Question about Kenmore 15864/15862 Top Load Washer
Kenmore top load washing maching flipping the breaker
Our machine is about 5 years old and is tripping the breaker 3 or 4 times per load now... It is a model 110 - 22652100, S/N CL3303841, type 3.
Does anyone know if this type has a selfcleaning lint filter? Any ideas what might be wrong? Thanks!! :)
Maybe the breaker is going bad or you have added something else on thatcircuit
Posted on Feb 09, 2009
Top loading Kenmore washer runs for a few seconds then shuts off
It's quite possible, however,
If you're mechanically inclined, I'd check the motor, transmission and pump first.
See the following Whirlpool / Kenmore Service manual for top load, direct drive washers and it's trouble-shooting section.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
See the following for how to pull the cabinet, pump, motor and transmission to check them all.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
YOU DON'T HAVE TO PULL THE TUB.
Mar 15, 2010 | Kenmore 43142 Front Load Washer
Blow breaker
I need the model n serial # to better assist you.
Thank you
May 10, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore 417.40412700 tripping GFI circuit breaker
Unfortunatly washing machines are too sensitive for GFI outlet.only way to fix is too take it off the GFI.
Mar 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore top load washing maching tripping the breaker
the breaker is likely worn out, have that checked by service person first, then check that machine does not need to be lubed etc. for too high a load on the circuit.
Feb 09, 2009 | Kenmore 15864/15862 Top Load Washer
10 year old model kenmore top load washing maching won't fill.
That means that eithere the membrane water lever switch is faulty (most common) or that the drain pump solenoid is stuck on open.
Dec 21, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 - in mid spin cycle the machine tripped GFI
check your pump ,,, sounds like you gotten something in it putting a strain on the motor to overload your breaker
Nov 17, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore wash machine will not spin
Eight years is getting kind of old. When the clutch or transmission goes out, it costs more to replace the part than to buy a new washing machine. You'd better plan a shopping trip rather than spring for that $100.
Aug 02, 2008 | Kenmore 22422 Top Load Washer
Washing machine has high amp draw
yes sounds like your motor is breaking down
Jun 15, 2008 | Washing Machines
Circuit breaker on laundry circuit has started to trip
if the machines are both on the same outlet i would attempt to run them on seperate outlets first to see if it improves. as time lapses breakers or gfi's can weaken and a continous amp draw esp. in the spin and the ignition stage at the same time which are the largest amp draw from either machine at any give time could be causing the issue. if this does not work you need a tech to look at it
Jun 03, 2008 | Washing Machines
Kenmore 15864/15862 Top Load Washer Logo
Sal De
fordexpert
Robert Rankin
