Question about Zanussi TD4112W Electric Dryer
Zanussi tumble dryer does not get very hot
Tumble dryer does not get very hot and there is no water to empty from the watertank
    Scholar:
  • 86 Answers
Hi, I take it from the description taht you have given your T/dryer is a condenser? If this is the case you could be looking at several problems? 1 it could be the large filter underneath the tumble dryer this could be blocked with fluff causing it not to condense quick enough! 2 it could be the water collection pump? Can you her it running? 3 It could be that half the heater has failed causing it not to get hot enough to dry?
Try these hopefully it should steer you in the right direction!
Posted on Feb 09, 2009
My new tumble dyers stops after 10 minutes telling me the water tank is full, when its empty
Since it is new, I would call the mfr and have them look at it. It is under warranty isn't it?
Jan 11, 2015 | Zanussi Dryers
Zanussi tc7103w condenser dryer-water tank light keeps coming on when tank is empty or nearly empty-have found small plastic float and spring on floor behind dryer-where do they fit?
I had this problem. If you look at the valve on the plastic water tank, you will see that those parts are the same. They fit inside the tumble dryer to shut off the water from flowing onto the floor when the water tank is removed. The white hollow cylinders in the tumble dryer and the water tank push each other open. If you study the water valve on the tank you will see how it is put together. It is all held in place by a little 9mm O ring at the back of the valve. The ring gets tired after a while and pops off. The valve then falls apart and you find the cylinder and spring on the floor and the O ring still inside the dryer. I bought an O ring kit and reassembled the valve inside the dryer using a new ring. You will have to pull the dryer out, turn it upside down and remove the floor to do this
Sep 23, 2010 | Dryers
The machine says fill watertank. ventilate. the
Open the hot water valve, and run about a cup of water, this will engage the pump and fill the circuit.
Jun 04, 2009 | Saeco Vienna Digital Coffee Maker,...
Zanussi TC 7114 W Condenser dryer leaking water
Maybe it's the water collector's upper side which leaks...
Apr 15, 2009 | Zanussi TC7114W Electric Dryer
Water leak on Zanussi tc7102 dryer
I had a similar problem. There is a 'o' ring on the plastic part that keeps coming out. This 'o' ring is not big enough, you need to replace it with a thicker one, preferably one made from a harder material.
Feb 28, 2009 | Zanussi TC7102W Electric Dryer
Zanussi TD4212 Tumble Dryer not heating
Could be failure of the overheat sensor
Jan 28, 2018 | Dryers
Tumble dryers
condenser takes the warm moist air and keep circulating it within the dryer ,,some times these unit have to be emptyed of water every so often..exhaust vent have to be vented directly to out side..
Sep 08, 2008 | Zanussi TC7114W Electric Dryer
Hotpoint condenser tumble dryer aquarius cdt00- wont dry
I am not familiar with this particular unit, but I have a condensing dryer (Malber) which pumps out the water by itself. I am guessing that your unit requires you to empty a bin manually. Even if the bin is empty, I think the unit thinks it needs to be emptied and that is why the dryer will not work to give you hot air. If you do have such a bin, it might have a weight switch which the unit uses to detect if the bin needs emptying. See if the weight switch is working. The same weight switch idea is used on dehumidifiers.
Mar 09, 2008 | Dryers
Zanussi Tumble Dryer
Sounds like the condense pump is bad. Replace it, or look if there is lint in it. ;)
Dec 30, 2007 | Dryers
Zanussi TD4112W Electric Dryer Logo
836 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
