Dvd/cd drive of acer aspire 5310 laptop not work propery
Hi, i am shailesh, my acer dvd/cd rw drive of laptop is not work propery means actully, it could not detect a cd or dvd in the drive then what can i do now? please reply me with solution
  • Anonymous Apr 03, 2009
    Hi i have an Acer Aspire7720g laptop.When i insert a disk you can here it turning then it mahe small crunching noises.Device manager says it is not working properly (code 10 ).What does this mean.
  • awadhesh001 Apr 29, 2009
    my dvd/cd drive dont read any thing, is there software problem? please help me.
    Novelist:
  • 140 Answers
The problem when a cd or dvd player cannot detect a disc even though one is there can be two distinct problems. The most common is that the laser reader diode or led lense as some call it needs to be cleaned. Usually a good cd lense cleaner that looks like a cd works, but if it is not turning at all to start it off, it won't work. That is the second problem that if the disc does not turn at all, then it will give the same message or error. To be sure you need to take the cover off with it unplugged so that you can see the lens pointing up towards the middle of where the disc would be. Use a q-tip dipped in isopropyl alcohol to clean the lens then with the dry side of the q-tip to dry off any excess that has not evaporated. This usually fixes over 90% of those types of problems. Let me know if I can help you in any other way.
Posted on Feb 09, 2009
2 Suggested Answers
preachw996
  • 1179 Answers
SOURCE: dvd/cd drive of acer aspire 5310 laptop not work propery
First step would be to try cleaning with a good quality dvd cleaner. Then see if drive detects. More than likely this problem is caused by a dirty laser lens or improper lens alignment. Cleaning should always be the first step in a problem you describe as 99% of the time it is the cure. Good luck.
Posted on Jun 01, 2009
How to reomve a faulty CD/DVD drive from the Acer Aspire 5510 to enable replacement.
Hello
With a number of software manufacturers using DVDs to distribute their software releases, having a Acer Aspire 5510 DVD-ROM Drive is not only convenient but is practically essential to keep up with software releases. Unfortunately, if your laptop doesn't have a DVD drive, installing one isn't quite as simple as it would be if you were installing the drive into a desktop computer. This doesn't mean that installing a laptop DVD drive is difficult, provided you purchase one that is compatible with your laptop. 1. Check to ensure compatibility between your laptop and the Acer Aspire 5510 CD-RW Drive you purchase. The best ways to do this are to purchase your DVD drive directly from your laptop manufacturer, look for compatibility information on the drive's packaging or ask a knowledgeable sales associate. If buying online, make sure to read all of the drive's profile to check for compatibility information. 2. Remove the Acer Aspire 5510 DVD-ROM CD-RW Combo Drive that your laptop currently has. Flip the laptop over, setting it on a sturdy surface with the side that the existing drive is on facing you. Depending on how the laptop is designed, you should find 1-to-3 screws holding the drive in place; these screws may be on the bottom of the laptop or on the side next to the drive. Unscrew the screws and set them aside for later use. 3. Flip the laptop back over. Carefully remove the old drive, pulling gently yet firmly if you encounter resistance/ This will be the drive unplugging from the laptop's drive interface, so a small amount of resistance is not unusual. Once the drive is free of the laptop, set it aside. 4. Slide the new Acer Aspire 5510 Combo Drive into the empty drive port. Make sure that you press it all the way in so that the drive will plug in to the drive interface. Once the drive is in completely, replace the screws to secure the drive. 5. Boot up your laptop. Your operating system will detect new hardware and will load temporary drivers for the DVD drive; insert the driver disc that came with the drive to install the manufacturer's drivers in order to get optimal use out of your new Acer Aspire 5510 DVD-ROM CD-RW Combo Drive.
Hope this helps, if so do rate the solution Good Luck
Jan 10, 2011 | Acer Computers & Internet
DVD RW but not reading DVDs and reads CD
The problem unfortunately will be with the dvd writer dvd laser not functioning or dirty try cleanng the laser with some glass cleaner or cd cleaning packs if the same the dvd drive is faulty and needs replacing
Mar 18, 2010 | Acer Aspire One PC Notebook
Acer aspire 6920 18.4 inch screen! I cant get blue ray dvds
According to the ACER Aspire 6920 specs, it does not have a Blue-ray player only DVD CD R/W drive. Therefore it cannot play blue-ray movie disks.
The specs of the DVD drive are as follows :-
Optical Storage
  • Type DVD±RW (±R DL) / DVD-RAM - Integrated
  • CD / DVD read speed 24x (CD) / 8x (DVD±R) / 6x (DVD±R DL)
  • CD / DVD write speed 16x (CD) / 8x (DVD±R) / 4x (DVD±R DL)
  • CD / DVD rewrite speed 16x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 5x (DVD-RAM)
Jul 24, 2009 | Acer Aspire 6920-6422 Notebook
MAY U PLZ ASSIST ME WITH MY ACER LAPTOP ASPIRE 4330 THE DRIVE IS UNABLE TO WRITE ALL THE DVDS BUT IT IS ABLE TO READ DVDS THE ONLY PROBLEM IS BURNING DVDS. HOW CAN I ENHENCE MY DVD/CD-RW COMBO TO WRITE THE...
No Sir, Acer Aspire 4330 comes with different Optical Media Loadings, ( You can see a pdf file here )
Like;
  • DVD/CD-RW combo drive
  • 8X DVD-Super Multi double-layer drive.
But you have the first one, The Combo drive not the super so you can READ both CD's DVD's but can write only CD's.
Hope this removes your dilemma.
If helpful, kindly do Rate!
Jul 18, 2009 | Acer Aspire 5720-6661 Notebook PC
I need to find out what type of disc to use with our dvd burner
The specification of the DVD drive for the Aspire 5930 is
  • Type DVD±RW (±R DL) / DVD-RAM / HD DVD-ROM - Integrated
  • CD / DVD read speed 24x (CD) / 8x (DVD) / 1x (HD DVD)
  • CD / DVD write speed 16x (CD) / 4x (DVD±R) / 2x (DVD-R DL) / 2.4x (DVD+R DL)
  • CD / DVD rewrite speed 10x (CD) / 4x (DVD±RW) / 3x (DVD-RAM)
This means you can burn CDs -R and +R type disc (incl R/W)
Burn single layer and dual layer DVD -R and +R disc (incl R/W)
Jun 27, 2009 | Acer Aspire 5920-6727 Notebook
Jun 01, 2009 | Computers & Internet
Hi my dvd/cd RW unable write dvd
What is the make and model of your DVD/CD RWdrive?
Check to specification of your drive.
Some combo drives can only burn CDs only and read DVDs & CDs.
Dec 31, 2008 | Acer Aspire 5500 5570-2609 Laptop
DVD / CD - RW Combo
When you say you cannot burn DVD's, do you mean you cannot burn DVD movies or do you mean you cannot burn data files to a DVD?
Burning DVD movies requires specific software to transcode the video and create a directory structure that DVD's players expect.
When you try to burn DVD's does it produce an error? What software are you using to burn?
Nov 19, 2007 | Acer Aspire 3680 Laptop
Computers & Internet Logo
435 people viewed this question
David Payne
David Payne
