Question about Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV
Sony KDF 60WF655 standby/power light blights 10 times then repeat
Sony LCD TV Sony KDF 60WF655 standby/power light blights 10 times then repeats with no picture or sound
  • Anonymous Feb 11, 2009
    power light 10 times with no picture
  • 42 Answers
This is what I found
You may want to have a Tv repair shop look at this .
Standby light flashes 10X
Symptoms / Customer Description
[Primary Symptom Code: 2111 ]
Solution
G1 and G2 boards are ok.
Found Q box was causing loss of DTL MODULE 5v.
Replaced Q box to resolve.
Part #
A1058689A
Posted on Feb 10, 2009
Hello, my Sony wega KDF-60WF655 tv will not turn on. The power/standby led flashes 6 times and pauses then repeats. what is the problem with tv?
This error code is an indication of a b+ error voltage ... specifically a voltage of 6 volts known as dd voltage when the voltage is low pin 129 of micro
Mar 08, 2011 | Sony Grand WEGA KDF-60WF655 60" Rear...
My sony kdf-60wf655 keeps shutting off on its own.what is the problem and can i fix it myself
If tv turns back on itself after shut down then it is weak lamp problem, replace lamp in tv to fix its problem.
Buy Sony original lamp for good picture in tv and replace it as it is user level repair and lamp replacement procedure is mentioned in related user manual.
If standby light start blinking after shut down, let me know how many times it blinks after three second pause to provide you info about possible cause of problem.
Thanks.
Dec 06, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
The picture goes off, the power/standby light
Sony KDF-60XS955 picture goes and power/standby light light flashes
Most likely you have bulb failure. First step in troubleshooting is "Change the Lamp or Bulb". Lightning, power line bumps and collisions with vacuum cleaners can all shorten lamp life. Rough handling in shipment can also happen without your knowledge.
+90% of all Sony LCD Rear Projector "No Picture or Intermittent Picture" faults are related to bulb failure.
If new lamp does not improve the situation, then hands-on troubleshooting by someone that has parts and knows how the unit works is the only practical remedy.
easyab
Mar 14, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Hi. My sony KDF-E50A10 will turn on for about 30 seconds, then the picture and sound go off, the standby/power light flashes 49 times green and the set turns back on. After 30 seconds, the same thing...
tv works for about 2 minutes, then shuts itself off. the red standby light flashes 50 times, then the tv. comes back on for approximetly 2 minutes then goes off again, only to repeat again
Sep 28, 2009 | Sony KDF-E50A10 TV
Red light blinks5 times stops & does it repeatly sony KDF-60WF655
5 times red light blinks in Sony KDF-60WF655 shows problem with ballast supply that needs to be replaced.
If you are handy with electronics stuff repair and have service manual copy then can replace it.
Be Aware: electric shock risk is involve in TV repair.
Or contact local TV tech to fix it.
Need further help, let me know please.
Thanks.
Sep 22, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony KDF-E42A10 rear projection TV. Won't turn on.
Start by changing the lamp. If you got 5 years out of the old one, count your blessings, most folks only get three. The lamp is designed to be replaced by the consumer. Ebay will carry a replacement for you or you can get it directly from rivervalleyelectronics.net. They've got good prices. The lamp door is on the back. Its really easy, give it a shot.
Sep 07, 2009 | Sony KDF-E42A10 42 in. LCD Television
Sony KDF-50WE655 will not power up. Red blight blinks 4 times
4 blinks shows problem either one or all 4 fans are not working AND internal temperature high error.
If you are familiar with TV repair and know basic electronics then unplug TV from AC outlet an take off back cover and check fans are running?
Jan 27, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Tv sound and pic goes out and green light flashes for 38 seconds
I have the same tv and it did the same thing. I replaced my lamp and it corrected the problem.
Jan 25, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony 42in- No picture or sound
You need to replace the bulb...very easy. You can do it yourself.
Dec 23, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
Screen is dead
TV screen dead symptom..I need info about Sound, and standby light at TV front. Is there sound comes from TV? does standby light lit when switch on TV?
Aug 15, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV Logo
378 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
