Question about Acer Aspire 6930-6771 Laptop
Acer Aspire 6930 wifi will NOT turn on when the button is pressed
My wireless was working fine on my Aspire 6930. in the middle of a download, it stopped functioning, the orange light turned off, and now when i press the wifi on/off button, i get no response whatsoever. Anyone have an alternate way of turning the wireless on? or am i having a hardware issue?
  • 4 more comments
  • hammer2003 Feb 09, 2009
    The device is there and in the properties is says "This device is working correctly"
    Well thats the thing, there is no sliding switch on the front of the laptop. The only way i can turn the wireless on is by pressing a little touch sensative button that for some reason isnt working. a terrible design if you ask me.
    Theres something interesting. I do not have a Acer eNet managment program. Ill look further into this. it just might be the issue.
  • Kim Theis Apr 22, 2009
    I have followed this thread and have the identical problem
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    If you go into the device manager, do you see the wireless card under the network adaptor category? If so does it have a red X or a yellow question mark?
  • Ben Wabnick
    On the front edge of the laptop. Should be a sliding switch. Have you tried that?
Start Windows Mobility Centr from the Accessories program group in the Start menu..you will see if its connected or not connected on top right hand side of pop up screen. Just click to turn wireless on and off. Otherwise go to page 14 of the Generic User Guide for more infor.
Posted on Mar 07, 2010
  • 1 more comment
  • thanne21 Nov 08, 2010
    thanks this cured the problem c.s.
  • lornadukes Apr 11, 2011
    hi got the screen but wont let me click on "wireless on" any ideas?
  • karen Aug 20, 2013
    wow! thanks!
I figured this out today. When your Acer 6930 gets low on power, it will automatically disable the wireless to conserve energy. However, when you plug it in again, it does not always enable the wireless. You can press the little button all day, and it will say something like wireless Lan enabled, but will NOT light up or work. Here's how I fixed that. You need to open Network Connections and find your wireless card.
1) Go to Control Panel
2) Check to see that you are in "Control Panel Home" and not "Classic View"
3) Click on Network and Internet
4) Click on Network and Sharing Center
5) In the left column (small print) click on "Manage network connections"
6) Now look for your wireless connection.
To enable wireless:
1) Right click on your wireless connection
2) Click on Diagnose
3) It will diagnose and tell you to turn on the wireless...and it will give you a button to finally turn it on.
4) Click that button and it will repair the wireless. Voila!
Posted on Jul 15, 2009
  • BeanTron5K Jan 21, 2011
    i have win 7 on the acer and this didnt work at all mainly because there is no "manage network connections" it is only "manage wireless networks" . furthere more there is no diagnose option. someone please help, and be specific
I had this same problem. After one reboot the wireless touch sensitive button would just not work. On the advice of acer support, I removed the battery and ac adapter and held the power button down for 30 seconds. When I boot the battery back in and booted up I was able to use the button again normally.
Posted on Mar 05, 2009
To turn your wireless back on: Click on the internet icon at the bottom right corner of your taskbar. Open "Network and Sharing Center". Click "Manage Network Connections" on top right of the Network and Sharing Center Right-click on your wireless network and then click "Diagnose" If your wireless is off, it should give you the option to turn it back on. This is different than the other "diagnose" functions where it simply tells you to turn it back on because this one actually turns your wireless back on for you. You should then see the orange flashing light on your keyboard and your wireless should be back up and running again.
Posted on Apr 21, 2009
There is a slide button on the bottom of the laptop, next to the battery button, that got me working again
HB
Posted on Mar 08, 2009
Instead of going through all of that, the best and easiest way to try and fix it is to download the driver from the Acer website.
look up the model on the website and download and install the wireless driver.
This way will definitely fix it if there is a driver error.
Posted on Feb 09, 2009
Its usually nothing to do with wireless drivers. When you reinstall windows or update the bios( or windows just messes up ) Reinstalling the wireless drivers doesnt help. Theres a program called eFramework that needs reinstallation. http://us.acer.com/acer/service.do?LanguageISOCtxParam=en&miu10einu24.current.attN2B2F2EEF=3750&sp=page15e&ctx2.c2att1=25&miu10ekcond13.attN2B2F2EEF=3750&CountryISOCtxParam=US&ctx1g.c2att92=453&ctx1.att21k=1&CRC=2054404012
Posted on Aug 14, 2010
  • isclark Sep 20, 2010
    Can't find any program called eFramework at the link above... it is all drivers! I'm really stuck with this problem, which seems to be the same as those above.
  • Acer Master
  • 2,404 Answers
If the sliding switch is not there try going into Acer eNet Management and make sure WLAN is turned on.
  • Ben Wabnick
    Ben Wabnick Feb 09, 2009
    Welcome Back:
    Visited the website for 2 consecutive days.
I have an acer aspire 6930g and my 'easy launch' function keys stopped working too. i updated all drivers and tried various means of turning the wifi back on using different programs. nothing worked. i downloaded an intel program that told me the radio switch was off but couldn't find anything anywhere to tell me how to turn it back on without using the broken touch sensitive button. i was tethering off my iphone for days. so irritating.
is the option to turn wireless on/ off via windows mobility center greyed out or absent? mine was but yours mightn't be so that'd be my first port of call. failing that, try the Fn + F5 combination. it's a schoolboy trick that took me about four days of pull-out-your-hair frustration to discover.
if all of your function keys are broken, and it bothers you at all, you can buy a new keyboard cover on ebay, and there are tutorials to help you replace it if you don't feel like visiting a computer shop. maybe that'll fix the actual buttons themselves.
Posted on Jul 07, 2014
None of the solutions are workingg.. Plz helpp
Posted on Oct 06, 2011
If you remove the drivers for your wireless and reinstall them, it should work again.
Posted on Oct 26, 2009
4 Suggested Answers
Joed911
  • 4338 Answers
SOURCE: where is the wireless connection button on the acer aspire 6930?
The switch for the 6930 is located just above the NumLock key. It actually looks like an LED indicator of a satellite dish, but it's not. It's the button for the WiFi enable/disable. Push it hard...
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Apr 06, 2009
  • 4 Answers
SOURCE: Wirless connectivity problem
What qualifies you people to write responses? The switch for the 6930 is located just above the NumLock key. It actually looks like an LED indicator of a satellite dish, but it's not. It's the button for the WiFi enable/disable. Push it hard...
Posted on Jan 16, 2009
  • 3 Answers
SOURCE: Problem with Acer Aspire 2930 wireless button
If it i not fixed i encounted a similar problem. My wireless was on but there was no orange light. I then went to windows mobility center and clicked on the wireless part. then i realized that it was switched off. I hope this has helped you.
Posted on Jul 23, 2010
Can not turn on my wireless swith
you may wanna try this:
or
- remove the battery and charger (everything connected to the pc) then press the power button for 1 minute..
- plug back in the charger
- after few secs try to turn it on and boot it normally
hope this helps :D
Mar 29, 2011 | Acer Aspire 6930-6771 Laptop
My acer aspire 6930 wireless is not working, i installed new driver ,when i turn on wireless it says wireless lann anabled but the orange light does not come on and the the computer says wireless is not...
I had a problem with this as well with a similar acer aspire model. Mine was defective: the connector inside was faulty. Returned under warranty and got it fixed! Now it doesn't do that anymore.
Mar 01, 2011 | Acer Aspire 6930-6771 Laptop
Can't find wireless switch on acer 6930 where is it on laptop?
On my mini Acer One it is on the right front to the right of the touch pad you can see it with the screen closed and it it a slide switch..
Hope my advice helps and please rate/vote or place a testimonial
Thanks,
Wicked Angel
Nov 20, 2010 | Acer Aspire 6930-6771 Laptop
I have a notebook aspire 6930, i've had it just barely over a year, and a couple days ago my internet just wouldn't connect. When i push the touch button to turn the wireless LAN on it does not light up...
1) Make sure Wireless Lan is Enabled by pressing the light button of it
2) Click with right button on the Battery Icon (on the botton bar aside clock)
3) Select Windows Mobility Center (a window will open up)
4) Click on "Turn wireless on" button.
Jun 12, 2010 | Acer Aspire 6930-6455 Notebook PC
Wireless lan will not enable
there should be a button right under the screen, right above the keyboard that looks somewhat like a thumbnail, when you press it, it should turn orange telling you it is on.
Thanks
Dec 10, 2009 | Acer Aspire 6930-6771 Laptop
Aspire 6930 wireless button not working
Without any wireless networks available, using your computer wirelessly is most pointless. If you want to set up a wireless access point in your home you need a wireless router, connected to Internet.
Sep 18, 2009 | Acer Aspire 6930-6771 Laptop
Cannot connect to a wireless net work
manually jst switch on wont serve the purpose, please do go to control panel. internet options and check out for the problem. there is setting error in your pc..
Jun 23, 2009 | Acer Aspire 6930-6771 Laptop
Acer 6930 Notebook - Easy-launch button -Wireless Network
control panel network connections if your network shows right click
if there is Enable then click
if not click repair
if you have nothing there check devices and see if wireless card shows
let me know if this helped
you may need to setup a wireless connection
Jan 11, 2009 | Acer Aspire 6930-6771 Laptop
Jan 04, 2009 | Acer Aspire 6930-6771 Laptop
Acer Aspire 6930-6771 Laptop Logo
21,620 people viewed this question
Brian Sullivan
Brian Sullivan
Mohammed Ebrahim M
Mohammed Ebrahim M
