that you have set it up for "rewind bobbin". Set your machine up for sew, not rewind.
Jan 01, 2017 | Singer Sewing Machines
Bobbin case for 7462 singer how do u put in the machine
Open Up The Door Below The sewing Foot. Lift Lever And Then Pull Out the Bobbing Case Replace Bobbing And Put Back Together
Feb 02, 2014 | Singer 7462 Mechanical Sewing Machine
I just bought my first sewing machine,its a singer duel zig zag model/758. i dont know how to thread it or the bobbing
If you go to www.singerco.com under support, click instruction manual, then enter 750, I think that it will work for you and it is free to download. Please let me know if it doesn't help because there are 2 different model numbers here and the 727198 does not work, and the 758 would cost you $15, so I am hoping that it will get you started anyway and if that doesn't do it, I will find you something else.. My email is mvd011244@msn.com
Apr 21, 2011 | Singer Zig Zag 727198 Sewing Machine
Bobbin rewind problems
Either the winder rubber is worn down one side, or the spindle has seized, take the top off and check and see if you can turn the winder by hand, if not then it has seized and the only way to free it is to put a couple of drops of WD40 on the spindle, put an electric drill on the end of the spindle and start the drill very slowly.
Feb 07, 2010 | Singer 8280 Mechanical Sewing Machine
Singer touch n sew 750 winding bobbins
You can find Singer bobbin winding instructions at http://www.singerco.com/resources/bobbin_wind.html.
"Birdnesting" occurs when there is no tension on the needle thread to pull the bobbin thread. This is easily corrected by rethreading the machine, following the threading path carefully and making sure the thread is fully engaged in the tension mechanism.
Jun 21, 2009 | Singer 7442 Mechanical Sewing Machine
Singer 2210/replaced gear/now needle bobbing cam out of sync
look here:
http://www.vacsew.com/repair/singer-600-timing.html
Apr 24, 2009 | Singer Sewing Machines
Sewing Machines Logo
262 people viewed this question
Top Sewing Machines Experts
Bargain Box
Bargain Box
Irene Tulloch
Are you a Sewing Machine Expert? Answer questions, earn points and help others
