Question about Microsoft Xbox 360 Console
Restarting xbox when my xbox is starting up it automatically restarts
    Novelist:
  • 174 Answers
This can sometimes be the same sort of problem as the dreaded 3rrod, it can be relieved by reflow of the entire board (heatgun over the gpe, cpu and memory, 2-3 inches away for 5 minutes each side). you would also benefit from the x-clamps replaced, heatsink paste replaced and also heat conducting pads on the memory chips. if you need any help doing the above just email me. www.fixmyconsole.co.uk
Posted on Feb 10, 2009
How do u reset your xbox format to pop up on your tv?
If you're using the XBox 360 component/compositve AV cable, try the switch at the base of the cable to switch from HD to SD or vise versa. If that doesn't work, try MS's official reset instructions:
To reset your display settings, follow these steps:
  1. Make sure there's no disc in the disc tray.
  2. Turn off the console.
  3. Turn on the console.
  4. Note If you're using an Xbox 360 Wireless Controller, make sure only one wireless controller is connected to the console, and then turn off and restart the console by using the Guide button on that controller.
  5. As the console starts, press and hold Y while pulling the right trigger on the controller. The display settings are reset to the default settings, and then the console automatically restarts.
    Xbox 360 E or Xbox 360 S console: To reset display setting on these console models, you can also just turn off the console and then hold the power button on the front of the console down for about 10 seconds. (The lights will flash several times.)
Oct 20, 2014 | Microsoft Xbox 360 Console
Restart
Automatic Restart? Are you trying to Start Automatic Restart or Stop Automatic Restart?
If you have having boot problems and the system keeps restarting, then turn off the computer, then hit the power button and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Scroll down past Safe Mode and you will see an option to DISABLE AUTOMATIC RESTART. Take the Disable Automatic Restart option.
Mar 28, 2012 | Computers & Internet
Automatic restart 630 laptop
If you have having boot problems and the system keepsrestarting, then turn off the computer, then hit the power button andimmediately start hitting the F8 key repeatedly until you see SAFE MODE. Scrolldown past Safe Mode and you will see an option to DISABLE AUTOMATIC RESTART.Take the Disable Automatic Restart option.
How to update your xbox360
The easiest way to update your console software is to connect to Xbox LIVE. To update your console by using Xbox LIVE, all you need is an Internet connection.
  1. Connect your Xbox 360 console to the Internet. To learn how, please see Connecting to Xbox LIVE.
  2. On the console, go to My Xbox, and then select System Settings.
  3. Select Network Settings.
  4. Select Wired Network or the name of your wireless network, if you are prompted to do so.
  5. Select Test Xbox LIVE Connection.
If you cannot connect your Xbox 360 console to the Internet, you can copy the console update from your computer to a USB flash drive and then install it on the console.
Note: The USB flash drive must use the FAT32 file system.
  1. Plug your USB flash drive into a USB port on your computer.
  2. Download the update file.
  3. Click Save to save the console update .zip file on your computer.
  4. Unzip the file. If you are using Microsoft Windows XP, Windows Vista or Windows 7, double-click the .zip file to unzip it.
  5. Copy the contents of the .zip file to the root directory of your flash drive.
  6. Unplug the USB flash drive from your computer.
  7. Plug the flash drive into a USB port on your Xbox 360 console.
  8. Restart the console.
  9. When the console restarts, the installation program starts automatically. Select Yes when you are prompted to update the new console software.
You can update your Xbox 360 console software by downloading the update to your computer from Xbox.com, burning the update to a CD or DVD, and then installing the update on your console. Here's how:
  1. On your computer, download the update file.
  2. Click Save to save the console update .zip file on your computer.
  3. Unzip the file. If you are using Microsoft Windows XP, Windows Vista or Windows 7, double-click the .zip file to unzip it.
    • If you are using Microsoft Windows XP, Windows Vista or Windows 7, double-click the .zip file to unzip it.
    • If you are using an earlier version of Microsoft Windows, you need to use a special software program to unzip the file (for example, WinZip).
  4. Insert a blank, writeable CD or DVD into your computer.
  5. Copy the contents of the .zip file to the root directory on your CD or DVD, and choose to write (burn) the files to the disc.
  6. Once the files have been burned to disc, remove that disc from your computer and insert it into the disc drive on your Xbox 360 console.
  7. Restart the console.
  8. When the console restarts, the installation program starts automatically. Select Yes when you are prompted to update the new console software.
Feb 04, 2011 | Microsoft Xbox 360 Console
The screen is enlarged after watching a movie how do we fix it?
Hi melissami133
PLEASE RATE MY ANSWER IF ITS HELPFUL !
FOR XBOX:
With the new Xbox 360 interface, the how-to below is not working anymore! You can do the following to reset your console:
To reset the display settings of the Xbox 360 console to the default settings, follow these steps:
  • 1. Remove any discs from the disc tray.
  • 2. Turn the console off.
  • 3. Turn the console on.
  • Note If you are using an Xbox 360 Wireless Controller, turn the console on by using the Xbox Guide button on the controller.
    Note Make sure that you use the player 1 controller when you do this. The player 1 controller is the controller where the upper-left quadrant light is on.
  • 4. As the console starts, press and hold the Y button, and then pull the right trigger at the same time. This causes the Xbox Dashboard to reset the display settings to the default settings and then automatically restarts the console. So it's OK when the Xbox 360 console restarts.
FOR PS3 :
Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
Jan 30, 2011 | Video Game Consoles & Games
Update failed when starting up brand new xbox!?
You can download updates to a cd rom,then try to update it that way,
Google, downloading updates to console.aspx.
Remember thumbs up if this helps.
Jan 29, 2010 | Microsoft Xbox 360 Console
Video output on wrong setting and cant see screen
for PS3, hold the power button for at least 5 seconds or until you hear a second beep.
for Xbox 360,
Sep 05, 2008 | Video Game Consoles & Games
Xbox 360
Its probably getting heated up, so try putting it in a moreopen cooler area.
Jul 12, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
