Question about Great States Garden
OLDER GREAT STATES PUSH MOWER
I have an old weather-w series great states push mower and the rear roller assy is busted. where can i find parts for it in northern calif.? Or is the company still around?
  • raiderricklm Feb 09, 2009
    the model #weather-w 10" tall wheels x 1-1/4"thk roller shaft assy is 18" long 5 blades 15" str across or 16" with the curve of the blades. this mower is at least 30 to 40 years old
  • JERRY ABELL
    JERRY ABELL May 11, 2010
    hello mr r. there are twenty old great states push mowers listed.could you be more specific in the model number and type of mower. MrFixIt.
  • 109 Answers
SOURCE: weedeater lawn mower shuts off, but still has 3/4 tank of gas
On some mowers...if the gas cap vent is not working properly, it will run fine for about 15 or 20 minutes, start spitting and sputtering, if you loosen the cap, and let air back into the tank it starts running normally again.
Posted on Apr 16, 2009
  • 68 Answers
SOURCE: Rear skirt on lawn mower flips under when backing up
Sounds like the skirt is too long for the cutting height you are using, either raise the cutting height or shorten the skirt. Remember it's a safety guard for trash kicked up when mowing!
Posted on Apr 26, 2009
  • 8 Answers
SOURCE: Mower starts up great and then dies
If it's a briggs engine, sounds like you have water / debris in your carb fuel bowl. Using spray carb cleaner will only work if you remove the bowl and clean the carb jets. Also, you could have water in the gas tank as well. First, remove your air filter, then remove the 3 screws that attach your filter bracket to your carburator and mower. Take off your fuel line at the carb and drain all your gas into a clear jar. If it looks very yellow, cloudy, or see water in the bottom of the jug, change your gas. Using a half inch socket wrench, after gas line is disconnected, remove the fuel bowl and clean with carb cleaner. Also, examine the bolt you just removed. There are 2 jets in the side and one at the end. Using the carb cleaner, make sure they are clean as well. Use the carb cleaner extension tube to spray up inside the bottom center of the carb, where the bolt threads, to clean that area as well. After all this make sure ur float assembly is intact and reassemblt the bowl to the carb and reattach the the fuel line. finish bt reattaching the air filter support bracket makinf sure the gasket between the carb and the bracket isn't damaged.
Posted on May 25, 2009
  • 376 Answers
SOURCE: need to know where to put the oil
There should be a plug with two ears on the left rear of the engine
Posted on Jun 02, 2009
  • 110 Answers
SOURCE: lawn mower keeps dying
Remove gas cap. If mower now runs without stalling, your problem is the vent in the gas cap is blocked. Replace the cap. Common problem!
Posted on Sep 22, 2009
The mower is not pulling.
Check if your belt on. The manual states taking you front wheels apart. Remove grass wrapped around parts. Grass to high. Raise platform up.
Apr 23, 2014 | Craftsman 675 Series 190cc 22" Briggs ...
Front wheels on manual mower lock when pushing for awhile.
1 Locate the height adjustment lever on the inside of the left rear wheel.
2 Kneel next to the mower and push the left height adjustment lever toward the center of the mower. This will unlock the lever from the locking pin on which the height is currently set.
Read more: How do I Adjust the Height on a Great States Reel Mower? ' eHow.com http://www.ehow.com/how_6834215_do-great-states-reel-mower_.html#ixzz21NOr1e8d
3Rotate the lever toward the front of the mower to lower the height of cut, or toward the rear of the mower to raise the height of cut.
4 Release the lever over the locking pin closest to the desired height of cut.
5 Repeat these steps with the adjustment lever on the right-side rear wheel. Be sure to set the right wheel lever to the same position as the left-side wheel's lever for an even cut.
Jul 22, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
The handle snapped off my mower. Everything else works fine, but It's useless without a good way of pushing it. How do I get a new handle?
Hi and welcome to FixYa. I am Kelly. The handle is in 2 parts. The lower handle and the handle extension. You can order them here:
https://www.reelin.com/ItemGroupItems.aspx?ItemGroupID=58
31108-2 - LOWER HANDLE 20" RH - QTY 1 EA. $6.30 button_in_cart_new.gif 31108-3 - LOWER HANDLE 20" LH-BLKTX - QTY 1 EA. $6.30 button_in_cart_new.gif
31098-3 - CENTER HANDLE SEC-BLKTX - QTY 1 EA. $7.05
button_in_cart_new.gif 31099-3 - TOP HANDLE SECTION-BLKTX - QTY 1 EA. $6.15
Hopefully you know which part of the handle that you need.
You can contact them here:
American Lawn Mower Co.
P. O. Box 369
Shelbyville, IN
46176
Consumer Hotline: 1-800-633-1501
Email: Sales@reelin.com
Thanks for using FixYa.
Kelly
May 30, 2010 | Great States 20" Scotts Classic Push Reel...
How do you adjust push-reel mower
You don't! Usually. Some allow height adjustments only. Others do not! One height fits all! On a side note...I hope you are a youngster! Maaaan! those puppies really require more push energy than you'd think. And if you aren't a young'in I sincerely hope you got a "victory garden" patch or something small in area...WHEW! But...I have seen them for sale "new" as recently as 2 weeks ago. (I'd rather faint from trying to pull start my "self propelled" baby!
May 09, 2010 | Great States 415-16 16-Inch Standard Full...
In need of a replacement handle
You should be able to buy the top section of the handle. What kind of mower is it and what is the model number? It should be on the rear of the deck.
Jun 10, 2009 | Great States Corp. 16 In. Scotts Elite...
Scotts reel mower gear problem
I found some replacements at http://www.reelin.com. The parts number for the pinion gear is 30737-2, 30737-3 (left and right) for the Scotts Classic.
You can find the owner's manual, with part numbers, here:
http://www.reelmowersetc.com/2000-20.pdf
Jun 09, 2009 | Great States 20" Scotts Classic Push Reel...
Reel mower isn't engaging -- blades aren't rotating and cutting
Remove the wheels and check the gears inside.
It sounds like they are worn or sheared and need
renewing
Jun 05, 2009 | Great States Corp. 16 In. Scotts Elite...
I would push the prime button 3 or 4 times it starts then quiet
I took my carburetor off and blew it out with compressed air. Runs great now. Make sure to get all of it. Little screw on bottom has a hole in it too!
Apr 18, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
A part on my Scotts 16 '' Elite push mower broke
The number Jakeyjones gave is the customer service number. Call it and describe your problem.
As for the gear, I had the same issue. I called customer service and was told that there was a supplier material issue that caused some gears made last year to break more easily than they are supposed to. They are sending me 2 new pinion gears completely free of charge. These are the black plastic gears that engage against the orange wheels to make the blades spin. Make sure you don't lose the pawls (metal rectangular pins that go through the shaft to engage the pinion gears).
1-800-618-7474
I called at noon eastern time today. The woman I spoke with was very helpful and knew exactly what parts to give me.
Mar 24, 2009 | Great States Corp. 16 In. Scotts Elite...
Garden Logo
95 people viewed this question
Top Great States Garden Experts
Dennis Key
Dennis Key
Marco De La Fuente...
Salvagedrover
Are you a Great States Garden Expert? Answer questions, earn points and help others
