Question about Toshiba Satellite 1805-S253 Notebook
I created recovery disc, which fail.
"Hi I hope some one can end my madness"
I thought Its about time I put a fresh Install on my Toshiba Equium L300-147, so I create recovery disc via the Toshiba Recovery toll. They where burnt on to two disc and every thing ran fin. Then when I came to recover th whole the disc had a error and it fail, left with a mest up system. "Is there any one with a shoulder to cry"
  • Vinod Pangtey
    Vinod Pangtey May 11, 2010
    when u tried 2 recover, what error message u got ?
  • pwalmsley55 May 11, 2010
    Deoend upon how old the mechine is. Statutoty Rights give you 12 months from the Manufacturer.
Hi i havw a toshiba satelite laptop had problems so i put it back to factory settings now i just have a black screen saying saying reboot insert disc or reset
Sounds like the recovery partition is was deleted or corrupted. Easiest solution might be to order recovery disks from the manufacturer or work with someone for a fresh re-install of Windows.
Nov 15, 2017 | Toshiba Computers & Internet
I need to reboot windows xp on my toshiba satellite laptop
The Toshiba Satellite A10-S169 includes several utilities to improve the performance or security of the computer, and to reconfigure the system's settings. Toshiba Satellites running Windows Vista 32-bit and Windows XP come with the Toshiba HDD Recovery Utility, which allows you to create a recovery CD of your system and applications. The recovery CD will allow you to restore your system and its settings in case your hard drive fails.
Click "Start." Click "All Programs." Expand "Hard Disk Recovery Utilities." Click "Recovery Disc Creator." Select "CD" as the type. Check "Recovery and Applications." Insert a CD into the disc drive. Click "Burn." The Toshiba A10-S169 will begin writing the recovery content to the CD. Follow the on-screen prompts to burn your recovery files to disc. Hope this helps.
Jan 10, 2013 | Microsoft Windows XP Professional With...
Toshiba equium A100-027 recovery disc
Contact Toshiba, they usually have the recovery disk available for a fee.
This is why you were supposed to create the recovery disks the very moment you pulled the thing out of its box.
Jul 28, 2012 | Computers & Internet
I was restoring from the Acer recovery disk that I created when my process crashed before it completed. Now it won't boot up at all...HELP!
Your best bet is to reinstall the operating system. I couldn't count the number of times that the Recovery Discs created by users fail, it's very common. The only recovery that works a high percentage of the time is when the manufacturer puts a recovery partition on your hard drive.
You can try your Recovery Disc again, but if it produces the same results, just reinstall your operating system fresh. It shouldn't matter because either way you will lose your data.
May 13, 2012 | Acer Aspire T160-US321H (AST160-U-S321H)...
Cannot get on wireless internet
if you used the recovery disc for your model the drivers could have been installed already. Now, you need to manually install it. If you don't have the driver disc then u can download it from Toshiba's website. Just look for your specific model. I still recommend to reinstall using the recovery disc. hope this helps u
Aug 26, 2009 | Toshiba Satellite A135-S2276 Notebook
Toshiba 5005-S504 recovery problem
Unfortunately , you are going to have to call Toshiba.
from the sound of it your recovery disks are failing and they have already formatted your harddrve
May 09, 2009 | Toshiba Satellite 5005-S504 Notebook
How to recovery the system from recovery partition
Did you know you only get ONE shot at creating a recovery disc? And most of the time it is garbage, just like Vista.
He tried to put XP on it and failed? weird.
A couple things you can do...
1. Get your hands on a Vista disk. If you know anyone that works in IT, you can borrow a Vista disk. Do a complete fresh install. Use your "Product Key" and you will have your own Licensed, perfectly legal version of Vista.
2. Get yourself a copy of XP. Delete all partitions, then create a new one. Don't try to save that Vista recovery's toast. I recommend XP, but I'm a dinosaur.
Apr 07, 2009 | Toshiba Fusion Satellite U405-S2833...
Sound drivers for Xp sp2
For specific models with different chipset drivers, you can get the sound driver & pretty much everything else on If you can't connect to the Internet, "Tecra, Portege", & sometimes "Qosmio" models came with a built-in HDD recovery, meaning you need to create your recovery disk by running the "Recovery Disk Creator". An application to create your recovery disk. A shortcut is created on the desktop by default, if you cannot find it there, try looking at "C:\Program Files\Toshiba\Toshiba Recovery Disk Creator" & run the "exe" file, it should give you a menu to create one. After creating the disk, you can use that disc to install the drivers for all Toshiba pre-installed devices/softwares on that machine. For Satellite models, the disc should come with the laptop when you boughtt it. When you have the disc, just insert it inside of windows, it will give you options to install the driver & software for a specific toshiba device.
Hope this helps.
Jul 15, 2008 | Toshiba Satellite A100-S8111TD Notebook
Reformatting toshiba notebook equium
i think u need 2 reformat your computer..
Oct 16, 2007 | Toshiba Equium 7100S PC Desktop
Toshiba Satellite 1805-S253 Notebook Logo
107 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
