Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Ice build up on coil inside freezer
Compressor runs, fans are all running, ice builds up on the coil inside the freezer and stops producing enough cold air to keep food frozen in the freezer as well as keeping food cold in the fridge.
  • Anonymous Mar 27, 2014
    coils icing
    Problem Solver:
  • 17 Answers
It can be two things the refrgerator probably has a small refrigerant leak therefore it ices up, or the defrosting heater on the begining of the coil is faulty.
Posted on Feb 10, 2009
Loud "clattering" noise from freezer area when refrigerator runs
There is a fan in the back of the freezer that runs when the compressor is running. It sounds like you have ice build up around the fan.
You could have one of these problems: (Sorted by most likely to least likely)
1) Auto Defrost timer, defrost bi-metal or defrost heater is defective - the unit will go into auto defrost about twice a day, if this fails you will have lots of ice built up around the cooling fins and sometimes on the fan. Pull the back off the inside of the freezer and check for ice build up around the cooling fins, there should be none or very little if its running normal.
2) Bad door gasket - if the freezer door is leaking warm moist air inside the freezer it could be condensing around the fan causing ice (you will also see ice build up on things inside your freezer too).
3) Plugged drain - the drain leads from the freezer down to the drain pain under the fridge. If this is plugged ice will build up on the bottom of the freezer and potentially around the fan.
Apr 01, 2013 | Kenmore Refrigerators
Kenmore refrigerator model 59562998 Compressor is running but no air is blowing into the refrigerator or freezer
the evaporator fan has stopped. it is usually in the back of the freezing compartment behind all the plastic. when the fan stops no air can circulate over the cooling coils so even though the compressor is running no cold can move iside the freezer or fridge. be extra careful when you take the small screws out as the screw heads can be full of build up that makes it hard to get a good hold of them. take your time and clean off all the screw heads so they don't strip out. The evaporator fan is not to expensive wait to buy on until you get the old one out.
May 01, 2011 | Refrigerators
It stopped working. All food defrosted. Not cold inside although feels cold when pulled open. No ice.
check the evapor coil and fan how much frost build up.if no ice build up.
check condensor fans and coil how dirty. if it ok
check compressor .relay
good luck
Jan 12, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have a true 2 door freezer with bun rack is runninig between 7 degrees up to 59 degrees...we vacumed the we need more coolant or what do you is about 4 years old and...
Vacuuming the coil is not usually sufficient to clean them properly. Hold a flashlight behind the radiator on top of the freezer to see if you can see freely through the coils. If not, the best way to clean the coil is to spray coil cleaner on there and flush with plenty of water. It is a mess but it will get the grease off the coild. If you do not have gauges to check the pressures of the refrigerant (lets call it freon), you can get a good guess by doing the following: Get a ladder, climb up so you can see in the top of the cabinet where the compressor is located. It looks kind of like a bowling ball. There will be one small copper line and one large copper line running from the compressor. The small line is the high pressure line. It should be hot enough to burn your finger. It then goes through a small pan where it evaporates excess water, then to a "radiator" which has a fan running behind it. If the machine is running this fan should be on. The small line then runs into the freezer box. At this point the line should be warm, not hot to the touch. If this is not happening you are probably low on freon. The other copper line on the compressor is returning from the freezer box to the compressor. It should be very cold to the touch. It should have moisture collection on it. If this is not happening you are probably low on freon. Other factors can effect your freezer. Make sure the fan near the compressor is running. Make sure the fan or fans inside the freezer are running. They will stop running when you open the door, so hold the door button in when you check the inside fans. Check also to see if there is a build up of ice on the inside coil. Your freezer should run a defrost cycle 4 times a day to remove the ice. If it has ice it will not run properly. If you can remove your product for 24 hours and shut the freezer down, prop the door open and the ice will melt. On restart if the freezer goes down to 0 quickly (30 minutes) it was probably frozen over. This may indicate a bad defrost timer or heater. Try these things.
Sep 08, 2010 | True Freezer TG2F-2S
Fridgeaire upright freezer is getting warmer and warmer.How do I
there is no way of cleaning the coils.there maybe a problem with the should hear a fan running inside the freezer when it is in the cooling cycle and the compresor is running if you do not here the fan running this could cause a cooling issue and the evaporator could be building up with ice.
check the rear of the freezer to see if there is any ice build up.
Jan 18, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
It seems the fan goes on more than it should. How often should it go on?
Both fans should run when the compressor is running. Dust on the condenser coil under the fridge can cause it to cool less efficient. Ice build up on the evaporator coil inside the freezer behind the rear cover will cause it to be less efficient. Heavy ice on the coil is caused by auto defrost failure.
Jan 18, 2010 | Kenmore 50522 / 50524 Side by Side...
Whirlpool Refrigerator fresh food section cool but not cold (freezer ok).
The most likely problem is in the defrost system. Behind the freezer panel there is not only an evaporator fan, but also the evaporator itself, and a defrost heater, termination bi-metal, and drain pan (or trough). You will likely find ice build-up in the evap coil. This could be caused by the defrost timer, the heater, or the termination bi-metal.
Have a service tech look at the unit.
May 28, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Hidden Ice build-up inside plastic bottom cover of freezer
Generally, icing is the result of too much water vapor inside the unit, blockage of the circulation channels and too much packing in of the box.  The water vapor is generally caused by: uncapped items in the fridge, opening the door too often, humid conditions, bad door seals.  There is of course, there is a possibility that the defrost cycle on the unit is not working.  About once a day, depending on the brand, you should notice that the fans and compressor don't run and you should hear a bit of creaking, sloshing or other strange noises as the ice melts.  If this is not happening, your defrost timer or the coil it heats could be bad.
Nov 12, 2008 | Refrigerators
Fan in freezer - evaporator fan?
HI. thanks for the question. yes the fan in the freezer must be replaced.and also the drain tube in the freezer, is clogged. cut power to the fridge. remove back panel . replace the fan motor . also clean ice build up. clean drain tube, from freezer to the drain tray, at the back, near the compressor. thanks the appliance doc. please rate my answer. thanks
Oct 07, 2008 | GE GTS22WCP Top Freezer Refrigerator
Fridge not getting cold enough
listen for the compressor running in the back at the bottom. when you hear that running, open the freezer section. do you hear a fan blowing inside the freezer? if not, the evaporator fan motor is jammed with ice build-up or it's bad. hope this helps.
Nov 01, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
420 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
