Question about Xantrex Technology Heart Freedom 20 12 Inverter
Heart Interface link 1000 Manual??
I just bought a sailboat with a this type Inverter/charger but didn't get a manual with it. It seems to have fried the batteries, 2 wet cell marine batteries and i wanted to change to 2 new AGM Interstate Optima batteries. Since i don't want to fry $450 worth of batteries what do i do?? Where can i purchase a manual?
Check the manufacturer web site:
Product Page:
http://www.xantrex.com/web/id/98/p/docs/pt/7/product.asp
User Guide:
http://www.xantrex.com/web/id/423/docserve.aspx
Posted on Apr 30, 2009
Good day, Have a Heart Interface 2000w model 81-0234-12 charger/inverter When connected to 12 v battery I get 275 v ac out from the inverter. Why not 220v ?
How are you measuring the output? The inverter makes alternating current and it can be measured wrong. Also it might be high if a regulator is bad and also if there is no load on the output..
Feb 06, 2015 | Heart Interface Boating
Where can I bring my Heart interface freedom marine 10 1000 watt 50 amp inverter charger to get repaired... I live in merritt island florida
Hi Nick!
I would strongly suggest contacting Xantrex service. IF your unit is still under warranty, it could save you some cash. If not, here's their contact info:
http://www.xantrex.com/power-products-support/overview.aspx
Nov 15, 2014 | Boating
Hi Nick!
I have a #20 charger inverter on my sailboat. It has worked fine for several years. This winter, I replaced the battery bank with 4 Trojan T-105. Batteries are fully charged, new battery wiring and...
Without more information, it could be a number of things. For starters, you might try disconnecting the ground wire to see if that makes any difference. The Xantrex Owner's/Installation Manual says specifically not to connect the inverter's negative *battery cable* to the vessel ground, but if the unit's housing and the negative cable share a common ground somewhere inside the unit, that would be the same thing. The T-105s are great batteries, but since they are 6V, make sure you rewired them correctly, i.e. a pair in series (12V) wired in parallel with the other pair for 450 AH total. Recheck all your battery connections and make sure you didn't blow the inline battery fuse in case you inadvertently made a momentary wrong connection during the new battery installation.
Apr 27, 2010 | Xantrex Technology Heart Freedom 30...
Inverter seems to be working but batteries aren't
is the bateries draining quikly?, if so try redusing the load on the inverter ,always make sure it is fully charged before use.
Feb 08, 2010 | Xantrex Technology Heart Freedom 25...
Heart interface 30 marine quit charging
the charge fuse may have broken or the charger is bad
Jul 15, 2009 | Xantrex Technology Heart Freedom 30...
I have a Heart Interface Freedom 20 Inverter/Battery Charger installed on a powerboat. The fan (cooling fan?) is making noise - it seems to be rubbling inside the unit. Is there a way to repair? Replace...
The fan can be replaced. It is very similar to some of the PC cooling fans. I've got the same problem (again) and will be replacing it soon. I will give you the fan specs once I remove my fan ( I think it is 4" 120VAC - will let you know when I repair mine).
Jun 14, 2009 | Xantrex Technology Heart Freedom 20 12...
Xantrex Technology Heart Freedom 20 12 Inverter Logo
1,726 people viewed this question
Top Xantrex Technology Boating Experts
Tre Elkins
Steve
Steve
Are you a Xantrex Technology Boating Expert? Answer questions, earn points and help others
