Question about OEM Systems Car Audio & Video
Remanufactured BMW Business CD
I recently had my Business CD stereo in my 2004 X3 replaced (on warrantee) because the cd player kept holding on to the cds. The replacement they put in is a RMFD part number (Remanufactured BMW Business CD). It stereo sounds very different from the original one but looks almost the same.. Now I don't even know if this is ipod ready.
I have a part number but no manual and the part number on the dealership paper work doesn't really correspond to other BMW Business CD numbers. How can I find out what model (and year) stereo they put in my car. Thanks for any help.
SOURCE: Jensen car stereo
just turn the changer on, make sure it is playing a disk, (and you know whats playing) the press the scan function on your radio til it picks up that signal and lock it in.
Posted on May 24, 2008
  • 163 Answers
SOURCE: cd player and hot (high temperature) CD's
As with all electronics... anything can happen (even unexplained). There are two things to think abou tin this expensive experience.
  1. 1.CD's are made of plastic and metal... excessive temperature can cause them to warp, but not as bad as the old vinyl.
  2. Mosy electronics have an acceptable operating temperature. Although the unit may work outside these limits, it is not recommended. ex:My Sony DVD R/W has a range of about 40-95 F. Being in Houston I am sure the upper limit is reached OUTSIDE the car. Inside you are probably pushing 120+.
It may not be convenient but if you have to leave discs in the car, try putting them in a case in the trunk, out of direct sunlight. And let things cool down inside the car before trying the CD player.
I have not seen this before but like I said, anything is possible.
Posted on Jul 21, 2008
  • 1586 Answers
SOURCE: Where is serial number for Business CD player
Get in touch with the dealer. You may need to go there. If so, bring your title, registration, and photo ID to prove you're who you say you are, and the car is yours. They can look up the code for your car based on its VIN number. They may charge you though, up to an hour's labor, so be prepared.
Posted on Aug 02, 2008
SOURCE: need radio code for bmw radio
need code for blaubanket
Posted on Dec 10, 2008
  • 3 Answers
SOURCE: lost radio code for a ford 6000 cd player serial no M133347
8689 should resolve it
Posted on Sep 02, 2009
I am getting an error read on my CD player. The CD Disc CD player (original) to my 2003 Experdition will not release CDs. The CD player which is an automatic feed was force fed a CD by a minor child. The...
The unit can be removed but disassembly will be required to remove the OFFENDING CD. Even at that, the player mechanism may have been damaged so that CDs simply cannot be played at all
Jan 28, 2013 | OEM 2002-2004 Ford Focus Factory AM/FM...
How do i eject a cd from the JVC KD G510 car stereo. A CD is already in there but i can't figure out how to get it out and put a new one in
A malfunctioning stereo may least allow feature buttons to perform extractions of CDs. Depending on how the stereo was installed, the car would have to be powered on to attain stereo functionalities. Second, CDs have to be inserted with the readable media side facing the appropriate lenses to achieve results. A wrong insertion of the CD into stereo compartment may require forceful extraction. Observe the type of stereo to ascertain CD extraction also known as reset buttons. Usually a tiny area, the reset button allows inserting an object that forces the car stereo to eject stuck disks. Every mean to eject stereo disk have to be performed while the car is turned on to utilize the source of power. An unsuccessful attempt to dislodge CDs in stereo compartments would require auto electrician's consultation. An unsuccessful dislodge attempt usually requires acquiring a new stereo in replacement of the malfunction.
Feb 02, 2011 | JVC KD-G510 CD Player
2004 Pontiac Grand Prix won't accept CDs...
it will need replaced, it has somthing broken inside it for sure for futher help please call 419 689 1114 thank you
Apr 18, 2010 | 2004 Pontiac Grand Prix
2004 Dodge Ram 1500, Infinity sound system. CD/AM/FM not working.
You most likely need a new radio. They go bad all the time in the Chrysler/Dodge/Jeep. Don't know how many of them I have replaced.
Jun 18, 2009 | 2004 Dodge Ram 1500
Cd drive not recognizing cd's
nope it happens to me, if your laptop still under warrantee call toshiba and they will replace it to you. the problem is the lens not reading the cd, try to clean it by dvd cleaner if its not working replace it.
Mar 19, 2009 | Toshiba Satellite M115-S3094 Notebook
CD player says error and spits discs back out repeatedly
Try to clean the lazer,and make sure the disc is clean.
The lazer will get dirty over time.
Feb 08, 2009 | 2000 Nissan Sentra
2004 Chevrolet Tahoe cd player says changer full and won't work
Bad news. Your CD player isn't any good. I work for Chevrolet and this is a very common problem. The magazine inside the radio (the part that holds the cd's) starts going crooked. I think some real tiny springs that hold it break, causing this problem. Only fix is to replace the radio. First try this. Go to the fuse box under the hood and remove the 'Radio' fuse for 1 minute. This may reset the radio. You may be able to eject any cd's stuck in the radio. May be cheaper to put in an after-market radio. Sorry.
Dec 17, 2008 | 2004 Chevrolet Tahoe
Trouble playing store bought cd's
itll be the lens on the player clean it with surgical spirit
Jun 26, 2017 | Lenoxx Electronics CD-102 Cassette/CD...
Car Audio & Video Logo
388 people viewed this question
Top OEM Systems Car Audio & Video Experts
xxxxxx xxx
Are you an OEM Systems Car Audio and Video Expert? Answer questions, earn points and help others
