Question about Sony PlayStation Portable (PSP) Console
My psp says error (80010087)
I downloaded a game from the playstatoin network and i play but it says error (80010087 wat should i do???????????
  • leonardoporr Feb 10, 2009
    HOW IAM I GONA REACTIVATE MY PSP I DON'T KNOW HOW
  • Sony Master
  • 2,404 Answers
Try these steps:
1 save your data on your psp system to a memory stick 2 reset system to default settings
3 delete old license folder
4 reactivate psp on playstation store
5 try it again
Posted on Feb 09, 2009
  • Ben Wabnick
    Ben Wabnick Feb 11, 2009
    Need to call 877-971-7669 and have the reactivate your account. Thats the only way I know how.
Tell me about error 80010087 in psp 1004 11g
this is a video that should tell you how to work with the problem unless the games case is broken then you have to see if it can get repaired or you might have to get a new game.
http://www.youtube.com/watch?v=H29ZINaHlRw
Jan 26, 2013 | Sony PlayStation Portable (PSP) Console
How can i fix the problems with my PSP
Sounds like you need to update your firmware and is causing all the games you downloaded (on the old firmware) to not work properly. The alternative is to re-download all the games that seem to be affected. If this doesn't work, make sure you are getting your games from a legitimate source otherwise they wont play correctly regardless.
Nov 19, 2011 | Sony PlayStation Portable (PSP) Console
How can I fix it?
How can I fix it?
The game could not be started. (80020321)
Nov 03, 2011 | Sony PlayStation Portable (PSP) Console
Error 80010087
Check the firmware of your PSP. Some games may not work if the latest firmware is not installed.
You usually get this message if the UMD has errors reading or the UMD is not present or was ejected in the middle of playing a game. You should try testing your PSP with other disks, if it doesn't have the same problem with other disks then your UMD is most likely scratched or damaged.
If you are using a modded PSP then you will get this error if you load a game from the memory stick without having a disk inserted in the drive. Or if the game that you are trying to load requires a higher firmware version. You will need to install a higher modded firmware to fix the error if that is your case.
Hope this helps.
Jun 29, 2011 | Sony PlayStation Portable (PSP) Console
Hi my psp will not play games or movies and all it comes up is the game could not be started 80010087 so can you please help me thank you
its bricked buy a pandora battery and update it to newwest fw or for more help visit xbox360repairspro.webs thanks
May 27, 2011 | Sony PlayStation Portable (PSP) Console
My psp has error and i cant play any game it said error
PSP generate lot of network errors ........ so don't worry, you can solve this easily ..... i got some problem with my psp and its resolved by the help of Repair Guide
it covers network problems thoroughly so check this out !!
it will definitely helps you
all the best
click here to download
Dec 09, 2010 | Sony PlayStation Portable (PSP) Console
Cant get on playstatoin store says needs update
you can do so .........
but you have to be strong technically if not download this psp manual which gives complete detail about psp and solution to various problems
Click Here to download the repair guide
Oct 09, 2010 | Sony PlayStation Portable (PSP) Console
Will not play games
1 save ur data on ur psp system to a mem stick 2 reset system to default settings3 try it again
Apr 14, 2009 | Sony PlayStation Portable (PSP) Console
Psp error # 80010087 The game can not be started
Hi robbimic,
The first thing to check is the firmware of your PSP. You should make sure that your PSP has the latest firmware loaded. Because some games will not work or load up if the latest firmware is not installed or loaded up.
You usually get this error message 80010087 if the UMD drive has errors reading the UMD disc or otherwise the disc is not present or was ejected while in the middle of playing a game or loading a movie. I suggest that you try to testing to see if the problem happens with other UMD discs, if it doesn't then most likely the disc could be damaged or scratched.
Now if you are using a modded PSP then you will get this error if you load a game from the memory stick without having any UMD disc inserted in the drive. Or if the game that you are trying to load requires a higher firmware version installed into the PSP. You will be required to flash a higher modded firmware to fix this error if this is your case.
Hope this helps!
Peace! :)
Oct 21, 2008 | Video Game Consoles & Games
Hi pls help me!!!
you must have wireless
go to setings>network setings>infracture mode
then new conection then scan and it will tell you wat to do from there
May 21, 2008 | Sony Limited Edition PSP Daxter...
Sony PlayStation Portable (PSP) Console Logo
2,932 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
