Question about Dewalt DC011 AM/FM Radio
Dewalt radio getting power line blink
Im getting the power line sequence on the charger light. Used it all day came home and plugged it in ever since them i get 2 blinks and a pause. Radio works on battery, and works off 110v.
  • James Barrows
    James Barrows Feb 09, 2009
    it also clicks one when i plug it into 110v.
  • birdhog Apr 11, 2009
    my radio works odd 110 and the battery. I get 2 blinks then a pause.... Problem powerline. What do I need to fix this
5 Suggested Answers
  • 4 Answers
SOURCE: DeWalt DW911 Radio/Charger
the second fuse is behind the circuit board,in middle of the radio.
there are 4 screw holding circuit board. Still looking for 2 AA battery.
Posted on Dec 07, 2008
  • 51 Answers
SOURCE: Dewalt dc011 won't charge or play on battery
could be a fuse in the radio. check with your local dewalt dealer.
Posted on Aug 08, 2009
  • 21 Answers
SOURCE: my dewalt radio does not work
sadly , chances are you blow the whole power supply on it. you should check with your local servicenter for an estimate on the repair. the units that are made for USA are 110v
Posted on Sep 25, 2009
  • 60 Answers
SOURCE: how to connect an ipod to a dewalt radio?
Get a lead of Ebay! 3.5mm jack to 3.5mm jack. Very cheap.
Posted on Nov 28, 2009
  • 60 Answers
SOURCE: my dewalt dw911 radio/charger works on either
More than likely your internal charger is faulty. Inside your inernal charger unit check the 2 anmp fuse which is white in colour.
Dewalt dc9310 charger flashing
On some chargers, when the light blinks rapidly, it means that the battery is bad. Try looking up charger information on-line.
Feb 28, 2015 | Dewalt Dc9310 7.2 Volt To 18 Volt Nicd /...
Any solutions to dewalt 20v lithium battery charger got wet shows blinking light as if its charging normal but not charging
High Performance Current Mode Controller doesn't work for you in the charger. According to the link, scheme.http://kazus.ru/forums/attachment.php?attachmentid=51161&d=1377505983
Sep 18, 2014 | Dewalt 12v Max - 20v Max Li-ion Battery...
Can I power a small appliance with my dewalt
This is what dewalt is saying...The Dewalt 12V/20V MAX work-site charger/radio functions as an AM/FM radio and recharges your 12V/20V Dewalt batteries (batteries not included). The 3-stage charger can recharge your batteries in as little as 1 hour, and the radio can run off 12V/20V batteries for cordless operation
  • 2 AC power outlets offer more versatility for jobsite power
  • Auxillary & USB ports allows for connection to CD, MP3, portable satellite receivers, and other digital audio devices.
  • USB port allows device to be charged via USB when radio is plugged into a wall outlet
  • Class D amplifier, woofers and tweeters provide full range of high and low sound for optimum sound quality,( hope this helps)
Aug 06, 2014 | Dewalt DCR015 MP3 AUX USB 12V/20V MAX*...
Two quick flashes problem powerline what does that mean exatly
From the manual.
Some chargers have a Problem Power Line indicator. When the charger is used with some
portable power sources such as generators or sources that convert DC to AC, the charger may
temporarily suspend operation, flashing the red light with two fast blinks followed by a
pause. This indicates the power source is out of limits.
Oct 13, 2013 | Dewalt 7.2-18.0 Volt One Hour Charger
18 volt dewalt lithium ion battery charger stopped working for no reason....
This can happen if the battery is too dead for too long. Keep trying to make it work like you have maybe 20-30 times. Or you can leave the battery in for a few days and let the logic chip do it's job. It should start working in a day or two.
Apr 25, 2012 | Dewalt Dc9310 7.2 Volt To 18 Volt Nicd /...
Have just got the Dewalt DE9116 charger.Plugged it in & red light comes on & then goes off.Is the charger working properly?Have no instructions
that is normal it happens when u plugged and unpluged. after a second it should show no blinking. then when u insert the battery pack it would show the diagnostics. with the blinking pattern.
if you need the manual , you can get at www.dewalt.com or call us at 407 657 0474 and we can fax it to you.
Sep 23, 2009 | Dewalt 7.2-18.0 Volt One Hour Charger
Aug 06, 2009 | Dewalt DC011 AM/FM Radio
My delphi xm2go radio unit will not take a charge. Have tryed everthing! It starts to charge then goes dead!
I had the same problem, Based suggestion that the plug in the Radio is worn and not making contact, I used a small screw driver to shift the pin in the charger input hole from the center a little. That did it on both my Myfi;s. The now charge properly, and stay on as long as I need. Which needless to say, brings a smile to my face :) .
Apr 21, 2009 | Delphi MyFi SA10113 XM Radio Receiver with...
Dewalt DC011 AM/FM Radio Logo
485 people viewed this question
Top Dewalt Audio Players & Recorders Experts
Gyula Lacz
Tom Chichester
JonSnell Electronic
JonSnell Electronic
Are you a Dewalt Audio Player and Recorder Expert? Answer questions, earn points and help others
